alignment after SAS? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-13-2007, 03:35 AM   #1
HAVOC's Avatar
I was just looking at some SAS threads. How do you align a truck that had IFS if all the alignment cams were removed with the rest of the stuff? I'm sure it's probably in the instructions, but I'm just curious.
HAVOC is offline   Reply With Quote
Old 08-13-2007, 05:50 AM   #2
xcmountain80's Avatar
Well for a trail rig and a method we used while at Tellico for a trail fix . Grab a tape measure and measure the inside distance of the front and the rear of the tire. Yes I know sounds like it wont work but it does.
Aaron
xcmountain80 is offline   Reply With Quote
Old 08-13-2007, 05:58 AM   #3
seafarinman's Avatar
Solid axles only have a toe-in and caster angle adjustment. I had to install a 6* shim on my spring pack to get the caster in the correct range of 5*-7* because I was getting some bad death wobble. The toe-in adjustment is just the way that XCmountain80 said. You should have anywhere from 0-1/4" toe-in (tires pointed inward in front).
seafarinman is offline   Reply With Quote
Old 08-13-2007, 11:29 AM   #4
4Crawler's Avatar
4Crawler is offline   Reply With Quote
Old 10-17-2007, 08:35 PM   #5
derrik86's Avatar
alignment shop
couldnt u just align it of have it aligned at on a alignment rack but align it to the specs of whatever vehicle it came off of ?
derrik86 is offline   Reply With Quote
Old 10-17-2007, 08:57 PM   #6
ozziesironmanoffroad's Avatar
unless it was the same EXACT vehicle, with the EXACT weight, just SAS and not IFS, then no, since that vehicle would be heavier. for example, ive heard of people taking ford axles and putting them on a yota, and then trying to align them to the ford. doesnt work that way. alignments have to be done to the car that is being worked on, no exceptions that i know of.
ozziesironmanoffroad is offline   Reply With Quote
Old 10-17-2007, 08:59 PM   #7
Tofer's Avatar
Quote:
you have more research to do......
Tofer is offline   Reply With Quote
Joe's 1987 4Runner ladybugRC 86-95 Trucks & 4Runners (Build-Up Section) 338 12-30-2016 11:09 AM
BLAZELAND LT IN 87 4RUNNER INSTALLED / CV comment and Question. JookUpVandetti 86-95 Trucks & 4Runners 10 09-30-2015 09:58 AM
22re turbo 87 4runner voiddweller 86-95 Trucks & 4Runners 16 09-29-2015 12:21 AM
86 Narrowed tons and 4Ds Toys4parts 86-95 Trucks & 4Runners (Build-Up Section) 2 09-26-2015 02:56 PM
Second Ge Tacoma SAS Project90 Solid Axle Swaps, All Years 0 09-25-2015 12:40 AM
Tags
101, 1985, 46, 4runner, adjustment, aligned, alignment, angle, automotive, caster, ford, pickup, sas, toein, toyota, tpypta
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
