SAS positives/negatives
I have a friend who owns a shop that I might have do it. I would do it myself but I dont know how to weld. Dropzone, the reason is that I want to be able to run 33s and I want a small lift like a 2" or 3" lift and ive read that the IFS lifts are crap. That's why I am thinking about doing a SAS
Your better off getting out and wheelin your rig now then see if sas is a good option. 4 crawler sales 1" body lifts.
So much better places to improve for wheelin than starting with an sas. To a large factor skill of the driver is more important than sas.
id do the sas if I were you. like others said the 3.0 is a pos motor. basically if I were you id think about what I wanted in the long run. the 3.0 to 3.4 swap is something people do a lot. So the way id do your build is the the sas in the front with heavy duty leafs if its done right itll drive just fine I could take the hands off my dd sas at 80mph and the wheel never shook. Do chevy springs or trial gear springs in the rear probably a lot harder to do in a runner cause you cant just remove the bed to get the weld on the hanger beside the gas tank. once you have all your suspension done and your motor is still running wait till it blows up and find a 3.4 and do the swap youll have the truck forever itll turn heads and youll be very pleased with it.
I would take the advise of the members with 15k posts first. That said.. I am doing exactly what 88sas said except with a SBC so i need to SAS first anyway to fit the engine in. Another factor to think of is with a SAS you probably won't be doing a whole lot of high speed offroading or jumping.
#27
What happened to the 90' 4runner that you were going to sas???
JookUpVandetti
09-30-2015 08:58 AM
Toys4parts
09-26-2015 01:56 PM
