Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
I'm waiting on some parts to start rebuilding my 1984 solid axle. I'm not sure if I need the knuckle ball gusset kit.
![]() The truck will see mud and light trails. It will also be used as a DD. Would it just be a good idea seeing on how cheap the kit is? Thanks. |
| Sponsored Links |
#2 (permalink) |
Sponsoring Member
If the axle is going to bend...it is going to bend at the knuckle ball.
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab FOR SALE: 1987 4Runner GRAY FOR SALE: 1987 4Runner RED 6th Annual South East 4Runner Jamboree, May 22-25, 2009 |
#3 (permalink) |
Staff
Big fat tires and spacers etc put a lot more stress on that part.
If you have it apart anyway, why not?
__________________
David TLCA 14788 71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap. 76 Landcruiser FJ-40 project/parts (haven't decided) |
#4 (permalink) |
That's what I was thinking. Now I need to cut the factory lower shock mounts off. I'm ordering these from wabfab because I don't like the lower shock mounting on marlin's part.
<edit> I just ordered them through Paypal. Can I use the dual transfer case crossmember with a single case? Do they make a single case crossmember like the one in the picture? ![]() Thanks again. Last edited by 89dlx : 07-27-2008 at 07:34 AM. |
#5 (permalink) |
YES you need them......also cap your steering stops or weld a nut inside
especially if you ever want to jump your truck.... I prefer the stock "double shear" design like trail gear over most of the other kits. I would also recommend making your own kit. Here's one I made for a SAS I was working on. We used a cheapie shock mount and modified it for the top. VERY IMPORTANT: make sure you install (or partially install) the knuckle and turn lock to lock to make sure the gussets clear. I know that Marlins kit requires quite a bit of trimming and its a pain in the ass to fix after you've welded it in all the way.. Use a small piece of round tube. This also allows the gusset to slide over a rock if it makes contact. ![]() ![]() ![]() ![]()
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. I'm the yota junk man......PM me for ALL your parts needs NEW or USED Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#6 (permalink) |
I will be capping the steering stops (they look too weak even for normal driving). I like the tube used as a gusset, someone should sell those (hint, hint). I'm having a friend at work do some of the welding, I could do everything else, except weld. I should look into taking a welding class.
#7 (permalink) |
yes
__________________
-Mikey- 1993 4Runner ~ TG 5" HD/RUF front | All Pro ~4" rear | 37" Krawlers | bomb-proof front housing | Marlin UM06s | 12" Fox 2.0s | Aussie front | Lock-Right rear | 5-speed swap | TG 4.7s | 5.29s | bumpers | sliders | t-case skid | K&N intake | Flowmaster 40 | Optima red top | clear lenses | PIAA 1400s | KCs | LED rock lights | Midland CB | Firestik 4' antenna | PIAA superwhites | stereo Polygoats 4-Wheel Drive Club -> check it yo |
#8 (permalink) |
I've the Trail-Gear ones too:
![]() ![]() Also put the Rock Rings ![]() And backing plate eliminators: ![]() David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write... |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Need a Knuckle(sandwich) | BLKNBLU | Arizona | 12 | 06-17-2008 01:06 PM |
| Knuckle rebuild help. | Popak2 | 84-85 Trucks & 4Runners | 10 | 01-30-2008 01:27 PM |
| '81 Knuckle/Pitman arm Ball Stud Flip | OldManYota | Pre 84 Trucks | 9 | 01-23-2008 07:29 PM |
| Knuckle implants | 4-RUNNIN' FREAK | Off Topic Talk | 17 | 05-08-2006 12:53 PM |
| How to get upper ball joint off steering knuckle! | 98LimitedCustomized | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 12-27-2004 05:05 PM |
