YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-22-2008, 11:46 PM   #1 (permalink)
86 toyota excab sas
i would like to know what you guys think. do i need more clearance with the front bumpstops? do you think my rear shock setup will hold? any other tips?
86-toyota-excab-sas-front-bumpstop.jpg   86-toyota-excab-sas-rear-shock.jpg   86-toyota-excab-sas-rig.jpg
mphyota is offline
Sponsored Links
To remove this ad, register today!
Old 06-23-2008, 02:57 PM   #2 (permalink)
sh0kk86's Avatar
only suggestion i can see would be changing the rear shock mount.
you should still run a brace from one side of the frame to the other(bar, tube) and find a way to mount your shocks to that.
the mounts you have now look like they may not be strong.
__________________
1986 Toyota 22r Short bed Pickup | 33x10.5x15 BFG MT's
sh0kk86 is offline
Old 06-23-2008, 03:45 PM   #3 (permalink)
Staff
Elvota's Avatar
I second that... improve the upper mount with a gusset (or two)
I have always understood that bumpstops should be set so the spring will go flat, and not invert... or reverse the arc.
__________________
1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000
- four wheels | three sticks | two hands | one trail -
Elvota is offline
Old 07-07-2008, 12:16 AM   #4 (permalink)
knuckle rebuild
rebuilt my knuckles with the knuckle rebuild kit from trail gear. got everything back together and drove it down the road. everything was fine until i locked the hubs. when i locked the hubs the front right side felt like it had a wobble. what could i have done wrong?
mphyota is offline
Old 07-07-2008, 01:04 AM   #5 (permalink)
Blizzard's Avatar
Send a message via MSN to Blizzard
Have you checked your pinion angle? If you've quite ride height, single T-Case and a low pinion diff your DS angle may be bad and this is why you get vibs with the hubs locked or the 4WD engaged.
Another option is that you've your DS off-phase. If in the process of removing the diff you take the yoke off and then reassembled it off-phase you'll get vibrations too.
David
__________________
'94 Toyota 4Runner 3.0 Turbo Diesel Intercooler – Trail-Gear 4'' SAS front, Trail-Gear 5'' rear leaves swap, 35x12.5x15 M/T's and too many things more to write...
Blizzard is offline
Old 07-07-2008, 02:04 AM   #6 (permalink)
it was fine before i did the knuckle rebuild. i didnt do anything to the driveshaft, i did slip it back a little to get a gasket on the front diff, but didnt mess with it. its my first knuckle rebuild so im thinking i did something wrong or missed something. how do i find the problem? i had a hard time getting the locking hub on, had to tap it a little.
mphyota is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1984 Toyota excab 4x4 offroadohio Vehicles - Trailers (Complete) 1 03-08-2008 04:00 PM
91 toyota sas!! TOYOTA 1 86-95 Trucks & 4Runners 6 02-24-2008 04:06 PM
2004 Tacoma SAS ExCab Knox Vehicles - Trailers (Complete) 20 09-26-2007 07:26 AM
WANTED: SAS toyota hexone Items Wanted 4 08-19-2007 06:55 PM
1986 2WD Toyota Turbo ExCab (71k) knucklehead38401 Vehicles - Trailers (Complete) 5 07-23-2007 01:20 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
