YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-27-2008, 09:51 PM   #1 (permalink)
broskyo's Avatar
87 4runner sas
I'm starting my sas on my 87 4runner. Today I began cleaning up my 83 axle. I am going to be using the 3in trail gear kit with 4.88 locked front and rear both with lockrights. Still not a 100 percent sure on how I'm going to lift the rear. Will try to get some pictures of progress in the next few days.
broskyo is offline
Sponsored Links
To remove this ad, register today!
Old 06-27-2008, 10:27 PM   #2 (permalink)
john rumbo's Avatar
Send a message via AIM to john rumbo
goodluck on bid
__________________
bigblockyota 884runner chevy 454 fuelinjected fullsize chevy dana 60 axles 14bolt rear 5.38grs spools frt,rrear 4wheel disc conversion tur400 trns 203 dbler 205 tranfer aprox 8-10 inch lift 37inch tslboogers 3inch magnaflow exhaust msd ingn aluminum rad ,flex fan 56 , inch spring conversion w8000lbcomp winch and bumper and just added a full hydraulic psc steering kit
john rumbo is offline
Old 06-27-2008, 10:28 PM   #3 (permalink)
john rumbo's Avatar
sorry reply on your build to many beers
__________________
Old 06-28-2008, 06:13 AM   #4 (permalink)
Sponsoring Member
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
On a 4Runner typically go 1" higher in the rear, on a pickup go the same.
Not sure how you are going to lift the rear? Does that mean you are trying to decide between 3 link, 4 link and leaf springs?
Order from me and save the sales tax.
waskillywabbit is offline
Old 06-28-2008, 11:42 AM   #5 (permalink)
broskyo's Avatar
I'm planning on doing the rear with leaf springs just not sure if I'm going to go with longer leafs or leave it stock length.
Just to save money I was thinking 3in downey leafs with an add a leaf and then a 1 1/2 shackle lift
broskyo is offline
Old 06-29-2008, 06:57 PM   #6 (permalink)
broskyo's Avatar
Started cleaning up the axle and taking the hubs apart, just need to get my 54mm socket.
broskyo is offline
Old 08-21-2008, 01:33 PM   #7 (permalink)
broskyo's Avatar
My camera isn't working so I cant show pics but the top half of the ball is pitted really and I don't know what to to do about it. Resurface?....or just leave it?
broskyo is offline
Old 08-21-2008, 01:49 PM   #8 (permalink)
broskyo's Avatar
got the camera to work
heres wat ive got done so far
broskyo is offline
Old 08-22-2008, 01:33 PM   #9 (permalink)
broskyo's Avatar
Bump!!
broskyo is offline
Old 08-22-2008, 04:08 PM   #10 (permalink)
88wildrunner's Avatar
i would just try sanding it, mine had a little bit of that so i just sanded it. make sure when you rebuild it to use plenty of grease to keep the ball and the birf lubed up.
good luck on the build.
__________________
I Got Your Jeep Thing, Now It Hurts To Pee.
MY 4RUNNER BUILD
http://www.yotatech.com/f115/88wildrunner-build-125357/
88wildrunner is offline
Old 08-23-2008, 07:08 AM   #11 (permalink)
dirtoyboy's Avatar
I just use sand paper or a scotch brite pad
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
I'm the yota junk man......PM me for ALL your parts needs NEW or USED
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 08-23-2008, 06:58 PM   #12 (permalink)
broskyo's Avatar
OK well I've used some sandpaper and touched it up with a soft wire wheel and I think I got it about as good as I can. Now I'm just having problems getting the axle oil seal out.
broskyo is offline
Old 08-23-2008, 07:05 PM   #13 (permalink)
Sponsoring Member
$5 seal puller
Old 08-24-2008, 05:57 AM   #14 (permalink)
dirtoyboy's Avatar
I usually use a giant flat head screwdriver.....jam it into the seal and pry it out....
You're putting a new one in anyways...good luck!
__________________
Old 08-24-2008, 12:57 PM   #15 (permalink)
broskyo's Avatar
I tried the screw driver thing for about 30min never got it to work so I will be buying the tool
broskyo is offline
Old 08-24-2008, 01:13 PM   #16 (permalink)
dirtoyboy's Avatar
Quote:
You aint trying hard enough! hit the screw driver with a bfh until it goes in then pry it out...the seal will be mangled by the time u get it out
__________________
Old 08-24-2008, 03:17 PM   #17 (permalink)
broskyo's Avatar
Ya I tired harder and got them out so now I'm just waiting on getting the 3rd member gasket...So my friend who lives out on a farm that had the welder and torch I was using cant have anybody over any more because one of the kids out there pissed of his dad so now I'm on the search for a welder I can use it to put on the armor.
broskyo is offline
Old 08-24-2008, 03:18 PM   #18 (permalink)
Spinnbait's Avatar
Use a punch (or old screw driver) on one side of the seal and then another time 180 degrees away. Crinkle/fold the seal a bit by hitting these two points and then pull it out with pliers.
__________________
Cannondale Rush 3 carbon (my new baby)
Surly 1x1 (my D/D)
1973 Schwinn cruiser (my shop bike)
Spinnbait is offline
Old 08-24-2008, 03:26 PM   #19 (permalink)
Team420's Avatar
Quote:
^ Good Tip ^
__________________
Quote:
Originally Posted by wheelaholic View Post
yea some people get the jeep thing to but i think they make a pill for that
Quote:
Originally Posted by owndog12 View Post
They do it's called a toy pill ! Take two and trade your jeep for a yota in the morning !
93 Runner, 3vze, auto, 4.88 gears, 31" tires, mostly stock, 255k and counting
DD:
94 runner, 3vze, geared 4.56, m/t, 31/10.5/15, only 200k on the clock
Project:
91 p/u, 3vze, m/t, 2" body lift, 4.10 gears, 33's, 219k on the clock.
It's becoming an addiction.
Team420 is offline
Old 09-11-2008, 06:20 PM   #20 (permalink)
broskyo's Avatar
I'm back in school so I have access to a parts washer and I got one side of the knuckles and hubs all cleaned next week I should be able to do the other side. This weekend I should finish welding the gusset and amor and get started on painting the axle
broskyo is offline
Search this Thread:
Advanced Search
Display Modes
