Front driveshaft pinion angle - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-14-2009, 08:29 PM   #1 (permalink)
dirtbike5051's Avatar
I have completed my SAS and went to get a driveshaft made and they said the angle is at max with the truck sitting level. I have no clue what to do now..... The SAS is from All-Pro and it is the 6 inch lift. The springs have settled by now but still the angle is too great. Do I need to rotate my whole axle and spindles? or can I shim it at about 4 degrees and wish it luck?
dirtbike5051 is offline
Old 05-14-2009, 09:24 PM   #2 (permalink)
Ardent's Avatar
Dual t-cases would be another option. Otherwise, you might be able to shim it. but, IMO, it doesn't look that bad. Perhaps get another opinion?
edit:
Check this out too, last page. Rage's angle doesn't look any better than yours.
__________________
Nate
1993 3.0 Pickup - 4" lift, 33x10.50s BFG KM1s.
1995 4.5L FZJ80 - OME springs, Locked. Nitto Terra Graplers.
Sold:
1993 3.0 4Runner - Fj80 Coils, 1.5" BJ Spacers
1987 2.4 4Runner / SAS'd / Got it Running!/ Project truck...
Just bought my FZJ80...
Ardent is offline
Old 05-15-2009, 06:37 AM   #3 (permalink)
don't sweat it man, just get your driveshaft made or make a square one yourself and enjoy it.
__________________
I did have a 1990 X-cab P/U, 3.0 SAS'd w/ 3" Trail Gear IFS Eliminator Kit, 4" Trail Gear Rear Lift Kit, 35" KM2s, Yukon 4.88s, Locked Front and Rear w/ Aussie and a Detroit, Sliders, M-8000 Warn Winch, But I sold it
RaginYota is offline
Old 05-15-2009, 06:56 AM   #4 (permalink)
neoworm0's Avatar
Send a message via MSN to neoworm0
You can cut and turn your knuckles. You can try to find a High pinion third member. Go dual cases. Lower you tcase and tranny. Do a combination of all of the above.
Depends on funds and how anal you want to be about doing it right. I went with a High pinion third and dual cases and it worked out great. Getting that driveshaft angle as close to ideal as you can will save you headaches (and money) in the long run. Just my .02$ though. Lot's of people just run them with a huge amount of angle.
__________________
1995 Toyota PU SR5. 2000 3.4l V6 and a few other mods.
my album:
http://www.yotatech.com/album.php?albumid=101
my SAS:
http://picasaweb.google.com/areinhol...eat=directlink
www.overlandcanada.ca
www.alltracwagon.net
neoworm0 is offline
Old 05-15-2009, 07:19 AM   #5 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
waskillywabbit is offline
Old 05-15-2009, 03:51 PM   #6 (permalink)
cool, good input. Went to the driveshaft shop today and was told all the same things. I think I am going to get one made for now. After I get tired of it breaking I will resort to cut and rotate. Just Spent a lot on the SAS, lockers, and other parts on the truck that this will have to wait. I definately want to do it right eventually, I am anal like that since I work on Mercedes all day long. Plus the Mustang project is on the front burner this month.
Old 06-04-2009, 11:02 PM   #7 (permalink)
ScottyC's Avatar
Run a cut down rear shaft up front and ditch the CV shaft. The stock IFS CV is only good to 21*. The solid axle CVs are good to 35*. But, the rear non-CV style setups are good to 41*. You need the non-CV style. Especially with a V6.
You need to redrill your front flange on the Tcase side or buy a triple drilled flange. You'll also need a long travel slip joint on the shaft to keep it from over extending and pulling itself apart.
99% of driveshaft places don't use or have access to Toyota flanges and joints. They try to make a standard U.S. style joint and flange to work. Plain and simple is that those U.S. style setups don't have enough clearance to work. So, go grab a rear shaft out of a 4cyl truck or 4runner, and have it retubed along with the longer slip joint. Its the only "real" option you have. If they tell you all they have is a 1310 joint, then don't let them do it. Have them rebuild a Toyota shaft ONLY.
__________________
Scotty
http://www.addictedoffroad.com/
970-420-4198
Toyota Winch bumpers on SALE!
ScottyC is offline
Old 06-06-2009, 12:39 PM   #8 (permalink)
awesome advice because they were telling me to do the 1310 joint. I have already purchased a longer slip joint for it so I am already half way there. I am probably going to hit the junkyard this weekend for that shaft. I did request for toyota parts when I was at both the driveshaft shops and they both just laughed at me... kinda made me mad about the whole deal and that is why my truck is still sitting with one driveshaft. I will let yall know how it works out!
Old 06-06-2009, 05:16 PM   #9 (permalink)
YOTA666's Avatar
What do the longer slip joints come in?
__________________
88 4RUNNER- 3.slow, Centerforce clutch, 2 inch body lift, s10 lowering blocks converted to lift blocks, Trail Mart SAS, trussed/armoured, 36" TSL's, pro comp 15x10 steelies.
YOTA666 is offline
Old 06-06-2009, 07:12 PM   #10 (permalink)
got it as a kit from all-pro offroad
Old 06-07-2009, 09:18 AM   #11 (permalink)
ScottyC's Avatar
Quote:
All-Pro or Trail-Gear both have them.
__________________
Scotty
970-420-4198
ScottyC is offline
Old 06-07-2009, 09:58 AM   #12 (permalink)
tc
tc's Avatar
If you're having it retubed, ask for heavy wall. Mine are .090" and holding up really well.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 06-19-2009, 12:42 PM   #13 (permalink)
86Tankota's Avatar
Feelin your pain,check this out
I'm in the same boat with my rig, and heard the same things from the local drive line shop, i did some research and found this http://www.4x4wire.com/toyota/tech/cvmod/ haven' tried it yet but plan to.
__________________
I don't care about the "jeep" thing, as long as I get my mail on time.
86Tankota is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Pinion angle woes. (pic included) stabmasta 84-85 Trucks & 4Runners 8 05-22-2008 08:44 AM
Pinion angle + Shackle angle Island_Yota Pre 84 Trucks 1 07-28-2007 12:27 AM
Adjusting rear pinion angle on Gen II 4Runner FredTJ 86-95 Trucks & 4Runners 3 09-18-2006 10:01 PM
Changing pinion angle....SFA Marc P Offroad Tech 8 08-31-2006 12:28 PM
Front Driveshaft Angle....too high? 4RocRunner92 95.5-2004 Tacomas & 96-2002 4Runners 4 07-17-2005 12:23 AM
2009 InternetBrands, Inc.
