Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
E-Locker in front
installed an e locker from an 03 taco v6 in the front of my sas conversion.
im changing to 5.29's. what the hell kind of gear do i install (reverse cut?) i have '80 p/u front axle, '88 4run rear.
__________________
cj, xj, yj, zj, BJ.. ?? Its a jeep thang!! |
| Sponsored Links |
#2 (permalink) |
Just a regular v6 gearset. Front and rear carriers and gears are interchangeable.
The only reverse cut gears are for high-pinion applications, so if you were using a land cruiser (fj40 thru fzj80) front diff, then yes.
__________________
- Brian |
#3 (permalink) |
thank you!!! by the time i get off of work, no body to talk to at retail stores.
__________________
#4 (permalink) |
I just put one in mine. Just make sure you get the right master install kit for the gears and take your time...
Here is the link to my install http://www.ultimateyota.com/index.ph....0;to picseen
__________________
1995 4Runner---SAS with goodies |
#5 (permalink) |
I highly recommend you invest in the motor cover, Marlin sells for about $50. When you hit a rock with your E-Locker that motor sells for about $550. from Toyota. I tried the cable conversion kit, good idea but didn't work for me.
#6 (permalink) |
Marc, did you have problems with the motor touching the springs? I suppose the problems will be the same in the High Pinion E-Locker as the motor is in the same side...
I don't have any locker in the front yet, but I've a HP and I think I'll be changing it in the future for a HP E-Locker. David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write... |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Front locker for '06 Tacoma | William | Offroad Tech | 44 | 03-15-2008 09:30 PM |
| locker up front??? | yotafeind | 84-85 Trucks & 4Runners | 9 | 04-07-2007 01:09 PM |
| WTB FRONT DIFF 1997 4 Runner 4:10 gears also would like complete front ARB Locker | BOSTON4RUNNER | Items Wanted | 1 | 02-02-2007 12:50 PM |
| Front Locker | herbsblue4x4 | Offroad Tech | 7 | 06-07-2004 04:16 PM |
| for those of you with a front locker.... | data | Offroad Tech | 7 | 09-10-2003 06:52 AM |
