YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 04-04-2008, 07:47 PM   #1 (permalink)
one2high's Avatar
SAS front leaf spring mount bracket
SAS front leaf mount bracket
Can anyone tell me how the front leaf spring mount brackets are designed with a boughten SAS kit? Does the inside of the mount have a threaded hole or a nut welded on the back side for the spring bolt to fasten to? Any/all pic's welcome!!
one2high is offline
Sponsored Links
To remove this ad, register today!
Old 04-04-2008, 09:09 PM   #2 (permalink)
4Crawler's Avatar
Usually just a straight through hole with a bolt and lock nut, stock size is 18mm.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 04-04-2008, 10:19 PM   #3 (permalink)
AxleIke's Avatar
Ah, this sounds like a truck that REALLY needs a SAS.
First, use 16 guage steel for everything.
Weld the springs to 24" blocks, then weld the other end of the blocks to the axles. This should give you plenty of clearance for 89" tires, and at least 12 shocks per axle.
Paint everything safety green.
Lastly, DO NOT, under any circumstances, buy any armor, gears or lockers. Those are complete wastes of money.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 04-05-2008, 02:14 AM   #4 (permalink)
Staff
Elvota's Avatar
Quote:
Boughten... that may be my new favorite word... even if I don't know what it means.
Here is a pic... basically a bolt and a nut per side:
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
Elvota is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Leaf Spring SAS Bumpstops!! ORS Vendor Advertising 0 05-10-2007 07:37 AM
Leaf Spring SAS Bumpstops!! ORS Axles/Suspensions/Tires/Wheels 0 05-09-2007 09:26 AM
SAS with buggy spring shacle mount? and steering question. meswoleshane 86-95 Trucks & 4Runners 3 01-06-2007 02:35 PM
Front SAS leaf spring question... 6lug Offroad Tech 6 12-12-2005 05:16 PM
4 link versus leaf spring SAS Dan_90SR5 95.5-2004 Tacomas & 96-2002 4Runners 3 03-13-2004 11:38 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
