S&J Engines - Brand New 22RE
YEAH BUDDY! MY ENGINE ARRIVED! Picking it up tomorrow!
Newly remanufactured S&J engine with a Toyota remanufactured head and RV cam. I'm so stoked!
^^^ I will do my best. I can already tell you I do not have the patience or time to do as thorough a build as I've seen some of the guys on here do. Thank goodness for them, I'm sure I'll be referencing them non-stop. But you won't be getting it from me. Haha
#27
Well.... I had a fun day up in Beaverton. I got the front windows tinted on the FJ down to 18% to match the rears (knock on wood no cops notice)
And the FJ became a medical transport for my 4Runner's new heart!
Awe..... all safe at home on my engine stand with the medical transport and the patient in the background (No, that's not my 2nd gen on the left and I don't know who owns it but GOT DAMM that thing is clean!!!)
So I thought once I had the engine in my hands and the money out of my pocket, some of the nerves would be gone? Nope. I'm still nervous as hell about getting this put back together correctly. I started to put some bolts on and then I stopped. Definitely need to study my before pictures thoroughly. Plus, it's beautiful outside - who wants to be in a dark cold garage? :-D
#29
Thanks. The FJ is a sweet ride to have. I pay dearly for it monthly but I find it to be worth it. It's been to Brown's camp but not on any serious trails.
#32
Productive weekend. The motor is in!
Went from looking like this...
And then I test fit my mojaves to make sure they clear everything...
And then somehow the motor ended up here...
Injectors are with Witch Hunter getting rebuilt and then I'll be set to turn the key!
#34
Put the hood back on last night! Need my injectors back from Witch Hunter (Should be here tomorrow!) and then I'll put my intake assembly and hook vacuum lines back up and this baby should be ready to turn over!
Oh, and I need a new battery
#35
So I'm having a good day so far. I had some issues because I was just getting a "click" and the lights would dim when trying to start it. Checked my connections on the starter and then thought about how corroded my battery connections were. Installed a couple new battery connections and off we went.
Spun it for 2 minutes to get oil spread around, then installed my spark plugs and got the following. The RV cam isn't as rough as I kind of expected.
http://www.youtube.com/watch?v=SYcae...ature=youtu.be
I had lost one of the bolts that held my cold start injector in so I had a big vacuum leak through that hole. Went down to Napa and got a new bolt (that the guy gave me for free, love Napa) and ...!
http://www.youtube.com/watch?v=K6f2Y...ature=youtu.be
Temperature is still all over the place, I think air is still purging out of the cooling system but I probably need to buy a new radiator cap just to be safe. The one it has looks relatively old. 13 lb release is probably correct tho.
#36
So my starter took a ˟˟˟˟. Apparently the 87 starter doesn't have the ability to just change out the contacts on the solenoid? You have to replace the whole damn thing?
#37
You should be able to change out the origional Denso starter contacts on an 87. Are you sure it's origional to the truck? I have an 88 and I have the same part number for the starter as you.
#38
Yeah turns out I can change the contacts. I think my issue is elsewhere. It appears my top power steering line is worn through to the metal and contacting the hard line coming out the base of the reservoir. This leads to the line getting extremely hot once I connect the battery. Electric tape doesn't seem to fix it. Probably need a new hose. Thoughts? Ever seen this before? I think it's causing a drain and my starter is getting starved for juice
#40
Here's a picture. You can see on the foam insulator of the power steering hose where I put electric tape that its contacting the hard line out of the reservoir. Ideas?
