YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Solid Axle Swaps, All Years
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-12-2008, 10:48 AM   #1 (permalink)
Toyotero's Avatar
44044's in front? Hybrid pack? On an '86 4Runner SAS
I'm planning the SAS on my '86 4Runner. I want 3 to 4 inches of lift over stock with good flex.
I got a deal on a '85 Toy front axle and it came with some like-new Rancho 44044s. I'm deciding if I will use them for the front suspension or not...
I've seen people mention "44044 hybrid" spring set up, which sounds like it is a Toyota main spring (front or rear) and some or all of the 44044 pack. Considering the difference in width of the springs, I'm wondering how this works exactly. It seems like they could be sloppy in the axle ubolts and the anti-fanout/anti-wrap clamp at the end of the second/third spring.
So, here are my questions I have now:
* To anyone who used 44044s on the front of a SAS:
- How did you hang them?
Did you make your own spring hanger?
I've read that some people use Toy spring hangers and grind the springs narrower to fit.
* How is a 44044 hybrid pack made with narrower leaves?
* Can I take some leaves out of the 44044 pack to lower the lift down to 3-4 inches (from 5" to 5.5") and expect to flex them with out damaging the leaves?
Thanks in advance.
Generz
EDIT
I didn't know that Pirate4x4 made the search work for non-starred members. For reference, these are the best discussions on this topic that I have found:
http://pirate4x4.com/forum/showthrea...ighlight=44044
Other related info:
hangers
Rear up front FAQ
http://www.pirate4x4.com/forum/showthread.php?t=265669
__________________
- El Toyotero
"I fly by ya in a foreign whip!"
FREE Toyota Factory Service Manuals ---> FSMs
Toyotero is offline
Sponsored Links
To remove this ad, register today!
Old 06-17-2008, 07:17 PM   #2 (permalink)
bigarms23's Avatar
i would put the ranchos in front and find a set of 4leaf chevy 63 for the rear and that should give a 4inch overall lift
__________________
1988sr5v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits
1988sr5v6 4runner with a 4inch allpro longtravel sas with detroit rear a ls in front and 33s
1985 sr5 4runner 8inch lift 39.5 boggers 529s detroits front and rear and triple transfer cases with a final crawl ratio of 2828to 1(sold)
bigarms23 is offline
Old 06-25-2008, 01:41 PM   #3 (permalink)
cubuff4runner's Avatar
I haven't heard about using a toyota leaf in the 44044 hybrid. I have a 44044 Hybrid that uses the main and second leaf of the 44044 because it is military wrapped and the lower 4 are stock waggy springs. I have an extra leaf on the driver side to level it out more.
__________________
96' 4Runner
SAS - 87 Waggy 44 Aussie Locker & Alloy Shafts, 63" Chevy Rear Leaf Conversion, Inchworm Dual Crawler, PSC Hydro Assist, FROR Full Floater
Rockfrogs
Pics
cubuff4runner is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Toyota Hybrid Solid Front Axle 90slvpup Axles/Suspensions/Tires/Wheels 5 04-30-2008 03:12 AM
SAS with rears up front Kiff Solid Axle Swaps, All Years 1 04-14-2008 05:08 AM
SAS Front Axle? 94toyota4x4 86-95 Trucks & 4Runners 8 10-23-2006 09:39 PM
Feeler: 95 4runner sas front and leaves in the rear. mandownco Vehicles - Trailers (Complete) 2 05-12-2006 07:17 PM
CJ or YJ front springs for SAS 934rnr The Fab Shop 8 09-09-2004 09:53 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
