First SAS on 93 pickup...(questions)
Old 11-04-2014, 04:23 PM
USAF Proud's Avatar
here is the yota thats getting the sas before i start ordering parts i wanted to double check with you guys if im leaving anything out thats needed for the build, here is what i plan on ordering right now (all the parts are from trail gear) the donor axle is out of a 89 4runner i dont plan on bringing it to a shop because i have all the tools and welder in my garage to do all of the work
IFS Eliminator Kit 5"
Rear Lift 5"
Shackle Mount, Rear, Kit
Heavy Duty Driveline Kit (creaper or matsuba?)
Old 11-05-2014, 03:21 AM
BigBluePile's Avatar
What axle did you get out of an '89 4Runner?
Also, lots of threads on doin' the SAS
Old 11-05-2014, 03:27 AM
Old 11-05-2014, 04:51 AM
bump530's Avatar
Its going to be really tall with the 5" but if that's what you want then go for it. I haven't went back and looked, but doesn't the TG 5" rear lift kit come with the rear shackle mount?
Old 11-05-2014, 02:50 PM
USAF Proud's Avatar
BBP the axle is completely stock i have to convert the front diff over to 5.29s but i might just buy an assembled 3rd member and just drop it in, might put a Detroit locker in the rear and front not sure yet trying to keep it on somewhat of a budget
bump 530 i have no idea why they wouldn't include rear shackle mounts but right in the description info it says the kit does not include shackle mounts
Old 11-07-2014, 04:32 AM
Was the donor '89 already converted over to a SA?
Old 11-08-2014, 08:52 AM
USAF Proud's Avatar
BBP yeah the 89 was converted to a solid axle once he decided to swap, then he ran out of money for the rest of the build also i got another question i was reading around and it seems like people have a problem with the rear of the truck sagging with both 5" leaf springs should i go 4 up front 5 in the back?
Old 11-08-2014, 05:36 PM
twistedyota's Avatar
With trucks its fine, the 4runners are the ones that get the sag in the rear.
Flying91
45
04-11-2024 04:39 PM
Shagool22
08-14-2015 12:24 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
Quick Reply: First SAS on 93 pickup...(questions)
