Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Need Help With Sas?
well i got a 1976 landcrusier axle and when im gonna put the TG high steer arm on the knuckle i found out that the hole for the TG r not as narrow as the Landcrusier. But the LC axle already had a custom High steer on it too so i guess i might have to use the Custom high steer instead, but it doesn't have another hole for the cross arm from the steering box to the custom high steer. wat should i do? weld a bracket that has a hole for the cross or wat else?
| Sponsored Links |
#2 (permalink) |
Sponsoring Member
You have to swap the mini truck knuckles onto the LCA axle to use the mini truck stuff IIRC.
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab FOR SALE: 1987 4Runner GRAY FOR SALE: 1987 4Runner RED 6th Annual South East 4Runner Jamboree, May 22-25, 2009 |
#3 (permalink) |
oh ok kool then i might as well do that then buy another 79-85 axle. Thanks u very much
#4 (permalink) |
as wabbit said you'll have to swap the mini-truck knuckles onto the lc axle to use the trail gear highsteer. unless you already have the mini-truck knuckles you might look at trail gear's six shooter knuckles.
__________________
2000 4Runner Limited 4x4 "TRD". Blown, etc. 1988 Trail Truck. SAS, Dual Cases, Exoed, Aluminum Trail-Ready Beadlocks, 37" Boggers, and Extreme Rock Rash. 2008 Camry LE. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| To SAS or not to SAS? That is the question | DeepSeaSnake | Solid Axle Swaps, All Years | 1 | 05-15-2008 06:16 PM |
| sas | tickt9842 | 93-98 T100s | 0 | 06-28-2007 09:38 PM |
| Sas? | Stomis | FJ Cruiser | 0 | 02-28-2007 09:02 AM |
| sas | CraZyRunner | 86-95 Trucks & 4Runners | 18 | 02-19-2006 08:28 PM |
| More sas ?s | jeremy | The Fab Shop | 42 | 01-09-2004 04:09 PM |
