YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Topic, Wiki Discussions, Fraudulent Vehicle Listings, & Stolen Rigs > Introductions & New Arrivals
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-26-2008, 07:09 AM   #1 (permalink)
1987 4 Runner
I have a 1987 Toyota 4 Runner, 22 R 4 cylinder. I have a problem that no one can figure out, it seems whenever it rains out, the truck wants to stall and lose it's power in 1st and 2nd gear.
Previously, did new timing chain and water pump, complete tune-up, clean throttle bottle.
The problem I don't understand is when it's raining out it will do this when I first start the truck up and after I drive for 15 minutes it works itself out.
If anyone has had this problem please reply, greatly appreciated.
bulletproof toyotas is offline
Sponsored Links
To remove this ad, register today!
Old 09-26-2008, 08:47 AM   #2 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
Sounds like water is getting somewhere. It's carberated huh?
__________________
Logan Oliver
'86 4Runner SR5 22R-E
Complete engine overhaul at 175,000
4" Procomp/Superlift/Rancho 9000x
Downey Header/Magnaflow exhaust
315/75R-16 Baja Claws wrapped around AR-23's
4.88's a TrueTrac and All Pro rear disc kit w/emergency disc trans brake
BudBuilt skids
http://yotatech.com/gallery/showgall...ser=20182&sl=b
'06 4Runner Sport
270/65R17 BFG All Terrain KO's
BigBluePile is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1987 4-runner battery discharging jimtanner 86-95 Trucks & 4Runners 7 07-01-2007 06:47 AM
1987 Toyota 4-Runner nc994run Vehicles - Trailers (Complete) 0 10-18-2006 05:41 PM
1987 Turbo Runner Stock in MO colsoncj Vehicles - Trailers (Complete) 22 05-02-2006 08:21 PM
1987 4-runner rear door needed jimtanner 86-95 Trucks & 4Runners 12 03-19-2006 06:09 AM
wiring diagram/1987 4 runner jimtanner 95.5-2004 Tacomas & 96-2002 4Runners 1 10-29-2005 10:40 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
