YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-21-2008, 04:22 PM   #1 (permalink)
Wink '95 sas swaybar needed???
I was wondering do I need to install a swaybar on this truck to keep it more steetable and disconnect it when going offroad. I have a '95 pe-tocoma extended cab with a 4.3 chevy engine in it. I will be running 35's with 4.88 gears. I really like for it to handle pretty good on road. Also where can I get a swaybar and what do I need to order ie:'85 and earlier or '95 swaybar.
Thanks
dbright is offline
Sponsored Links
To remove this ad, register today!
Old 02-21-2008, 04:30 PM   #2 (permalink)
AxleIke's Avatar
If you are using leaf springs, you shouldn't need one.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 02-21-2008, 05:20 PM   #3 (permalink)
Staff
Elvota's Avatar
I have been debating doing this on my 4Runner, but it's a lot more top heavy than your vehicle should be.
I do a lot of long highway driving when I head up to Utah and generally pack a shuttle box full of gear way up on the roof rack. So my COG is pretty insane. It can be like driving a 4,000 lb weeble wobble at 75 miles per hour.
I may end up putting one on with disconnects, but I think you should just drive yours a bit and see how it feels. I don't have any real issues until I start loading up the 4Runner. It sways some, but I don't feel anymore than any other lifted truck would.
This is a link to a route I may go if the time comes. He used a Tacoma IFS bar that he flipped over:
http://home.4x4wire.com/erik/4runner/sas/#swaybar
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
Elvota is offline
Old 02-22-2008, 08:19 PM   #4 (permalink)
bigarms23's Avatar
no just run it without sway bars unless you have alot of body lean around corners if you do than yes run swaybars
__________________
1988sr5v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits
1988sr5v6 4runner with a 4inch allpro longtravel sas with detroit rear a ls in front and 33s
1985 sr5 4runner 8inch lift 39.5 boggers 529s detroits front and rear and triple transfer cases with a final crawl ratio of 2828to 1(sold)
bigarms23 is offline
Old 03-05-2008, 02:48 AM   #5 (permalink)
YeloSub7's Avatar
Send a message via AIM to YeloSub7
ya I was wondering this too... anyone here run swabars with an SAS? If so, how'd you manage it?
__________________
-Jake
1990 4Runner <> 1990 Toyota 4Runner-22RE-5 speed-TG 3" front/4" rear-33's-4.88's-rear LSD-front TruTrac-MC Rear Bumper-TG DOM Sliders!
SAS Build-Up
Old Rigs:
'85 4Runner (RIP)
'95 4Runner (sold)
YeloSub7 is offline
Old 03-05-2008, 09:13 PM   #6 (permalink)
bigarms23's Avatar
I do have a set on my 884runner and i had wfo concepts make them
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
SAS info needed jakek Newbie Tech Section 9 08-22-2006 02:51 PM
SAS axle info needed Bill 86-95 Trucks & 4Runners 6 05-12-2006 08:39 PM
What all is needed (from 85 donor for SAS on a 91)? 91 4Runner The Fab Shop 11 11-30-2005 05:32 PM
SAS tips and help needed PROTOTYPE2 95.5-2004 Tacomas & 96-2002 4Runners 6 03-12-2003 06:07 PM
Swaybar Disconnects CTB 95.5-2004 Tacomas & 96-2002 4Runners 2 01-21-2003 11:01 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
