89' hilux 2WD
There is tons of information on this on here over at marlin crawler and on pirate 4x4 use caution on pirate if you ask this question you will at best get ignored and more than likely get made fun of till you don't come back. Use google to search what you want to do. Put yotatech in with your search. Then repeat with marlin crawler then pirate. You should read till your eyes bleed. Then a little more. You also need to be more detailed in you question. Are you wanting a stock height truck. Small lift. Ect ect ect. Do you had the springs? Are you building a driver or a wheeler? More information helps us help you. Have you seen a truck on here that you trying to make it like. Might be able to "copy" parts and hanger locations. Good luck hope this helps.
AND DONT FORGET TO READ. It will save you more headache than you can imagine.
im making it to be a farm truck and a off road and on road all in one pretty much just need to figure out how to put a toggle and push button in but its being a pain so far but im tring to get everything else done then do the sas after
Dale Johnston
11
10-31-2015 10:22 PM
Cycles
09-29-2015 06:37 AM
