Pic of my SAS, but another question a/b driveshaft length - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-17-2009, 07:47 AM   #1 (permalink)
I appreciate all of the help, so here's a pic of what I have completed so far. I did have a question a/b the rear driveshaft, I am putting on a Trail Gear 5" rear lift, but I am also putting on a t-case doubler. I want to run my stock rear u-joint style driveshaft (let me know if you think this is a problem), but I need to determine the angle. I know the tcase and third member need to be at the same angle, but I want to put my drive shaft in and drive my truck to another shop (to flex it on a fork lift) before I put the doubler in. What angle should I put the third without the doubler now so as not to have vibrations when the rear shaft gets shortened 6.5" for the doubler? Thanks for the help!
fordmgt1 is offline
Old 05-17-2009, 09:33 AM   #2 (permalink)
cubuff4runner's Avatar
Why don't you just measure back the 6.5" + the 2" or so for the ujoint from the center of the transfer case flange. There is the point your pinion should be pointing at.
__________________
96' 4Runner
SAS - 87 Waggy 44 Aussie Locker & Alloy Shafts, 63" Chevy Rear Leaf Conversion, Inchworm Dual Crawler, PSC Hydro Assist, FROR Full Floater
Rockfrogs
Pics
cubuff4runner is offline
Old 05-17-2009, 09:43 AM   #3 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Just don't over rotate the rear axle or you will have worse problems.
If you are doing things all at once now, install your dual cases FIRST, then the rear lift and point the rear pinion at the actual spot.
Your tcase and your 3rd member at the same angle?
Run a double cardan on the rear d-shaft and you will thank yourself later.
waskillywabbit is offline
Old 05-17-2009, 10:13 AM   #4 (permalink)
[quote=waskillywabbit;51142024]
QUOTE]
I was trying to get away with running u-joints, and I think its right for the angle on the tcase and third member to be in parallel planes. Now, if you think there will be problems, I have a spare front drive shaft with a double cardan that I could take to a drive shaft shop and have then weld and balance it I suppose. I just trying to save money without cutting corners if thats possible. I didn't know if the length would be short enough to warrant a double cardan on the rear.
fordmgt1 is offline
Old 05-17-2009, 12:11 PM   #5 (permalink)
TOYOTA 1's Avatar
i have a 5" allpro lift in the rear, stock pinion angles and d-shaft lengths ( with no cardan joint) work perfect (no vibration). the rear 3rd flange and the tcase flange are @ the same angle. if you just want to drive it before a doubler kit, the stock setup(d-shaft/pinion angle with a 5" lift works great.
not sure about the no cardan joint with the duals though.
__________________
91 Toyota "built not bought"
Quote:
Originally Posted by BigBluePile View Post
I just bought a Toyota and I don't have any tools or any kind of area to work on it with and I'm wanting to drop in a V8 and clear 38's but I don't have any money and do I need to lift this if so what kind of lift and what do you recommend also I'm not sure if all terrains will work in mud is there another kind I have some rims that should work but they came off a yugo so is the bolt pattern the same...
TOYOTA 1 is offline
Old 05-27-2009, 03:08 AM   #6 (permalink)
4xJedi's Avatar
I'm running TG 5" rears. I pointed the pinion at the tcase, welded my perches on and called it good. I later installed duals, shortened my shaft and it doesn't drive any different than before. No problems at all. I have a CV for the rear but never installed it, it's fine.
__________________
'86 Runner, 4"SAS, 5.29's, 30 spline Longs, locked frt/rr, dual cases w/4.7's, Twinstick, LCE header, K&N, Engnbldr cam, Can-Back, Armor by me.
4xJedi is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Driveshaft Length Question...Urgent! 881stGenRunner 86-95 Trucks & 4Runners 5 06-11-2008 10:25 AM
Driveshaft Length toyguy86 84-85 Trucks & 4Runners 4 06-27-2007 11:32 PM
Driveshaft Length toyguy86 86-95 Trucks & 4Runners 2 06-26-2007 03:10 PM
Driveshaft Length? 96 Taco MudMonkey 95.5-2004 Tacomas & 96-2002 4Runners 11 06-26-2006 04:06 AM
driveshaft length straightaxle85 95.5-2004 Tacomas & 96-2002 4Runners 2 10-02-2005 10:44 PM
2009 InternetBrands, Inc.
