YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-31-2008, 08:24 AM   #1 (permalink)
John S.'s Avatar
Removing a leaf from the pack
Recently finished SAS on my 88 4runner and the front is a few inches higher than the rear. I have the trail gear 5'' hd springs in the front and 5'' in the rear, but it is no where level. I was just wandering if I removed a leaf from the front pack if it would drop the front enough? If so which one should I remove?
__________________
1988 4runner w/ 5'' SAS Trail Gear Kit, 3'' body lift 5.29 with Detroit Lockers, and 35'' Iroks
2002 Chevy Z71 w/ 6'' ProComp stage two suspension, 3''body lift and 37'' SSR
http://bslca.com/
John S. is offline
Sponsored Links
To remove this ad, register today!
Old 07-31-2008, 09:26 AM   #2 (permalink)
4Crawler's Avatar
Might contact TG for advice, but generally pull the 2nd leaf from the bottom and see how it looks. Also, most folks gor with 1" lower spring up front since you get a built in 1" of lift due to the spring hanger and longer shackle on a SAS.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
building own leaf pack MattTse 84-85 Trucks & 4Runners 4 09-11-2007 02:59 PM
shackles or new leaf pack? dijlop 86-95 Trucks & 4Runners 18 05-14-2007 06:13 PM
Shackles with new Deaver 8 leaf pack? kamaaina1 Offroad Tech 1 04-23-2007 01:46 PM
leaf pack length jimbo74 95.5-2004 Tacomas & 96-2002 4Runners 10 09-11-2004 01:33 PM
OME leaf pack questions. GRNTACO 95.5-2004 Tacomas & 96-2002 4Runners 10 02-13-2004 02:05 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
