Thread Tools | Search this Thread | Display Modes |
#1 (permalink) | |
4runner SAS: how tall are your leafs?
About to order up a SAS kit, wondering what leafs I should get? what are other's experiences?
__________________
91 4runner - 3.0 - 5spd | 6" lift | 35" X-Terrain | Roof basket | Hella AUX lights | IFS brace | 2.25" x-over eliminator and Magnaflow exhaust | ISR | 5.29's | F & R Detroits | Cobra CB | 84 VW Diesel Rabbit....47mpg Quote:
| Sponsored Links |
#2 (permalink) |
what size tire do you plan on running? That is a big part of the lift you need. Is this a truck or 4runner? for 33'' tires, go with 3-4'' lift. I have 3'' up front and it is great. If you want to run 35'' tires, go with 5'' lift.
__________________
-Hayes |
#3 (permalink) | |
it's a 91 4runner. I am looking at 35's or 37's whatever comes available really
__________________
#4 (permalink) |
then a 5'' lift will be what you are looking for.
__________________
-Hayes |
#5 (permalink) |
I would not get a 5" lift. I have a buddy running 36" tires and 5" springs. He's truck is TALL. Get 4" front and 5" rear max. If I had it to do over I'd go 3" front and 4" rear but that's just me.
__________________
Greg - http://www.pureyota.com --- you can't fail if you don't give up. Proud dad of a little girl.. 1. 1997 Tacoma - 3.4 auto - SAS'd - DD 2. 1995 4Runner - SAS'd - FJ62 Front - FZJ80 Rear, 40" Iroks - Beater! 3. 1995 4Runner - 3.4 swapped - Baby mobile/Grocery getter! You can lose a lot of money chasing women, but you'll never lose women chasing money. |
#6 (permalink) | |
The only thing I can think why I would go for 5's is I can always remove leafs to flatten them out no?
__________________
#7 (permalink) |
Staff
I ended up with Marlin 4" fronts and All-Pro 6" rears. This was upon Marlin's suggestion, as All-Pro (at the time) measured their springs differently. Generally, it's common to go 1" more on the rear to help offset some of the additional weight of the 2nd Gen 4Runner. To be honest, even with the 6" AP springs I could never get the tail end level.
I have 35's now, but may up to 37's when they wear out. I envision having to cut some sheet metal or mod with a BFH a little bit to get everything to work. Currently, I have almost no rubbing issue except at a full stuff and full turn... and even then only very minor. This is a fake CRAWL layout I made a while back goofing around with some Adobe programs.... pretty ridiculous I know, but it does show the dimensions I ended up with pretty well: ![]()
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - |
#8 (permalink) |
Sponsoring Member
Leaf spring lift depends on a lot of things as mentioned above.
I agree with Yotaman on springs. I run 40s with a 5" lift but I have no sheet metal either. ![]()
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab FOR SALE: 1987 4Runner GRAY FOR SALE: 1987 4Runner RED 6th Annual South East 4Runner Jamboree, May 22-25, 2009 |
#9 (permalink) | |
somewhat off topic. Is there a difference in leafs between companies, ie: trail gear, marlin, all-pro, wab-fab? or are the kits all fairly similar?
__________________
#10 (permalink) |
Sponsoring Member
Do some searching as it has been discussed ad nauseum but your options are limited in Canada with import fees.
__________________
#11 (permalink) |
Heres a general guideline to get started....
33-35" tires = 3 inch lift 35-37" tires = 4 inch lift 37'+ tires = 5 inch lift Use sawzall. Cut to fit ![]() and YES there is a huge difference in spring quality and rates between the different companies...I would recommend doing some research before you drop some serious coin
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. I'm the yota junk man......PM me for ALL your parts needs NEW or USED Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#12 (permalink) |
my truck came out a lil wierd. i didnt want body role so i went with 3.5" lift spring in the front and a 5" allpro in the rear. and it sits level! here is a pic on 35"
__________________
91 Toyota stdrd cab short bed 22re 5spd. sas'ed, Yukon 5:29's. 3.5" tuff country e-z ride springs in the front. 5" allpro long travels in the rear. pro comp es 9000 shocks, 12" tg long spline front d shaft. k&n, 35x10.50x15 boggers. cobra cb/ashtray mod, 3' fire stick. etc. 2000 Toyota Tacoma xtra cab sr5, 3"revtek,285/70/17 coopers stt, clear tails, injen short ram intake, obx header, flow master, etc. 2001 Toyota Camry, the girlfriends, www.22re.com |
#13 (permalink) | |
how do rears up front size up?
__________________
#14 (permalink) | |
any input on rears up front?
__________________
#15 (permalink) |
I would order marlins 4inch sas kit but have 5inch rear springs to compansate for the extra rear weight
that will allow you to run 35s or 37s with minor fender trimming and it will give a great center of gravity
__________________
1988sr5v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits 1988sr5v6 4runner with a 4inch allpro longtravel sas with detroit rear a ls in front and 33s 1985 sr5 4runner 8inch lift 39.5 boggers 529s detroits front and rear and triple transfer cases with a final crawl ratio of 2828to 1(sold) |
#16 (permalink) | ||
Staff
Another one for 4" front 5" rear. Other options are rears up front and chevies rears.
__________________
2006 Tacoma TRD offroad 4.0 Access Cab 6 sp 3" Revtek, 285 BFG's, Borla Catback, Volant Intake, Billet Grill, Split Second PSC1 Professionally dyno tuned, URD Short Shifter Kit, 226 RWHP 1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's See my build up thread here http://www.yotatech.com/showthread.php?t=104000 Quote:
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Recomendations on LC80 lift tall tall VS short short pairs | johnsenpa | 86-95 Trucks & 4Runners | 4 | 01-25-2008 09:08 AM |
| 4runner leafs on Pickup | 91ToyTrck | 86-95 Trucks & 4Runners | 9 | 11-19-2006 04:26 PM |
| Rancho Add-A-Leafs - 1st Gen 4Runner | Bob_98SR5 | Maintenance & Repair | 0 | 01-14-2006 08:56 PM |
| Will 98-04 tacoma leafs fit 86 4runner? | nmtoy | Offroad Tech | 6 | 11-07-2005 07:54 AM |
| Best add a leafs for a 1st Gen 4Runner | pruney81 | Offroad Tech | 2 | 05-05-2005 09:58 PM |
