| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
should I buy this car?
#2 (permalink) |
Why so cheap? Its going to have a salvage title since it's from an auction. Dont necessarily buy it, but definitely go check it out and if its good, go with it. Be a little weary though, auctioned cars like that are usually from DUI impounds and the such. A few of my friends have gotten vehicle from auctions with little to no problems, but still check it out thoroughly. It looks pretty cool though. FJ-60/62s are bad ass.
Also, did you read the description? He said the transmission had some problems.
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold| Pro IFS Last edited by toyota4x4907; 09-11-2009 at 09:49 PM. |
#3 (permalink) |
I did, how much do you think repairing or replacing the transmission would be?
#4 (permalink) |
I dont know whats wrong with it, I've never worked on autos. If you were to replace it, it would cost what a new/used tranny plus labor if you dont do it yourself. It depends on your area and the shops around you.
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler '88 4runner|22re|5spd|206K miles|Sold '93 single cab|22re|5spd|150K miles|Sold| Pro IFS |
#5 (permalink) |
Looks like a very sweet deal. Too good to be true? Just my two cents: I've learned to check out the vehicle as best I can. Check the vitals, idle speed, timing, vacuum, compression. Check belts, hoses and fluid levels and conditions. Says he changed the oil? Check this too! Bang on the frame with a ballpeen. Pull a wheel, front and rear. Or bring a mechanic. If the seller has a problem with you going detail on it, then say goodbye. One thing (of many) I need help with is tranny trouble, but having to warm up the trans to be able to shift for the whole day sounds like it needs work. One should be able to shift a cold tranny just fine. But you know it's gotta have some problems for you at that mileage and asking price. Hope this helps.
__________________
1994 Toyota Pickup 4WD Reg Cab 22RE 5spd 107K and running strong...but needs work. |
#6 (permalink) |
Its an old vehicle and its going to need some work, so just completely look it over inside and out, and test drive and listen for any strange sounds, and if everything seems ok then buy it. even if you need to have the trans rebuilt/replaced it would be worth it in my opinion. I have no idea what it would cost to have the trans rebuilt, probably some were between five hundred to one thousand dollars, and that only a guess.
__________________
86 Toyota 4Runner Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper. |
#7 (permalink) |
Why do an FJ60 when you could buy an FJ80 that needs zero work and has 1/2 the miles! Oh look... I've got one for sale: $5,500 for Toyota geeks like me
http://lasvegas.craigslist.org/cto/1362995341.html Let me know if you're interested. Cheers
__________________
2003 4runner sport 1993 Land Cruiser (for sale) 2004 Prius 2002 Tacoma xtra cab (sold) 2000 Rav4 (sold) |
#8 (permalink) | |
Quote:
![]() check out ih8mud. lots of lc info over there. I know quite a few people that have 62s and they are pretty tip top. However I dont ever recall seeing that orange paint on a 62 though. The trans issue seems odd. I would definitely be leary of that. 300k on the drivetrain really isnt nothing for that drivetrain. $2k doesnt seem like a bad deal if you are one that doesnt mind working on your vehicle if problems should come up. but if you are buying it for a dd that you wont have to work on, you might want to pass. also look for any oils stains under wear it is parked. usually an indicator of how bad a leak is if there is one.
__________________
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some muscle. |
#9 (permalink) |
Oh how embarrassing! can't believe I thought it was a 60.
Here is a link to useful info. http://forum.ih8mud.com/60-series-wa...*********.html
__________________
