Moving axle forward - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-07-2009, 11:59 AM   #1 (permalink)
YOTA666's Avatar
Moving axle forward
Hey guys, im about to start on my first SAS and I was just wondering what is involved in moving the axle forward?
Is it just a matter of moving the hanger forward and moving the rear shackle mounts forward as well?
I've got a trailgear 5" HD sas kit so I dont wanna go forward so much that I can't use the steering system that comes with it.
thanks!
__________________
88 4RUNNER- 3.slow, Centerforce clutch, 2 inch body lift, s10 lowering blocks converted to lift blocks, Trail Mart SAS, trussed/armoured, 36" TSL's, pro comp 15x10 steelies.
YOTA666 is offline
Old 06-08-2009, 10:05 PM   #2 (permalink)
Toyotero's Avatar
I've not done a SAS yet, but from what I've seen, you'll probably have to move your steering box forward so that the drag link and tie rod don't hit.. or worse the pitman and tie rod...
Alternatively, you can get a flat pitman arm that might help (Cruiser pitman maybe) or a shorter one.. of course, then you'll have 3 pt turns at every corner...
Or who knows, with 5" springs, draglink/tierod, clearance might not be a problem depending on your driver's side articulation when compressed.
Don't forget to check the slip yoke on the drive shaft... 2" forward on the axle will required almost 2" on the drive shaft to keep the same yoke position you have now.
- Toyotero.
__________________
- El Toyotero
"I fly by ya in a foreign whip!"
FREE Toyota Factory Service Manuals ---> FSMs
Toyotero is offline
Old 06-09-2009, 06:53 AM   #3 (permalink)
4Crawler's Avatar
Right off the bat, those springs will move your axle forward 2" as compared to using a stock front leaf spring. To go farther, you'll move the front hanger forward on the frame, I think most of the kits offer stock and 1" forward mounting options. Then you'll probably need to move your steering box forward on the frame as far as it can go.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 06-09-2009, 04:51 PM   #4 (permalink)
YOTA666's Avatar
alright i think im just gonna do it according to the instructions for the first time lol. Thanks for the help!
__________________
YOTA666 is offline
Old 06-09-2009, 05:05 PM   #5 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
At the bottom of my sig is a link to my build threads the 4.3 build on the last or second to last page tells you and shows you how to do this. Gotta search this stuff cause the info is out there
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 06-10-2009, 01:25 AM   #6 (permalink)
4RunnerKid's Avatar
Send a message via AIM to 4RunnerKid Send a message via MSN to 4RunnerKid Send a message via Yahoo to 4RunnerKid
you can also re-drill the perches for another 1.5" or so... i almost guarantee you'll have to move your steering box though
__________________
-Mikey-
1993 4Runner ~ TG HD/RUF front | All Pro rear | 37" Krawlers | Marlin UM06s | 12" King 2.5s | 2" air bumps | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | 4xInnovations cage | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | LED rock lights | PIAA superwhites | stereo
Polygoats 4-Wheel Drive Club
Poly Performance
4RunnerKid is offline
Tags
1, 11, axle, blocks, forward, front, inch, leaf, lift, move, moving, pickup, rear, springs, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
foward positioning on my SAS with 35's/set axle forward/backspacing recomendations??? jpmountainboy 86-95 Trucks & 4Runners 10 02-17-2009 08:10 PM
best way to move front axle forward? rob84runner 84-85 Trucks & 4Runners 11 04-21-2008 05:35 PM
Moving the axle 4 inches ahead. premirrider The Fab Shop 12 02-19-2008 11:24 PM
For V6, moving shackles 1" forward or more...problem? chimmike Solid Axle Swaps, All Years 8 04-16-2007 06:10 PM
Do Not Forward Woodbert Off Topic Talk 8 06-23-2003 05:47 AM
2009 InternetBrands, Inc.
