YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-23-2007, 03:52 PM   #1 (permalink)
4Runner92sr5's Avatar
Send a message via AIM to 4Runner92sr5
DAMN front driveshaft!!!
ok so i figured since im doin my SAS in about a week that i would take my front driveshaft out so thats one less PITA to take care when it comes time....well the joint attaching to the diff was easy i just air gunned it out but the double cardon joint side attached to the Xcase is impossible to get to how did you guys take it off??
i was figuring i would take the crossmember off and support the Xcase with a jack so i could get to it but some people did it without taking it off and i want to know how you guys did it thank you ahead of time
__________________
"doing a body lift is like sleeping with a blow up doll, it might make you feel better for now, but it just doesn't feel right in the morning"
1992 4Runner Auto 3.0 135K SASed
Free Flow (no cat) Flowmaster 40 exhaust
33x12.5 BFG Mud Terrains
Marlin Crawler Rear Bumper
All Pro Front Bumper
1984 Front Axle
TG SAS kit 4'' w/ bilstein 5150's
OME 863 coils
ProComp 4" Panhard drop bracket
My SAS Thread http://www.yotatech.com/f152/startin...ss-sas-118997/
4Runner92sr5 is offline
Sponsored Links
To remove this ad, register today!
Old 07-23-2007, 04:07 PM   #2 (permalink)
AxleIke's Avatar
mine comes out with 2 14 mm wrenches.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 07-23-2007, 04:34 PM   #3 (permalink)
Tofer's Avatar
Send a message via ICQ to Tofer Send a message via AIM to Tofer Send a message via MSN to Tofer Send a message via Yahoo to Tofer
^^^ what he said ^^^
__________________
3genRunner: including parts from 3 generations of 4runners, '92 pickup, '80something Land Cruiser, Chevy truck, Ford sedan
89 4runner: Project DD. 3.0, needs a new tranny
81 2wd pickup: 22R | 5-sp | long bed | quad hauler, leaks oil but gets 26mpg
91 Honda Prelude: the Daily Driver
WA, OR or CA wheeler?? Check out pacific-crawlers.com and check out yotaworks.com
Tofer is offline
Old 07-23-2007, 04:39 PM   #4 (permalink)
anthony1's Avatar
Send a message via AIM to anthony1 Send a message via Yahoo to anthony1
put the t-case in neutral then it should be easy to turn...if you can't turn it...I mean.
and yeah, what the other guys said...two 14 mm wrench...
__________________
http://www.angelfire.com/ca6/954runner
GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1.
anthony1 is offline
Old 07-23-2007, 04:47 PM   #5 (permalink)
Tofer's Avatar
have a buddy throw it backin 4lo when you get the wrench on... makes it alot easier.. then put it back in N. to move to the next one.
__________________
Tofer is offline
Old 07-23-2007, 04:55 PM   #6 (permalink)
chimmike's Avatar
Send a message via AIM to chimmike
hop from under it, roll it a few inches, and remove another. it takes time, but its easy.
__________________
'03 350z Turbocharged (totalled :( )
'04 Honda Accord LX V6 (first bone stock car I've owned in a while)
94 4runner SR5 4x4, 31x10.5's, SAS, Warn M8000 winch, Allpro bumper, Summit (K&N FIPK in different wrapping) CAI, flowmaster muff, 5.29's FOR SALE!
'07 Harley-Davidson XL1200c, rush slip-ons
chimmike is offline
Old 07-23-2007, 05:16 PM   #7 (permalink)
i tried putting in 4 low to keep the driveshaft stable but that nut is really on there they wouldn't budge and im not a weak guy i only spent like 30 min tryin to get on it ill get it off tomorrow wd40 aught to help ive taken the rear driveshaft out no problem so i wasnt' expecting the front to be that hard
__________________
1984 Front Axle
OME 863 coils
Old 07-23-2007, 05:19 PM   #8 (permalink)
chimmike's Avatar
lol they're not that hard. Socket on one side, box wrench on the other to hold it steady. If necessary, use a breaker bar.
__________________
chimmike is offline
Old 07-23-2007, 05:20 PM   #9 (permalink)
on the double cardon joint side??? you can't fit a socket by the transfer case ive been trying maybe im just being totally retarded but theres not room for a socket and ratchet by the xcase and if i try a socket on the nut the joint gets in the way of the socket so that you cant get an even grip for the socket
__________________
1984 Front Axle
OME 863 coils
Old 07-23-2007, 05:25 PM   #10 (permalink)
Tofer's Avatar
__________________
Tofer is offline
Old 07-23-2007, 05:31 PM   #11 (permalink)
chimmike's Avatar
Quote:
use an extension? lol.
__________________
chimmike is offline
Old 07-23-2007, 05:41 PM   #12 (permalink)
ok im not as stupid as im sounding ive tried the socket with an extension.. the joint where the two ujoints connect gets in the way so there isn't a flush grip with the socket on the nut.. thats what im talking about so when you try to get a breaker bar to get it loose it strips off because the socket isn't flush on the nut for maximum grip
__________________
1984 Front Axle
OME 863 coils
Old 07-23-2007, 05:45 PM   #13 (permalink)
chimmike's Avatar
I dunno dood, I never had a problem. I did it all from the passenger side obviously underneath.
__________________
chimmike is offline
Old 07-23-2007, 05:47 PM   #14 (permalink)
yeah thats what im not understanding im doing the same thing as you guys and it doesn't work oh well
__________________
1984 Front Axle
OME 863 coils
Old 07-23-2007, 05:56 PM   #15 (permalink)
well my impatience finally taught me a lession i got it off to problem just had to let the wd40 set in i feel like an idiot
__________________
1984 Front Axle
OME 863 coils
Old 07-24-2007, 10:32 AM   #16 (permalink)
seafarinman's Avatar
Send a message via AIM to seafarinman Send a message via Yahoo to seafarinman
On my 94 truck (R150F/VF1A) there were studs pressed into the flange from the rear, and only the nuts and washers on the front. I did end up having to use the 4-LO and the 14mm wrench to get it to budge, and then going to neutral and rotating it, then 4-LO, until they all came off. The best part was trying to redrill the flange to accept the 85 CV joint! That flange is HARD. I had to just drill out the existing holes to get the bolt patterns to line up.
__________________
Rome the "Seafarinman" IT1(SW) US NAVY
1994 SAS 2RZ/R151F=244:1!
http://s11.photobucket.com/albums/a176/seafarinman/
seafarinman is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
IFS Front Driveshaft captwalker87 Solid Axle Swaps, All Years 4 05-01-2007 08:27 PM
Front driveshaft dilemma mehret Offroad Tech 7 01-29-2007 10:25 AM
Front Driveshaft Homeless dog & truck Axles/Suspensions/Tires/Wheels 0 01-03-2007 03:38 PM
Front driveshaft Homeless dog & truck Engine/Tranny/Parts 0 09-28-2006 05:10 PM
front driveshaft on 22re (cant get off) needayota 95.5-2004 Tacomas & 96-2002 4Runners 8 02-13-2005 07:10 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
