Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
'87 Sas
Will the front axle from a 1974 fj55 work in my '87 4-runner if i were to have a SAS done? I know that axle may not be ideal but I can get one for cheap.
Thanks |
| Sponsored Links |
#2 (permalink) |
If it is a passenger side drop it should work, I don't know about spring spacing, but I guess you could always cut the old ones, and weld in some new ones. If I were you I would pass on this axle, it seems like their is more aftermarket support for the 1979-1985 axles.
__________________
1994 Toyota 4Runner V6 3.0 5 Speed Conversion Solid Axle Swap Rear Leaf Spring Conversion 1985 Solid Front Axle Bilstein 5150's All Around 35" BFG Mud Terrains Yukon Full Spool in Rear 3" Exhaust w/ Hi-Flo Cat and Magnaflow Muffler Drilled Air Box MY BUILD |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| SAS 87 4runner | superman180 | 84-85 Trucks & 4Runners | 19 | 04-09-2007 04:08 PM |
| Which ARB Bumper will fit a '87 4Runner with SAS? | Gunshipdriver | 86-95 Trucks & 4Runners | 0 | 03-20-2007 12:12 AM |
| To SAS or not to SAS that is the ? | Tofer | 86-95 Trucks & 4Runners | 63 | 03-15-2007 11:18 AM |
| My SAS is under way | jayson161 | The Fab Shop | 32 | 12-11-2004 09:53 AM |
| Sas | customcruiser | North Carolina | 44 | 02-19-2004 09:05 AM |
