Problem with front driveshaft after SAS - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-18-2009, 08:19 PM   #1 (permalink)
YOTA666's Avatar
Hey guys, I was just wondering what you all did for a front driveshaft after you finished SAS'ing?
I took my stock one and clearanced the heck out of it/lengthened it, but for some reason the friggin thing shakes like hell when I put it in 4wd. I know the balancing is way off but would that make it shake at slow speeds?
The thing seems to smoothen right out if i speed up but when i start moving from a stop it vibrates like crazy or when its engine breaking/going slow...
__________________
88 4RUNNER- 3.slow, Centerforce clutch, 2 inch body lift, s10 lowering blocks converted to lift blocks, Trail Mart SAS, trussed/armoured, 36" TSL's, pro comp 15x10 steelies.
YOTA666 is offline
Old 08-18-2009, 08:26 PM   #2 (permalink)
islandboyjt20's Avatar
is your joints in good shape?
__________________
WAIKANE...
I BULIT...
islandboyjt20 is offline
Old 08-18-2009, 10:23 PM   #3 (permalink)
4Crawler's Avatar
Unless you rotated the knuckles on the front axle, your pinion angle is way off the the CV shaft (should be at 0 degrees for smooth operation):
- http://www.4crawler.com/4x4/CheapTri...n-Measurements
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-18-2009, 11:26 PM   #4 (permalink)
YOTA666's Avatar
This is what i did. http://www.4x4wire.com/toyota/tech/cvmod/
The shaft turns smooth as silk by hand... Once the vehicle is moving its a whole different story though.
__________________
YOTA666 is offline
Old 08-19-2009, 07:44 AM   #5 (permalink)
4Crawler's Avatar
Read the page I posted a like to above. The u-joint on the bottom (pinion) end of the shaft will only run smooth if it is at 0 degrees operating angle. You need to do something like this to fix it:
http://www.4x4wire.com/toyota/tech/rotated_housing/
Or live with it and leave the hubs unlocked until you need 4WD.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-19-2009, 07:52 AM   #6 (permalink)
ocdropzone's Avatar
who did the the lengthening? Crappy job is gonna give you crappy vibration. Also if you took out too much material from one side. Long slip joint?
pics of shaft?
4crawler is usually dead on for this stuff...
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is offline
Old 08-19-2009, 02:11 PM   #7 (permalink)
YOTA666's Avatar
oh i thought the u joint on the bottom was fine, i thought it was all in my cv joint on top. Thanks for the link.
I did the lengthening myself, basically just cut it in half and got some tubing with with the same inner diameter as the outer diameter of the shaft, then welded er up lol...
ill try and get a pic of it for you guys asap.
__________________
YOTA666 is offline
Old 08-19-2009, 02:27 PM   #8 (permalink)
YOTA666's Avatar
__________________
YOTA666 is offline
Old 08-19-2009, 03:27 PM   #9 (permalink)
Do you have a high pinion front? I have the same problem but I have a single joint on each end and a low pinion. you may want to add a long slip on there too you are going to have problems with it coming apart.
__________________
93 2dr 4runner "overland build"
www.overlandcanada.com
89 Supra Built 2jz swap,T67 DBB and a Vipec V88.
Wheelingnoob is offline
Old 08-19-2009, 03:41 PM   #10 (permalink)
Plumbrbob's Avatar
I made mine longer too keeping the stock slip its a bad idea make sure is doesnt almost fall out at full droop bet it will and if it gets binded up cause it "almost slips out" bad things will happen
it looks like the DS u joints are phased but check again that will make it do weird vibration type things
also chekc the double cadigan joint the center peice gets worn out and if it breaks in 4wd it will smack your tranny UH OH
I made mine out of reciever stock cant do any better than 15-20mph but it does not shake it is noisy though and I have unlimited slip also if I smack it on a rock my cheap duralast lifetime u-joints break. u-joints are an easy trail fix plus i get a new one for free when i get back into town.
__________________
79 YotA ThinG
Mods: http://www.yotatech.com/blogs/plumbr...list-mods.html
Plumbrbob is offline
Old 08-19-2009, 03:42 PM   #11 (permalink)
Plumbrbob's Avatar
oh yea i ditched the double dumb joint and used a single out of a rear ds its much better has more degreeage
__________________
79 YotA ThinG
Old 08-19-2009, 03:44 PM   #12 (permalink)
Plumbrbob's Avatar
it really kinda looks like your drive shaft is not phased to each other maybe a few splines off hard to tell for sure from your picture
__________________
79 YotA ThinG
Old 08-19-2009, 05:40 PM   #13 (permalink)
YOTA666's Avatar
what does phased mean?
One thing i was thinking about doing is to find a rear driveshaft and cut it down to fit the front, then it would have regular U joints on both sides. Do you guys think that would work? Im just not sure if it will bolt up to the flanges...
Thanks for the input guys!
__________________
YOTA666 is offline
Old 08-19-2009, 06:12 PM   #14 (permalink)
4Crawler's Avatar
Phasing really only applies to a single-cardan shaft (i.e lining up the u-joints):
- http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
On a CV shaft, not important, although I still try and line up the u-joint bearings with the lower CV joint bearings.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-19-2009, 08:29 PM   #15 (permalink)
Plumbrbob's Avatar
yup thats it X2
I wrench better than type thanks 4crawler
hey did you check to see if you have crazy play between the u-joints onthat double dumb joint? I bet thats the vibro vermin givin ya greif
__________________
79 YotA ThinG
Old 08-20-2009, 11:09 AM   #16 (permalink)
That's what I have/did, I put the double cardon on the rear and the single on the front. you will also have the swap the Tcase flanges at the same time or get a TG adapter flange.
I have the single cardon in the front of my 4runner with a 3" sas and 12" slip. I also have crazy vibrations when in 4WD. If I go over 20kms/hr it starts to smooth out a bit but still not very good. I'm going to try and hi-pinion next to try and reduce the angle I have on the front.
__________________
Old 08-21-2009, 01:15 AM   #17 (permalink)
SLOWBOOST's Avatar
i'd ditch the cv setup if i was you. your pinion really needs to be facing the t-case flange for it to work correctly. rear shaft will work, you'll have to redrill the flanges to bolt it up and figure out some slip.
i made a square shaft. under $50, no vibes, used rear u joints and re-drilled the flanges. works awesome even up to speed.
__________________
91 sr5 38s and sas, 5 spd swap...over 300K!
SLOWBOOST is offline
Old 08-21-2009, 05:11 AM   #18 (permalink)
ocdropzone's Avatar
Quote:
yep-u-joints acting like a fuse are cheaper and easier to fix than a R&P
OP-you definitely need some more slip travel than stock:
not mine but why you want to make sure your stuff works
probably won't happen to you but thought it was a cool picture
__________________
~Robb
TREKKER Forum
Old 08-21-2009, 10:08 AM   #19 (permalink)
YOTA666's Avatar
That is some pretty gnarly carnage haha...
I think you guys are right about the phasing, it looks like it is about 1 tooth off, dunno if that will make a drifference but ill correct that and try it.
If not I guess im gonna build a square driveshaft. I might need to anyways to correct the slip joint problem. The long travel slip joint kit is like $300 up here lol, and i already gotta get one for the back either way...
Where did you guys get the ujoint setup to weld on the square stock for the square driveshaft? Did you just cut them off of old driveshafts?
Thanks!
__________________
YOTA666 is offline
Old 08-21-2009, 03:04 PM   #20 (permalink)
SLOWBOOST's Avatar
yes just use the old ones off a rear shaft. the stock slip yoke is the quick part to fit in the 2" square tube, the yoke for the 2.5" requires a little more work.
you can do some searching and find alot of links for it.
__________________
Tags
4runner, angle, blocks, drive, driveshaft, flange, front, homemade, joint, lowering, pinion, problem, s10, shaft, single, swap, tacoma, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
