| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
dana 44 1/2 ton front rear to toyota drive line adapter plate?
#2 (permalink) |
You are going to have to build the front anyways and probably the rear so you might as well have them put the U -joints to match the yokes since a flange yoke would cost more. I was going to put flanges on my 44s to match the flanged Tcase and thought it would be stronger but everybody at the drive line shops told me to keep the U bolt style since it was stronger. I guess it makes sense since most of the one ton axles come with the U bolts like the D60, D70, 14 bolt etc. Definately don't use a 10 bolt rear if that is what you mean by 1/2 ton Chevy.
__________________
1999 Tacoma with ARBs and 33s 1949 CJ2A "Flattie", 4.3 Vortec, TH350, D44s with Aussies and 36s Last edited by Jeep'nTaco; 02-17-2009 at 02:22 PM. |
#3 (permalink) |
Here ya go
http://www.inchwormgear.com/store/pr...roducts_id=979 I would keep the stock toy rear right now, 1/2 ton's isnt going to be an upgrade, better go to 1 ton in the rear. If it was me i would get a toy housing throw longs in it and call it done.
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
#4 (permalink) |
i would just have one end of the driveshaft and the other chevy
__________________
1988sr5 4.3v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1972 stepside jimmy d44/d70 425hp 1995 green range rover |
#5 (permalink) |
44 front and gm 12 bolt are a pretty common package deal, but because the 12 bolt is c-clip skip that and go dana 60 rear, those are cheap and easy to find. i do beleave polyperfomance.com has them, they used to anyways, if you can get there number talk to Dave Schlocshberg. there was a time way back when when marlincrawler.com had them for D60 rears. as for the front just find junk driveshaft for a yota and D44 and make a square tube and call it good
#6 (permalink) |
12bolts aren't bad so long as u buy a moser c-clip eliminator kit if you want to keep the weight down cause 60s weight alot
__________________
| Tags |
| 1/2 ton gear to toyota, 12, 44, adapter, axel, build, chevy, dana, drive, front, line, rears, shaft, ton, toyota, wwwpolyperfomancecom |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3/4 ton axle swap front and rear on 91 toyota | gentry20 | Newbie Tech Section | 15 | 10-27-2008 05:48 PM |
| For Sale 4Runner Drive Shafts/Line, Front & Rear | iceman601 | The Classifieds GraveYard | 4 | 04-01-2008 10:30 AM |
| Dana 44 front with 10 Bolt Rear, or 1980-1985 Toyota Axle with stock rear? | 1986Yotaboy | Solid Axle Swaps, All Years | 9 | 09-12-2007 01:44 PM |
| Guys, would this fit?-78 dodge 1/2 ton truck front axle dana 44 | slyang1012 | Offroad Tech | 4 | 09-28-2005 11:25 AM |
