YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-06-2008, 09:35 PM   #1 (permalink)
Axle Width Question
I have an 86 that I'm thinking about SASing. What have you already accomplished SASers done to match the front axle track width the the rear axle in your ifs truck? Wheel spacers? A rear axle from the same year or same truck?
Skinsfan6 is offline
Sponsored Links
To remove this ad, register today!
Old 06-06-2008, 10:22 PM   #2 (permalink)
Staff
Elvota's Avatar
Wheel spacers (1.5") to make up the 3" difference.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
Elvota is offline
Old 06-06-2008, 10:24 PM   #3 (permalink)
DeathCougar's Avatar
Send a message via AIM to DeathCougar Send a message via Yahoo to DeathCougar
Dont use the 85 rear axle. Its 3" narrower, and much weaker.
As elvota suggested, use front spacers. Or, you can have the tubes extended. Or, use a Dana 44.
Or just put Unimog axles front and rear
__________________
Need that hard to find part? Nix99 Used Toyota and Lexus parts!
Quote:
Originally Posted by Junkers88 View Post
Good lord this thread is like herpes. Everytime I think it's gone there's another outbreak.
Quote:
Originally Posted by 1972TLC View Post
DC, you're always #1, don't worry ;)
DeathCougar is offline
Old 06-08-2008, 06:49 AM   #4 (permalink)
dirtoyboy's Avatar
Quote:
Thats what I used...they work fine...just check the torque on the spacer bolts after 100 miles and every time you rotate or take a tire off...
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
I'm the yota junk man......PM me for ALL your parts needs NEW or USED
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 06-08-2008, 03:12 PM   #5 (permalink)
customcruiser's Avatar
with the spacers that came with my kit (allpro) used longer studs that like to break...
I broke all the studs at once and almost lost the wheel on the road. I use to alway have to replace studs, the guy at napa said they were the longest he had or have ever seen.
look into using ifs hubs or something like that (there is one company that sells a kit) to make up the difference
__________________
94 4Runner Truggy
60/14B, 3Link w/18" Air Shox
Chopped & Exo'd
42's on H1 Beadlocks
Pirate4x4 Build Thread
03 Tundra Crawler Hauler/Baja DD
3" Lift, Fiberglass Fenders
Prerunner Bumper, (3) 9" Lights
customcruiser is offline
Old 06-08-2008, 03:29 PM   #6 (permalink)
Staff
Elvota's Avatar
I was curious.... do your All-Pro spacers have studs inset within them, or do the studs pass through the spacers and then the wheel?
Marlin has spacers like this:
Wonder if your All Pro spacers are a different design?
__________________
Elvota is offline
Old 06-08-2008, 03:33 PM   #7 (permalink)
bigt's Avatar
im going with a fj- 62 series axle it is wheel base is 58.75. not as many gearing options but i plan to either weld the front and put a arb when i have the coin... im still researching and prolly a year or more away.. i have the axle and its much beefier than the mini truck and im going to rebuild and long field it ... high steer system.. prolly spring over it..
also around here they want like 500 bucks for a mini truck axle..
i looked at this axle and wanted to do the s.a.s with this.
it has been done before and they people who have done it LOVE IT.
most people like the posters above use wheel spacers..
__________________
1991 HILUX SURF SSR-X
2-lte turbo diesel with upgraded head
tons of cool options you dont get in north America
RIGHT HAND DRIVE,auto,push button 4wd,turbo timer,31.1-.50.15 bfgs,factory fender flares,window flares.
CAR DOLLY
sirius TUNED TO HOWARD 100
trail ifs rig goldie
fate unknown
blue 93 srf 4runner NEW TRAIL RIG IN POGRESS
ifs welded rear few mods for now
rebuilding fj 60 series front axle for future s.a.s
bigt is offline
Old 06-10-2008, 04:19 PM   #8 (permalink)
Kaleb's Avatar
Send a message via AIM to Kaleb
My All Pro spacer are of the same design. I've never had a problem with them.
__________________
1994 Toyota 4Runner
V6 3.0
5 Speed Conversion
Solid Axle Swap
Rear Leaf Spring Conversion
1985 Solid Front Axle
Bilstein 5150's All Around
35" BFG Mud Terrains
Yukon Full Spool in Rear
3" Exhaust w/ Hi-Flo Cat and Magnaflow Muffler
Drilled Air Box
MY BUILD
Quote:
Originally Posted by Big_Denny View Post
i have been trying to find the dip stick for my rear differintial and just can not fid it is there a posibilty that the previous owner removed it? or lost it? he seemed pretty dumb and didn't know about wheeling
Kaleb is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Sky mfg full width axle sas kit jovibuilt Axles/Suspensions/Tires/Wheels 0 07-15-2007 03:33 PM
3rd Gen 4Runner full width axle swap Hyperlite Solid Axle Swaps, All Years 51 12-12-2006 08:44 AM
front/rear axle width 89dlx General Vehicle Related Topics (Non Year Related) 3 11-29-2006 08:25 AM
Axle Width Help Edge 3.0 86-95 Trucks & 4Runners 11 09-21-2006 05:26 PM
FJ40 front axle width compared to 3th gen 4runner arjan Offroad Tech 9 11-22-2004 07:24 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
