Post up your SAS pics and specs
Old 12-22-2010, 08:19 PM
  #81
85excab's Avatar
and one im still working on, its a 1990 4runner with 3.0/r150/duals and 4.10 gears
front leafs are a mix of rears and 3" procomps
rear leafs are 4" cj7 rear leafs and it is on 35" cooper sst's
i will be swappin a vortec 4.3/th350 next mont too.
here is the before on 31" coopers
Old 12-22-2010, 08:25 PM
  #82
85excab's Avatar
my old 1991 4runner with a 22re/w56/duals and 4.30 gears on 35" boggers
4" procomp chevy leafs front and rear
Old 12-22-2010, 08:32 PM
  #83
85excab's Avatar
a 1987 4runner i built with a 22re/w56 duals with 5.29 gears on 35's
3.5" alcans in front, 63" chevies in rear
Old 12-22-2010, 08:37 PM
  #84
85excab's Avatar
1986 pickup with a 22rte/r151f/duals
4.56 gears on 1 tons with 42" iroks
tg hd5" front springs, 63" chevy rear leafs
Old 12-22-2010, 08:50 PM
  #85
4Ruster's Avatar
here is what im currently running.... Sky hanger,9000's at all corners,44044's up front,TG 5" rear leafs,37" Iroks.
Old 12-22-2010, 09:47 PM
  #86
muddpigg's Avatar
Originally Posted by 80yota4x4
Here is my 98 taco clipped 4runner SAS and rear leaf swap. I used a FJ60 front axle w/aussie locker, taco elocker rear, 4.88s, marlin 4" springs for the 79-85 minitrucks, marlin dual gear drive cases passenger side drop. I wanted to keep it all toyota.
Are you serious! This 4rnr is bad azz! I love it.
Old 12-22-2010, 09:51 PM
  #87
muddpigg's Avatar
Originally Posted by DanKRunner
Dual Marlins, with 4.7 rear case, 5 speed, 3.4, Dana 60 front GM 14 Bolt rear. Full hydro steer, 3link front 4 link rear. All built by me in the back of a barn.
Damn.... Nice flex.
Old 12-22-2010, 10:13 PM
  #88
muddpigg's Avatar
I just stopped posting damn... So many sweet rigs makes my '86 SAS look tiny. Really like the link setup on one tons.
I really don't have to many pics of my rig since the SAS. I have a bit of rear sag, the build was done in stages and set the rear up when I still had IFS but was installing dual case so wanted to get the pinion turned and a descent height, have some longer shacles and maybe some small blocks. FROR front spring hanger Allpro 4" spring all around. 33's
I'm happy with the height, can fit 35's just don't know if I want to be any taller. The 33's have severed me well. Perhaps step up to a 17" rim to get a 34" tire, just can't decide if having a bigger rim is worth the trade off of not being able to air down as low and being a little narrower.
Old 12-23-2010, 05:01 AM
  #89
blake.nemitz's Avatar
if you go with a trail gear kit with a v6 keep your rear leaves. i added a leaf in my pack 3 down with a cut down main from a rear pack to hold the extra weight, i no longer hit the stops all the time and i handles a hunder times better and doesnt hinder flex at all
Old 01-08-2011, 09:18 AM
  #90
arizonatea's Avatar
That's the height I'm going for.Nice and low.Did you just use the All Pro kit per instructions or did you modify it to be that low?I see your hanger is custom,like it alot.Any binding issues with the steering components?
Sorry for all the questions, not many guys stay low when they sas so I have lots of questions.
Old 01-08-2011, 12:13 PM
  #91
muddpigg's Avatar
The hanger and shackles is from Front Range offroad, Brian has the lowest hanger on the market. Wound up using TG frame tubes so I could use a jig for cutting holes in the frame. The springs and rotors are Allpro. With Ball Gussets on the front axle from Marlin, bumpstops and other misc small things from TG. Cost was alittle more than Trail Gear's kit but I didn't like the stance of TG's finished product. I still have 3.5" uptravel. No issue with steering components binding.
Old 01-11-2011, 10:46 AM
  #92
cblackard's Avatar
Originally Posted by 85excab
1990 4runner with a 3rz/w56/dual/4.7's
4.88 gears 35" bfg km2's
rear/alcan leafs in front
3.5" rancho leafs in rear
37" mtr's in this pic
There is a truck in that pic? Where, I don't see it....LOL
WOW!!!
Old 01-15-2011, 07:41 PM
  #93
camo31_10.50's Avatar
you should check out the "hot women of yotatech" thread
Old 06-01-2011, 09:37 AM
  #94
Blue Steel's Avatar
subscribed. hopefully i'll be here in a few months!!!
Old 06-14-2011, 09:18 PM
  #95
Sin
Sin's Avatar
Originally Posted by toyospearo
Thats a tough act to follow right there..
Heres mine.
TG kit front 2.5" domestic spring stock done by a local blacksmith. Rear OME, TG 3" Shackles. 83 SA on 33's now. Sits EXACTLY where I want it
DAMN nice truck!
Old 06-15-2011, 06:15 AM
  #96
agreed
Old 08-05-2011, 11:11 PM
  #97
vang_22re's Avatar
subscribed!!!!!!!!!!!! keep those pics coming!!
Old 09-22-2011, 01:28 AM
  #98
NorthBendneck's Avatar
1991 dlx ext cab
3,4 v6 swap
85 front axle
disk brakes
bobbed bed
107,xxx original miles
hids
mexi tailights haha
Before:
after:
Old 09-23-2011, 07:36 PM
  #99
radshingo's Avatar
That is the nicest Yota flatbed I've ever seen. It's so clean and i'm lovin the color.
Old 09-23-2011, 08:37 PM
  #100
westjohns yota's Avatar
stop the madness im getting ideas that are makeing my wallet hurt! hahah one day i shall have sas.....
Quick Reply: Post up your SAS pics and specs
