RT's 86 SAS - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-05-2009, 06:17 AM   #1 (permalink)
RT's 86 SAS
Well after a year or so of wheelin the IFS time to get rid of it. Just started the prep on the axle housing and parts (its off of an 80 yota). Got parts on order should be here soon, gonna go with the 4" in the front and havent yet decided what or how I am gonna do with the rear just yet. I have been reading several posts on this and doin alot of research but if anyone has any advice for me would be glad to hear it
sav-yoda is offline
Old 04-05-2009, 07:32 AM   #2 (permalink)
Banned 'cause I was 4runnerchevy also banned
I would put some gussets an the housing (knuckle and housing). Are you going crossover ? Are you gonna rotate it for better pinion angle ? Are you rebuilding it with new seals and trunion bearings ? Gears ? Locker ?
86toylet is offline
Old 04-05-2009, 07:54 AM   #3 (permalink)
Yeah I already order the gusset kit, should be here n a few days, as well as the locker(lock-right), knuckle rebuild kit as well with the trunion, wheel bearings and hd axle seals from mc. Unfortunately not changin the r&p just yet, gonna run the stock for right now(outta cash). How difficult or what do I need to rotate for the better pinion angle? And I bought the 4" SAS kit so should come with almost everything I need including the high-steer.
sav-yoda is offline
Old 04-06-2009, 08:30 AM   #4 (permalink)
Since I am using I believe a 79 front axle, does anyone know if I will have to change, add or modify anything for the 4" SAS?
sav-yoda is offline
Old 04-06-2009, 08:46 AM   #5 (permalink)
Quote:
Originally Posted by sav-yoda View Post
Yeah I already order the gusset kit, should be here n a few days, as well as the locker(lock-right), knuckle rebuild kit as well with the trunion, wheel bearings and hd axle seals from mc. Unfortunately not changin the r&p just yet, gonna run the stock for right now(outta cash). How difficult or what do I need to rotate for the better pinion angle? And I bought the 3" SAS kit so should come with almost everything I need including the high-steer.
Nice it sounds like you got it covered. As far as rotating the axle, search pirate for cut-and rotate front axle. You will need to relocate spring pads, steering stops, and get a 3-4 inch pipe cutter, welder, grinder. I rotated mine 12* and the pinion angle as well as driveshaft angle are perfect.
86toylet is offline
Old 04-06-2009, 05:17 PM   #6 (permalink)
Spinnbait's Avatar
Check out this company. One of these may be well worth your time since you have already stripped the axle (discounted price for core).
http://www.cruiseroutfitters.com/customfab.html
__________________
Cannondale Rush 3 carbon (my new baby)
Surly 1x1 (my D/D)
1973 Schwinn cruiser (my shop bike)
Spinnbait is offline
Old 04-12-2009, 06:55 AM   #7 (permalink)
Updated pics, after a good long 8 to 10 hours the IFS crap is finally gone! The 4" TG IFS Eliminator kit should be here on Tuesday (Thanks Wabbit), soo looks like another long weekend comin up (gotta get it out of my buddies garage)!
sav-yoda is offline
Old 04-12-2009, 07:36 AM   #8 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Several ways to help the pinion angle without having to rotate the knuckles.
High pinion front diff, dual cases, but the key is a proper driveshaft with the proper u-joints (double cardan). IFS ones won't work as they do not allow enough degrees of freedom.
Since I am using I believe a 79 front axle, does anyone know if I will have to change, add or modify anything for the 3" SAS?
On 79-80 SFAs the outers are different and not compatible with the major aftermarket SAS kits (has to do with how the rotors attach) so you will need some new wheel hubs. I've never used one as I know it is an issue so I've avoided 79-80 SFAs, so not definite if that is all that you need.
Keep me posted and have fun!
waskillywabbit is offline
Old 04-12-2009, 09:56 AM   #9 (permalink)
I went with the Trail Gear 3" in the front and 4" in the rear. I like the stance and gives me the option to run 35's once my 33's wear out!
__________________
I did have a 1990 X-cab P/U, 3.0 SAS'd w/ 3" Trail Gear IFS Eliminator Kit, 4" Trail Gear Rear Lift Kit, 35" KM2s, Yukon 4.88s, Locked Front and Rear w/ Aussie and a Detroit, Sliders, M-8000 Warn Winch, But I sold it
RaginYota is offline
Old 04-17-2009, 05:52 AM   #10 (permalink)
Got my big BROWN delivery Tuesday (Thanks Brian@Wabfab) and started welding on the knuckle gussets last night, just wanted to post a few more pics of the progress. Gonna try and finish up the axle tonight so I can start the painting process on it!
sav-yoda is offline
Old 04-17-2009, 08:01 AM   #11 (permalink)
Looks good!! For the steering stops, did you shave the little dammits so they would sit flush inside of the stops?
__________________
Old 04-17-2009, 08:37 AM   #12 (permalink)
Quote:
No I didnt, I just welded them on the top of the stops, didnt see any real need to weld them inside, they should still be alot stronger than stock that way as well, I hope!
sav-yoda is offline
Old 04-17-2009, 10:39 AM   #13 (permalink)
Oh yeah they are gonna be alot stronger. I did weld them flush, but I was bored and had the time...lol... it was a PITA... it is amazing how boredom will do to you.
__________________
Old 04-22-2009, 11:35 AM   #14 (permalink)
Well still working on it (very time consuming), was tied up this past weekend with other things soo have been just doin alittle here and there after work during the week. But off work next week soo should get it finished up. Anyway I ran into a small problem the other day, has anyone used a 79 or 80 sa? If so how did you bolt the rotor to the hub? From what I have read is that the 79 and 80 sa hubs use 6 bolts to bolt the rotor to the hub and not 6 studs and 2 bolts like the later models. The bolt pattern lines up but the bolts are smaller than the rotor holes therefore leaving some unwanted play in the rotor (not acceptable). Any help you guys can give would be appreciated.
sav-yoda is offline
Old 04-24-2009, 05:27 AM   #15 (permalink)
Well finally got the axle mounted and set it back on the ground! Im thinking the 33's look awful small on there now, should look a little better with the 36's. Still have to lift the rear thats why its sitting at an angle in the pics right now. I mounted the front hanger a half of an inch forward like the instructions said but the shackle angle is still too straight up and down looking. I think I am gonna mount it flush and see if it will help my shackle angle, I know they will settle some but its almost 90 degrees to the frame now. So dont think they will settle that much, would like to see the angle at about 15* now and settle closer to the 25 or 30 area. Any opinions or suggestions? Oh btw my fenders were previously cut about 2 inches all of the way around which makes it look even that much taller, had to make some room for the 33's with the IFS.
sav-yoda is offline
Old 05-15-2009, 10:38 AM   #16 (permalink)
Well finally almost got this thing back together for the most part, well driveable now anyways. Still have a few loose ends to finish up, right now working on the driveshaft, using the long spline from TG with the modified IFS double cardan and making a spare out of the SA one with the square tubing. Real happy with the project, cant wait to get it out on the trail and oh yeah get some bigger tires hahaha The 33's just arent gonna cut it anymore, plannin on goin to 37's. If anyone is interested in any of the IFS parts email me (I know most everyone on here is gettin away from the IFS but worth a shot)!
sav-yoda is offline
Old 05-15-2009, 02:56 PM   #17 (permalink)
Staff
Looks like you are making progress.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
IFS to SAS..SAS High maintenance issues?? toyospearo 86-95 Trucks & 4Runners 42 11-20-2008 10:43 AM
To SAS or not to SAS? That is the question DeepSeaSnake Solid Axle Swaps, All Years 1 05-15-2008 06:16 PM
SAS for the FJ Corey FJ Cruiser 2 03-23-2006 10:50 PM
Sas customcruiser North Carolina 44 02-19-2004 09:05 AM
More sas ?s jeremy The Fab Shop 42 01-09-2004 04:09 PM
2009 InternetBrands, Inc.
