Plan for sasing the runner. - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-18-2009, 11:39 AM   #1 (permalink)
crolison's Avatar
How does this plan sound to you for sas'ing a third gen runner?
Running Gear:
fj80 elocked front axle with 5.29's
Swap over to a gear driven tcase with 4.7 gears
Modified links in the rear with fj80 coils
My plan would be to use the stock radius arm set up off of an fj80, with using coils and shocks., and using an jf80 or fj60 steering box. Get some new coil buckets from toyota and some link brackets for the frame for the radius arms.
This has been done before on an fj40, the sema taco this year did this too.
http://www.wowway.com/~rballard2820/...ingwriteup.htm
I really don't like the ideas of leafs and wanted to keep it simple and run coils front and rear. Figured all I would have to do is basically replicate the dimensions on the fj80 frame and mounting points and then do some tests to gain how i should limit the axle and what springs i should use in it.
How does this sound to you guys?
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns
armor
locked
lifted
heavy SOB
broken front and rear swaybars
My Profile..
crolison is offline
Old 02-18-2009, 11:45 AM   #2 (permalink)
DC Hoerunner's Avatar
sounds like fun... are you going to be lifting it any or just stick with the two inches the rear coils will give
__________________
91' 4runner incoming 302 and sas in front and cruiser coils and chop in rear.
03' Chevy 2500HD 8.1L Vortec
89' Ford Mustang Lx parting out
93' mustang donor for hoerunner
2 Honda preludes caged and set for short leg rally
Quote:
Originally Posted by ozziesironmanoffroad View Post
ii doonnt wan nnt to drive, cuuz i doonmt want to kill nemone
DC Hoerunner is offline
Old 02-18-2009, 11:49 AM   #3 (permalink)
crolison's Avatar
Quote:
It all depends on how it sits with different springs in the front, but basically I would lifting the rear a couple inches. Probably at first I'll run 33's, then move up to 35-37's. I'll tub the firewall and rear to fit the bigger tires with running the least amount of lift.
I am just in the planning stages now, just trying to find out if I have missed anything.
For the tcase I can either run my w59 and an adapter or run a w56 and don't have to deal with the adapter.
List of things so far:
FJ80 axle, radius arms, upper coils buckets, steering box, (panhard and steering I will fabricate)
Frame reinforcement plates
radius arm and panhard brackets
w59 to gear driven tcase adapter
26 spline to 23or21 spline adapter
topshift 4.7 case
twinstick
tcase crossmember and skid and other assorted skids
steering lines
5.29's front and rear
brake line parts
square front d-shaft
assorted plating and steel to beef up components
Down the road:
tub the firewall
35-37's
dual cases
__________________
armor
locked
lifted
heavy SOB
My Profile..
crolison is offline
Old 02-18-2009, 01:08 PM   #4 (permalink)
Spinnbait's Avatar
Have you thought about airshocks for the front? They are relatively inexpensive and very tunable. It would provide more space for gusseting and linking options...
__________________
Cannondale Rush 3 carbon (my new baby)
Surly 1x1 (my D/D)
1973 Schwinn cruiser (my shop bike)
Spinnbait is offline
Old 02-18-2009, 03:30 PM   #5 (permalink)
crolison's Avatar
Quote:
I think i'd be too heavy for airshocks and overheat them.
I am not really worried about gusseting the front axle, and with the radius arm set up i dont have to really worry about room because I just have the radius arms and the panhard that come off of the axle.
__________________
armor
locked
lifted
heavy SOB
My Profile..
crolison is offline
Old 02-18-2009, 08:13 PM   #6 (permalink)
wyorunner's Avatar
what are you going to be doing with the current third member? cuz i might be interested if your going to sell it.
__________________
02 4runner Sport 4.88 LOCKED
3" OME lift + 1" 4crawler BL, Tundra Brake Upgrade,
Deckplate Mod + ISR Mod, LED Gauge cluster and temp control, 285/75R16 Goodyear Wrangler MTR, H/O ARB compressor,
Needing install
HID Retro
My Profile
wyorunner is offline
Old 02-18-2009, 10:20 PM   #7 (permalink)
Spinnbait's Avatar
I will let you know how mine turns out. I had to consider space in my decision to run airshocks (fox 2.0) because I'm running an 8".
__________________
Surly 1x1 (my D/D)
Old 02-19-2009, 07:55 AM   #8 (permalink)
crolison's Avatar
Quote:
I'd be selling my whole front set up, arb 4.88's, manual hub set up, budbuilt.
But thats when I start chopping which probably won't be until 2010-2011. Just in the planning process now, and gonna start collecting parts this summer. Then I have to move out of my apartment and move into a house with a garage so I can work on it after work, etc.
__________________
armor
locked
lifted
heavy SOB
My Profile..
crolison is offline
Old 02-20-2009, 01:11 AM   #9 (permalink)
wyorunner's Avatar
you should go ahead and start chopping now , sos i can buy your front set up and put it on mine then ill be double locked and ready to rock. and i also wouldnt have to pull the third to get new gears put in. it would already be done, eh oh well.
__________________
Needing install
HID Retro
My Profile
Old 03-03-2009, 08:46 AM   #10 (permalink)
Offie's Avatar
Please Update when you get going, I got my own plans about SAS'ing with coils in the near future.
Offie is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
what do you think of this plan yotalover96 95.5-2004 Tacomas & 96-2002 4Runners 19 12-01-2008 09:41 AM
Need a game plan Djlarroc 86-95 Trucks & 4Runners 6 10-22-2007 02:01 PM
I've got a new cheaper plan! ravencr The Fab Shop 254 12-14-2005 03:27 PM
Cost of SASing an 02 Runner shazaam The Fab Shop 187 07-07-2004 08:09 AM
A man with a plan. Dr. Zhivago Off Topic Talk 9 02-20-2004 11:26 PM
2009 InternetBrands, Inc.
