YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-08-2008, 10:19 PM   #1 (permalink)
Wantayota24's Avatar
Which SAS kit?
so i have been searching YotaTech for ideas on a SAS for my future truck. i have been looking around and found three kits. i want to lift if 5" with the SAS and 5" with a rear lift kit.
What is the most cost effective yet most quality way to go?
Marlin
http://www.marlincrawler.com/htm/suspension/
AllPro
http://allprooffroad.com/index.php?o...ask=view&id=42
Trail-Gear
http://www.trail-gear.com/sas.html
http://www.trail-gear.com/rearsuspension.html
I personally like the Trail-Gear because of the cost.
What do you guys think is the best way to go?
__________________
Eldorado Dust Devils child
Wantayota24 is offline
Sponsored Links
To remove this ad, register today!
Old 06-08-2008, 11:35 PM   #2 (permalink)
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
i have a mis-matched-pieced-together on my SAS, but every TG sas kit i've seen is very clean and complete. i know several people who are very happy with their Trail-gear SAS kit.
__________________
3genRunner: including parts from 3 generations of 4runners, '92 pickup, '80something Land Cruiser, Chevy truck, Ford sedan
89 4runner: Project DD. 3.0, needs a new tranny
81 2wd pickup: 22R | 5-sp | long bed | quad hauler, leaks oil but gets 26mpg
91 Honda Prelude: the Daily Driver
WA, OR or CA wheeler?? Check out pacific-crawlers.com and check out yotaworks.com
Tofer is offline
Old 06-09-2008, 05:38 AM   #3 (permalink)
dirtoyboy's Avatar
The marlin and all pro kits are very similar parts wise. The trail gear kit isnt bad but you do get what you pay for....
Personally, I like knowing where my springs come from (Marlins come from Betts Spring Company, Trail gear come from China) Marlin uses 555 stamped OEM FJ80 TREs and trail gear uses CHINA stamped TRES. They look like toothpicks compared to Marlins.
I do have some trail gear parts on my truck but I would be vary wary of any steering or brake components from purchased from them. I would never run them on my truck.
Every thing else that I have seen in the kits is very similar (frame plate kits, ubolt flips, etc...)
After many hours (days) of research I chose the marlin kit....(I even got mine on sale and it was the same price as trail gears kit)
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
I'm the yota junk man......PM me for ALL your parts needs NEW or USED
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 06-09-2008, 05:53 AM   #4 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Check out our website.
I have used Marlin, All-Pro and Trail Gear parts on numerous SASs, not a whole lot of difference in the kits IMO. It is kinda like bottled drinking water...same water, different packaging and personal preference. The big variable on these kits are the individuals installing them. I have seen more stuff get fubared by someone working on their own junk simply by not bothering to follow FSM torque specs or actually reading the damn installation instructions.
Just remember, if you building a SAS rig to drive on the street, your components are going to see a LOT more wear and tear, and on the SAS kit I drove on the street I went with as many OEM parts as I could (i.e bearings, seals, etc but that cost a LOT more). If it is a trail rig, you are going to be tearing into the axle yearly at least, so wear parts are going to get examined and replaced.
waskillywabbit is offline
Old 06-10-2008, 08:29 AM   #5 (permalink)
netwt12's Avatar
mine is trail gear and is very flexy. i can't comment on the other brands as i have no experience with them.
__________________
2000 4Runner Limited 4x4 "TRD". Blown, etc.
1988 Trail Truck. SAS, Dual Cases, Exoed, Aluminum Trail-Ready Beadlocks, 37" Boggers, and Extreme Rock Rash.
2008 Camry LE.
netwt12 is offline
Old 06-10-2008, 09:14 AM   #6 (permalink)
neoworm0's Avatar
I bought the trail gear kit and the price was very good. However, all the bearings they supplied, all the bushings and the tie rod ends were JUNK!
They ALL wore out within a few months of use. I have since replaced the TRE's with 555's, the wheel bearings with stock toy parts as well I went back to the stock toy rubber bushings. 18 months of use now and everything is fine with the exception of relacing some of the bushings again but I wheel a lot so that's pretty normal.
Also none of the greasable shackle bolts actually work. Didn't matter to me because I went back to rubber anyway but they SHOULD work.
Bottom line is the metal parts ie brackets and springs etc were fine but consumables like bearings etc are garbage.
If Marlin or All Pro supplies OEM parts with there kits and are only a bit more money I would go with them. Otherwise I would say the parts supplied with TG's kit are only good for bush spares.
I have the rear kit as well and it is fine aside from the bushings which I replaced with OEM and they last much longer.
Just my $.02
__________________
1995 Toyota PU SR5 V6, A few mods.
neoworm0 is offline
Old 06-10-2008, 09:53 AM   #7 (permalink)
Red_Chili's Avatar
You forgot a supplier.
www.frontrangeoffroadfab.com
Brian's spring hangers are unique in that they mimic the factory geometry, and stress the frame less (frame cracking is not uncommon with a SAS). Look at Marlin/Allpro/TG and you will see the same basic design. More drop than FRORF, and more leverage applied to the frame as a result.
Something else: with the prepackaged all-in-one kits, you don't get to make any choices. For instance, the F250 towers at $12 each are robust and simpler than the hoops supplied in the kits. Just brace the back with a triangle on the motor mount. You get the shocks they include, maybe you like them, maybe you don't. You get the pitman arm they include. You get the TREs they include. And so forth. Something to think about.
Just some thoughts. Good to know about TG's bearing/TRE quality. Sometimes you get what you pay for.
__________________
-Bill
Red Chili II: 1987 SASed 5VZ-FE 4Runner with more stuff than I can afford. Not that that makes me unique 'round here.
Shadowfax: 1993 minitruck. Getting the Engnbldr full meal deal. Hunting truck and DD!
Bio Page
Red_Chili is offline
Old 06-10-2008, 10:16 AM   #8 (permalink)
SwampThing's Avatar
I went with the 5" front and rear, 14" shockhoops, 5.29 gears, and a few other odds and ends from trail gear via wabfab (nothing like throwing some business to a fellow forum user). Very pleased with the kit. My greasable shackles work great, they accept a ton of grease, and lay down like a cowed dog.
Only thing is, is I wouldn't recommend getting the heavyduty front springs unless you plan on swappin in a v8.
And I've only had mine lifted for around 750miles, so I can't really attest to the TRE's or bearing longevity. They seem good so far, especially as much as I beat my poor ol truck up lol...
__________________
Toyota 84 PU: Killed in Action - Pending (Give it time, it'll happen)
Toyota 89 4R: Killed in Action - Dukes of Hazard'ed / Evil Knievel'ed
Toyota 95 PU: Killed in Action - Retread blow-out roll over
Some folks call me a crazy redneck. I prefer just Clint.
Quote:
Originally Posted by abecedarian View Post
and a 3/4/5 right beer-angle isn't a recognized geometrical figure.
Quote:
Originally Posted by thook View Post
One day a child will ask,"Mommy, why are there endangered species?". "Well, dear, one day someone invented the truck... Then, Clint was born!"
SwampThing is offline
Old 06-10-2008, 10:19 AM   #9 (permalink)
SwampThing's Avatar
And having never had bilstein shocks before, I don't think I'll ever get em again. Sure they're nice and pretty all chrome and whatnot, but they make the truck ride like a tank...
__________________
Old 06-10-2008, 10:21 AM   #10 (permalink)
dirtoyboy's Avatar
THREADJACK:
Clint, what happens to your spring when the shackle hits the frame? It shouldnt do that...the spring WILL bend when it has nowhere else to go...
__________________
Old 06-10-2008, 10:25 AM   #11 (permalink)
camo31"10.50"'s Avatar
damn dirttoyboy you beat me too it..lol..i was wondering the same thing
__________________
1986 Toyota 4x4 extra cab pickup stock 22R 5spd with 35,000 miles on a complete rebuild pushin 200PSI in every cylinder...31x10.50 swamper TSL's (muddin shoes) Kelly Safari SUV (street shoes)
1980 Toyota 4x4 20R/L43 combo not in the best of shape...but gets me wherever the '86 wont.. :)...still not sure if i want to part with it just yet..(FOR SALE!)
camo31"10.50" is offline
Old 06-10-2008, 10:35 AM   #12 (permalink)
Kaleb's Avatar
Send a message via AIM to Kaleb
I went with All Pros kit. It's treating me good.
__________________
1994 Toyota 4Runner
V6 3.0
5 Speed Conversion
Solid Axle Swap
Rear Leaf Spring Conversion
1985 Solid Front Axle
Bilstein 5150's All Around
35" BFG Mud Terrains
Yukon Full Spool in Rear
3" Exhaust w/ Hi-Flo Cat and Magnaflow Muffler
Drilled Air Box
MY BUILD
Quote:
Originally Posted by Big_Denny View Post
i have been trying to find the dip stick for my rear differintial and just can not fid it is there a posibilty that the previous owner removed it? or lost it? he seemed pretty dumb and didn't know about wheeling
Kaleb is offline
Old 06-10-2008, 10:40 AM   #13 (permalink)
SwampThing's Avatar
The spring will eventually be hitting nothing
That portion of the frame will no longer be in existence whenever I get the motivation to bob it... Yeah, I still need to do the bumpstops, just haven't gotten around to it yet either.
__________________
Old 06-10-2008, 10:56 AM   #14 (permalink)
dirtoyboy's Avatar
Which way are you moving the hangar? Seems to me it needs to go back...not forward
You dont want that shackle to reverse either......
__________________
Old 06-10-2008, 11:07 AM   #15 (permalink)
SwampThing's Avatar
Aint quite get what you're saying, but imma chop the frame right behind the shackle mounts, and either bob the body or build me a flatbed.
Hanger and mounts are where they're supposed to be. Hangers 6" forward, mounts 2" back.
__________________
Old 06-10-2008, 11:29 AM   #16 (permalink)
dirtoyboy's Avatar
Those are just general guidelines...not exact directions...
What I am trying to say is that your springs WILL bend when the shackle hits the frame...the spring cant compress anymore so it bends...seen it many times...its only going to get worse as the springs settle
its a good thing you havent cut the frame yet because you're gonna need it.
Do you have any ride height pics of your shackles???
__________________
Old 06-10-2008, 12:29 PM   #17 (permalink)
SwampThing's Avatar
Aint my first rodeo That's why god invented the bumpstop lol.
Aint got a good picture of em, but they're sittin about 25-30º.
__________________
Old 06-10-2008, 12:41 PM   #18 (permalink)
