| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
2000 Taco trans ?
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#2 (permalink) |
Staff
Using a stock toyota front axle, no.
using a drivers drop Dana44, maybe. the factory toyota SFA is a pass side drop, and the tacoma uses a drivers drop case. Marlin does make an adapter to bolt on a gear driven pass drop case to the tacoma trans. Also, the Tacoma uses an 8.4" diff (though its actually its just an 8") but the Tacoma diffs use extra support fins that make so it wont fit in a stock 8" housing.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#3 (permalink) |
So I can't use the e-locker in the 4cylinder rear? so I guess that means I stick to the original plan and do it all in the 3.slow
__________________
#4 (permalink) |
If it is an E-locker rear, it can be made to fit in the 93' housing (there is no difference in housings between 4 and 6 cylinder). I retrofitted an E-locker into my 91 truck housing which is the same, minus the suspension brackets. There are several writeups on the cutting you need to do to the housing to fit the e-locker. From what I hear about the 3.4 swaps, and having owned a 3.0V6 in my truck, I'd say do the swap. You'll be much happier, my new 3.0---turbo diesel is quite the upgrade from the v6.
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 2000 4runner drivetrain jerking (trans?) | bwilder10h | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 06-08-2008 04:05 PM |
| 2000 taco - 1 or 2 cats? | neoworm0 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-16-2008 10:32 PM |
| 2000 taco dash lights | kenai | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 03-08-2008 07:06 PM |
| looking at 2000 Taco any thing I need to know? | Ilovemountains | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 10-01-2004 06:43 PM |
