91 runner front 3 link solid axle - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-29-2009, 01:35 PM   #1 (permalink)
miese's Avatar
This post was started on another site but I wanted to let some other yota guys in on my fun.
So last summer I ran my 33’s and did nothing but break front axles and it really took the fun out of playing with my truck. This year I am going with an 85 solid axle running a high pinion land cruiser third and factory e-locker. Should be much better!
Got the plasma going and voila….pile of useless parts!
Gotta get the rest of the mounts out of the way
Nice clean frame!
Raise the drive line up 2 ½ inches to flatten out my belly.
Clean out the old crossmember to make way for the new one. 2x4x1/4 made from three pieces for easy trans service. Lower links for radius arm will start at the crossmember and run to the front diff. Gonna use coilovers to hold it all up.
Truck looks mean without the ifs junk!
Started getting the axle ready.
Made all the gussets need to weld it all up.
Parts just waiting to go together!
Axle upgrade….. Big Time!
More to come!
miese is offline
Old 03-29-2009, 03:45 PM   #2 (permalink)
miese's Avatar
so the front shaft doesnt have much flex .
For the work required and the cost involved, it was well worth it.
miese is offline
Old 03-29-2009, 03:46 PM   #3 (permalink)
miese's Avatar
I wanna keep it a little low so i need to c noth the frame.On the front (sounds weird)
Very excited to cut out original frame tonight!
miese is offline
Old 03-29-2009, 03:47 PM   #4 (permalink)
miese's Avatar
Some new pics of the old frame all gone and the diff trussed up!
Got a 2 wheel dr pan to give me more room. All the steering gonna fit up nice.
miese is offline
Old 03-29-2009, 03:50 PM   #5 (permalink)
miese's Avatar
I have been in the mock up and decision stage.
Looks as if I am going with a three link , with a panhard bar. Should work very nice. I have found that my frame is gonna be to close to my locker when I start to flex so I decided I am going to c-notch the frame. It is going to make the frame stronger at the front and give me the clearance I need. My hope is to keep the truck at a nice ride height and have lots of flex. My coils at this time will restrict me to 2.5 inches of up travel and 5.5 down.
Looks that my caster angle is gonna be just slightly positive which should be just fine.
miese is offline
Old 03-29-2009, 06:26 PM   #6 (permalink)
TMZ
TMZ's Avatar
Have you thought about jigging the front housing to make sure it did not warp from all the welding on it. You do really nice work BTW.
TMZ is offline
Old 03-29-2009, 07:02 PM   #7 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Did you do that or have it done? What exactly did you do?
Looks nice and purty.
waskillywabbit is offline
Old 03-29-2009, 07:09 PM   #8 (permalink)
miese's Avatar
Quote:
First Thank you, and second it took a few hours to weld up, doing 1 to 2 inch passes on opossite sides. Lots of cooling cycles in between. Starting out with the 85 housing already trussed on the bottom makes it a little safer too.
miese is offline
Old 03-29-2009, 07:18 PM   #9 (permalink)
ocdropzone's Avatar
x2..did you use 4crawler's write up?
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is offline
Old 03-29-2009, 07:47 PM   #10 (permalink)
miese's Avatar
I did the driveshaft myself. It really wasnt all that bad to do.
once its apart the mods are easy. befor and after pics of all the stages.
strip and sandblast
remove the seal and grind off the stop ring
cut the stop off the bottom and remove excess off top of bearing
clearance for the grease fitting
Funny part, I have to cut it now to lengthen it, need about 5 inches so i am just gonna retube it and not change the slip joint. Gonna see how that works.
miese is offline
Old 03-29-2009, 07:50 PM   #11 (permalink)
miese's Avatar
I used a write up on 4x4wire. Just enough detail to get me goin.
miese is offline
Old 03-29-2009, 07:56 PM   #12 (permalink)
86Toyrunna's Avatar
sweet build up so far man, cant wait to see this all done... subscribed!
__________________
current: 1986 4Runner, Rebuilt 22RE with engnbldr HP head, cam'd, battery/intake swap, SASed, 5.29s, detroit rear, 35in MTRs, trussed and armored axles, marlin HD clutch, soon to be dual cased, TG rear bumper, Best mod todate CHROME METAL SR5 DOOR HANDLES, thats whats up
RIP: 1985 Standard Cab SR5 pickup, add-a-leafs and shackels, 33" BFGs, it died a horrible death (50mph roll over)
DD: 2006 Scion Tc w/TRD Supercharge and TRD stainless cat-back exhaust
86Toyrunna is offline
Old 03-30-2009, 05:31 PM   #13 (permalink)
miese's Avatar
Thought I would put up some pics of my crossmember and link setups. Still in the early stages.
Bungs for the johnny joints
Front lower links
miese is offline
Old 03-30-2009, 06:36 PM   #14 (permalink)
bigt's Avatar
YEAH MAN!!! i kinda wanted to post this up one here so the toyota dans could see it...
being on the heep site and all..
CANT WAIT TO SEE THIS BIA in PERSON WITH THE LINKS...
your drive shaft mod with pics is totally boss hog
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan,
130,000 km 31 bfg a/t auto
current build
1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/
bigt is offline
Old 04-01-2009, 12:51 PM   #15 (permalink)
agusgus3's Avatar
Sweet going build man. Hopefully we can help each other on this 3 Link, I'm doing one as well. Have you considered going to a 4 link radius arm setup like that found on jeeps?
agusgus3 is offline
Old 04-03-2009, 06:32 PM   #16 (permalink)
miese's Avatar
Quote:
I did consider going with a radius arm setup, but after cuttin it all out and sitting back for a good look I decided a 3rd link would be better for me. I think with the radius arm set I will be restricted on placement of my coil over.
Plus who does a radius arm "heeps", The YOTA needs to be different.
miese is offline
Old 04-05-2009, 05:52 PM   #17 (permalink)
agusgus3's Avatar
are you going to put the upper link mount on the frame rail or on the cross member your making?
agusgus3 is offline
Old 04-05-2009, 06:19 PM   #18 (permalink)
scuba's Avatar
Subscribed...
Lookin Badass so far !!
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 04-07-2009, 11:12 AM   #19 (permalink)
miese's Avatar
The upper link is on the crossmember so that the three links will be the same length. Unequal lengths makes for some difficult geometry. Using 2 holes on each mount for adjustability.
Hopefully I will post a few pics tonite.
miese is offline
Old 04-07-2009, 08:04 PM   #20 (permalink)
miese's Avatar
So got the links and crossmember done.
Third link and coilovers are next. Engine and trans lift into the body went nicely as did the frame.
Was happy with the space and clearance gained for up travel.
Third link gonna fit right up in the frame and clear the oil pan and engine mount thanks to a pair of brackets Stangs fab added to the build.
Thinking a 36 or a 38 tsl for her to ride up on.
miese is offline
Old 04-10-2009, 10:26 AM   #21 (permalink)
miese's Avatar
all links in and hooked up. Moving on to coil mounts.Flex is real smooth with no binding and it seems that all is gonna clear real well.
Couple more days and the front should be done! Time to link the rear!
miese is offline
Old 04-10-2009, 10:31 AM   #22 (permalink)
scuba's Avatar
Square links...Thats no joke !!
Im diggin this build and cant wait to see whats next
__________________
scuba is offline
Old 04-21-2009, 08:48 PM   #23 (permalink)
miese's Avatar
Front end is almostc complete. Getting ready for reassy. The spring perches are all done and the frame is finished(on the front anyway).
Front diff is ready for a clean and some fresh parts.
I decide the time was right so , the rear got cut out too. Frame is a little soft on the pass side so I'm gonna have to fix it too.
miese is offline
Old 04-21-2009, 09:09 PM   #24 (permalink)
scuba's Avatar
Jeezus, Thats whats up...
__________________
scuba is offline
Old 05-02-2009, 07:54 AM   #25 (permalink)
miese's Avatar
So the front is pretty much complete and I got some new rubber.
Let me know what you guys think! I have to cut out the rear frame cause there is some rot to fix. I will post some pics of the rear soon.
miese is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Feeler: Front solid axle and rear 2wd axle thewjsand The Classifieds GraveYard 2 04-22-2008 06:17 PM
Solid Axle 88 runner big jim The Classifieds GraveYard 11 02-02-2008 05:13 PM
Solid Axle Runner and IFS Runner Decisions GreeneHoosier 95.5-2004 Tacomas & 96-2002 4Runners 15 11-18-2005 09:14 AM
V6 vs solid front axle. GV27 Offroad Tech 8 05-16-2003 01:44 PM
2009 InternetBrands, Inc.
