| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
SAS conversion help on axle
__________________
1992 Pickup 4x4 V6 5-Speed clutch pedal clevis pin hole fix http://www.yotatech.com/f116/clutch-...-round-181666/ |
#2 (permalink) |
1979-1985 TRUCK front axle is what you want, but if you have to ask then I'm concerned that this swap may be a little over your head. Have you thought about tackling other thinks like transfer case gears and a rea rlocker? I'd do that first and wait to blow up your IFS.
__________________
-1984 reg. cab truggy. I HATE SHEET METAL ON TRAIL RIGS!!!! duals, locked f/r 5.29s, hysteer, 63s and RUF springs, 34 x 10.50 Swampers, 1" master, V-6 calipers, dove nosed & street legal (thanks Colorado) -1988 4Runner, daily driver, Downey intake, Headers, rear AAL, Stock, and staying that way! (maybe) Last edited by UKMyers; 05-15-2009 at 02:07 PM. |
#3 (permalink) |
Any 79-85 front axle. Do yourself a favor and search.
EDIT: This is a pretty basic knowledge oldgold3vze is right...
__________________
1982 2wd Pickup - Custom Interior - Pioneer 8" subs 1990 4runner - Blown Head Gasket Mod (fixed!) - Cruiser Coils - BJ Spacers - Bed Lined Fenders - CB/PA - Alpine HU - H4 Headlights - 2 15s and a Rockford amp. 1996 Camry - 400,000 miles on original engine/transmission. HELL YES!!! All it takes is a quart of oil with every tank of gas. Project: scratch building a modernized Lotus 7 replica using a 22-re Celica drivetrain Last edited by toylocost; 05-15-2009 at 11:30 AM. |
#4 (permalink) |
Staff
Check out these sites:
marlincrawler.com trail-gear.com allprooffroad.com Spend some time learning, and come back when you are learned. Also, spend some time searching the forums here. This info has been available since this forum was created. In fact, we have a subforum specifically dedicated to SAS: http://www.yotatech.com/f152/
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#5 (permalink) |
All 3 of those
![]() Couldnt agree more.
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#6 (permalink) |
i've done a little research and all the SAS swaps i've seen online so far has not said anything about gearing in the front diff. I just wanted to know since my truck is already 4x4 and is already paired up with the stock setup, would think that going with the solid axle i would need to match the front diff, with the stock diff in the back.
Maybe it's the wrong question to ask. http://www.fourwheeler.com/techartic.../photo_15.html I've also been looking into Sky's kit and Wab's kit as well.
__________________
#7 (permalink) |
No it wasnt the wrong question to ask, But most people do an sas to fit 35's or larger, and you cant really run 35's without NEW (or maybe used) matched gear sets front and rear, your stock 4.56's arent going to turn those well, if at all..
Whatever the case you need lower gears (numerically higher), So it really shouldnt matter what gear set comes in a toy axle.
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. Last edited by scuba; 05-15-2009 at 01:40 PM. |
#8 (permalink) | |
Quote:
Also.. You can push 35's with 4.56's. It won't be fun, your clutch and mpgs will hate you but you can get by with it. Go onto Trail-gear.com and marlincrawler.com. Read their installation instructions. I did that a few times before i tackled my project. helped a bit. Yes any 79-85' axle from a pickup or 4runner will work. The later ones are perfered more since it has more factory bracing under it. axle prices range from free (if your lucky) to 300 or so.. I paid $300 for mine. Im sure there is people that have paid more, and people who have paid less. just depends on the deal you can find.
__________________
Mike 1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, Locked, 5.29's, 39.5" iroks on Beadlocks, Armor'd Longfields, Duals coming soon: My build thread http://www.yotatech.com/f152/904_run...thread-158746/ http://www.treadlightly.org/ http://www.pirate4x4.com/tech/billav...ery/index.html |
#9 (permalink) | |
Staff
Ideally you want an 84-85 because they had a better truss set up. If you do it right it won't matter though because your going to want to add truss's to it anyways. Your also going to want to plate the steering stops. The stock ones are junk. There's a lot more to this project than just slapping an axle out of older Toy under your truck. Here's a list of things off the top of my head that I've seen cause Toys to sit in garages for years unfinished because they didn't realize what they had gotten into.
First prepping the axle.. full rebuild, truss, armor, plated steering stops. Might as well stick some longfields in there while rebuilding or else you'll get really good at replacing birfs Even 33's look dinky on a SASed rig.. most guys run 35's If your gonna run 35's your gonna need to regear If your gonna regear you might as well lock it while it's apart Oh crap the stock push pull won't work.. Gotta get a hysteer kit Shoot what springs to go with since I need 4 new leaf springs Oh man now the front is higher than the rear.. gotta rebuild the rear too What springs in the rear Shocks are now to short.. gotta buy new shocks all around Now it flexes too much in the front.. need a long spline custom shaft Of course you can always do all this on the cheap... hack it together and then spend all your time broke clogging up the trail. Do your homework.. a SAS is a huge expensive project. An IFS rig on 33's with some decent gears and locked up will AMAZE you at where it'll go when driven properly.
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000 Need Toyota Parts? www.davezoffroadperformance.com Quote:
#10 (permalink) |
Good post Joey !!
__________________
#11 (permalink) |
x2, My opinion is do it right the first time and you will never have to worry about it again.
__________________
86 Pickup 4x2, Manual (Sold) 87 Extra Cab Pickup 4x4, Manual (Sold) 93 4Runner 4x4, Manual, 3.4 Swap In progress 90 4Runner 4x4, Manual, Blown 3.0 (Stripping out for parts then to become a trail rig/camping/fun truck) 94 Lexus SC400, 1UZ, magnaflow exhaust, after market headlights, bought for parts for the swap into the 90 4Runner |
#12 (permalink) |
or you can go full width chevies from the start it depends on which direction you want to take your 4runner
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1972 stepside jimmy d44/d70 425hp 1995 green range rover |
#13 (permalink) |
Just for now...lol....
__________________
I did have a 1990 X-cab P/U, 3.0 SAS'd w/ 3" Trail Gear IFS Eliminator Kit, 4" Trail Gear Rear Lift Kit, 35" KM2s, Yukon 4.88s, Locked Front and Rear w/ Aussie and a Detroit, Sliders, M-8000 Warn Winch, But I sold it |
#14 (permalink) | |
Quote:
Good luck with this.
__________________
#15 (permalink) |
I know a lot of people mention gears, but I push my 36 tsl's w/ the stock 4.10 gearing. Of course, its not a daily driver and its dual cased, but does ok here in NC driving to the trails. I will eventually go to 5.29's, but for now, just welded the spiders and waited for the expense of gears and lockers.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| sas conversion questions | camarorally68 | Newbie Tech Section | 3 | 05-05-2009 06:49 PM |
| 3.4L Oil Pan Conversion for SAS | ORS | Vendor Advertising | 0 | 04-29-2008 10:53 AM |
| ORS Tacoma SAS /79-85 3.4L Conversion Oil Pan Conversion | ORS | Vendor Advertising | 0 | 09-26-2007 04:40 PM |
| SAS conversion 4x2 to 4x4 is it possible? | sofakingfresh | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 08-10-2007 09:02 PM |
