YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-07-2008, 07:19 PM   #1 (permalink)
TOYOTA 1's Avatar
high pinion 3rd member?
so.. i have a few questions about putting a high pinion 3rd member into a stock "front" housing. the reason for this being i need better "driveline angle" to get rid of my vibration caused by having a single t-case and a low pinion 3rd and 5" of lift. here are a few questions i need help with, any help would be great.
Thanks, Mike
1. will a high pinion 3rd fix my problem?
2. what kind of housing modifacation if any? will i need to do to fit a high pinion 3rd into a stock housing?
3. how much money should a stock a high pinion 3rd member cost?
4. would i have to get new/different axels to accomidate a high pinion 3rd?
i cant stand this vibration any more!
any help would be great thanks!
TOYOTA 1 is offline
Sponsored Links
To remove this ad, register today!
Old 03-07-2008, 07:29 PM   #2 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
It may help some but still youll get vibrations. Do you have a double cardon cv in the front shaft? What is the year/ model? Is it a solid axle or IFS?
As for new axleshafts which I think you mean NO
The 8" thirds will fit in any 8"axle granted if you get an elocker you will need to modify the housing a bit to accomidate.
The high pinion help also with ground clearence but its a small gain. Dont ever put one in the rear unless its a ford 9". Ide say check to see if your front driveline is CV or not and if not change it too and the vibrations should stop some
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 03-07-2008, 07:35 PM   #3 (permalink)
TOYOTA 1's Avatar
ya its a cv driveline, i had a single cardan drive line in there before and it was worse so i swapped it for the cv style, that helped but its still pretty bad.
as for my truck it is a 91 standard cab shortbed sased 5 inches of lift
stock gears
TOYOTA 1 is offline
Old 03-07-2008, 07:42 PM   #4 (permalink)
Sorry dude not much is going to help with a big lift, tires and speed. Keep the speed down (even if you are) and since you built it to wheel it sounds like your gonna have to live with the ride in this case. Hell driving on rocks and through mud cant be much worse can it??? The high pinion may help a bit but youll always have a vibration in the front
__________________
Old 03-07-2008, 07:48 PM   #5 (permalink)
TOYOTA 1's Avatar
Quote:
the funny thing is it dont vibrate at all unless hubs are in and im in 4high or 4lo. but if hubs r in and im in 2 wheel drive i can do 60 and its smooth but as soon as i engage both it starts and it vibrates pretty bad at like 10 miles per hour
so cutting and turning knuckels to fix the vibration is my only option?
TOYOTA 1 is offline
Old 03-07-2008, 10:02 PM   #6 (permalink)
AxleIke's Avatar
Strange its not in 2wd hubs locked.
Cut and turn would do it.
You may be able to shim it a little.
4crawler.com has shims.
http://4crawler.com/4x4/ForSale/Shims.shtml
Beware the death wobble though. If you get your caster too far out, you could have issues. Roger should be able to help you a little.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 03-07-2008, 10:06 PM   #7 (permalink)
neoworm0's Avatar
duals help alot. And hey why not. what a great excuse to get duals. And hey, if it doesn't solve the problem, well damn you have duals.
I can do about 40-50mph with mine.
__________________
1995 Toyota PU SR5 V6, A few mods.
neoworm0 is offline
Old 03-07-2008, 10:38 PM   #8 (permalink)
TOYOTA 1's Avatar
Quote:
thanks ike, i already have 3 degree shims can i go more with out getting the deth wobble? yes its wierd i can also put my front end at max droop and it stil spins smooth, but anything over like 10mph with 4wheeldrive engaged it gets pretty bad . so what do u guys think would b the best option.
1.cut and turn?
2. high pinion diff?
3. double t-cases?
TOYOTA 1 is offline
Old 03-07-2008, 10:45 PM   #9 (permalink)
cutboggers's Avatar
whatcha got a dune racer or sumthin?
cutboggers is offline
Old 03-07-2008, 10:47 PM   #10 (permalink)
TOYOTA 1's Avatar
haha no i use my tacoma for that!
TOYOTA 1 is offline
Old 03-07-2008, 11:10 PM   #11 (permalink)
AxleIke's Avatar
Quote:
1.cut and turn?
3. double t-cases?
Cut and turn is a bitch dude. I've watched a guy I'd consider to be a master fabricator do his 40. Took FOREVER. Built jigs, and tig welded the beast. Its dead on, but whoo. To me, thats the last resort.
Here's my advice:
First of all, duals are awesome. I'm in the middle of my dual install, but I've watched enough in action to know that you'll be blown away.
Second, HP diffs are stronger, and you can get it with an elocker. Hunt junk yards for FJ-80's. The fronts with lockers are HP set up, and, if you get it right, you could have it for as little as 300 bucks, needing only a refurbish.
If you do both of those, which will benefit you greatly regardless of the vibration, and, hopefully, will solve your issues.
If you STILL have the vibration, then start shimming more. The amount of shim you can do varies from axle to axle. If you can't get it to go away without deathwobble, cut and turn.
Anyway, just they way I'd look at it.
__________________
IFS SAS
AxleIke is offline
Old 03-07-2008, 11:18 PM   #12 (permalink)
TOYOTA 1's Avatar
Here's my advice:
thanks ike, im looking at it the same way. i think il start with a lil more shiming. and i will be looking for a junkyard jewel "highpinion 3rd". ill shim more tomarrow then post the results! wish me luck
TOYOTA 1 is offline
Old 03-08-2008, 01:35 AM   #13 (permalink)
YeloSub7's Avatar
Send a message via AIM to YeloSub7
FJ-80 diffs are for 8"? I thought those were bigger axles? Shows what I know
__________________
-Jake
1990 4Runner <> 1990 Toyota 4Runner-22RE-5 speed-TG 3" front/4" rear-33's-4.88's-rear LSD-front TruTrac-MC Rear Bumper-TG DOM Sliders!
SAS Build-Up
Old Rigs:
'85 4Runner (RIP)
'95 4Runner (sold)
YeloSub7 is offline
Old 03-08-2008, 06:53 AM   #14 (permalink)
AxleIke's Avatar
Good luck man!!! Hope it gets solved.
Quote:
Front diffs are 8. Rears are 8.875.
__________________
IFS SAS
AxleIke is offline
Old 03-08-2008, 12:36 PM   #15 (permalink)
cutboggers's Avatar
http://www.4crawler.com/4x4/4R_TechInfo.shtml
damn good info
Old 03-09-2008, 12:56 PM   #16 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
I've a front HP 4.88 diff out of a Toyota LJ-70. It's bolt-on.
Helped a lot with the front DS angle. This is with the suspension extended:
With the truck on the ground the angle is good, I had no vibrations but my front DS is balanced too.
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write...
Blizzard is offline
Old 03-09-2008, 01:32 PM   #17 (permalink)
TOYOTA 1's Avatar
David
ya thats what im lookin for got any 4 sale? lol, how much did the pinion actually go up? that measurement would be helpful to see if i need anything more than just a high pinion! thanks for your input blizzard!
__________________
91 Toyota stdrd cab short bed 22re 5spd. sas'ed, Yukon 5:29's. 3.5" tuff country e-z ride springs in the front. 5" allpro long travels in the rear. pro comp es 9000 shocks, 12" tg long spline front d shaft. k&n, 35x10.50x15 boggers. cobra cb/ashtray mod, 3' fire stick. etc.
2000 Toyota Tacoma xtra cab sr5, 3"revtek,285/70/17 coopers stt, clear tails, injen short ram intake, obx header, flow master, etc.
2001 Toyota Camry, the girlfriends,
www.22re.com
TOYOTA 1 is offline
Old 03-09-2008, 05:51 PM   #18 (permalink)
bigarms23's Avatar
just cut and rotate the axle for a better driveshaft angle cut it at both knuckles set your castor and reweld the knuckles back on and save the 1000 for the hp
__________________
1988sr5v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits
1988sr5v6 4runner with a 4inch allpro longtravel sas with detroit rear a ls in front and 33s
1985 sr5 4runner 8inch lift 39.5 boggers 529s detroits front and rear and triple transfer cases with a final crawl ratio of 2828to 1(sold)
bigarms23 is offline
Old 03-09-2008, 09:00 PM   #19 (permalink)
TOYOTA 1's Avatar
Quote:
ya it sounds easy but i no that it is above my head, i mean i can weld ok, and ive been known to turn a wrench or 2, but im making "cutting and turning" my last resort! and im hoping to find one for cheaper than $1000!
but thanks for your advice bigarms.
__________________
www.22re.com
TOYOTA 1 is offline
