pre-purchase help for 1991 4runner with link - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Marketplace > Members Classifieds > Buying & Selling Advice - Feeler/Gauging Interest
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-25-2009, 09:16 AM   #1 (permalink)
pre-purchase help for 1991 4runner with Craigslist link
Hi, I am returning to this forum after selling my old 87 runner and looking at buying a 1991 4runner. Here is the link to the ad: http://cosprings.craigslist.org/cto/1430384464.html
What things should I look for? I test drove it yesterday and the gas pedal seemed really really stiff. It also smelled like it was running rich and it was really hard to get it to start moving. If you did not give it lots of gas it would stall out as soon as you let off of the clutch. Also, it had a terrible wobble in the steering wheel. I checked the CV-boots and they were both torn. It also looked like the upper passenger side ball joint bushing was torn and leaking grease. I potentially am going to trade my older Honda for this truck. I realize it looks like i will have a little work in front of me, but nothing I have not done before. It has about 185,000 on the body and drive train. The engine was is a Jasper rebuilt 22re about 20k miles ago. The engine looks clean, just it looks like it is leaking oil from either the front of the oil pan or from the front of the engine somewhere.
Just would like your opinions and what to look out for on a 1991 4runner. The lift was professionally installed and looks good.
skicopper is offline
Old 10-25-2009, 09:26 AM   #2 (permalink)
pwd
pwd's Avatar
Did the new motor he put in have a warranty? Are you willing to spend an unforeseen amount of time and money on this? I guess if you have the time and money, its not as much of an issue.Has it been re-geared to accommodate the larger tires? If your located in the rust belt, do the most thorough inspection you can. If you can get the VIN, call up Toyota and see if its eligible for any recalls (don't know if the lift voids any or not).
__________________
1995 4x4 ext. cab Truck 3.0L 5-speed
Bone stock, with Wab-Fab Shackles Rear Wide 6" $100
Acquired in May 07 , spent ~ $4400 on repairs so far:
Paint job, parking brake cable, rad re-core, new tire winch, brake lines, fuel line, Bremo rotors, Toyota pads, new calipers (in this order), all new exhaust excluding headers
1992 4Runner 4x4 3.0L Auto
Project Truck... the deeper money pit.
Update Nov. 19: Fully road worthy. New Tires Coming Soon.
pwd is offline
Old 10-25-2009, 09:30 AM   #3 (permalink)
The engine came with a 7 year warranty. However, I don't think it is transferable. It was not re-geared. The truck looked like it did not have any rust. Thanks for the suggestions about the VIN!
Old 10-25-2009, 09:43 AM   #4 (permalink)
Kiroshu's Avatar
Usually parts with warranties are void with the vehciles sold. I would look for rust, look up under it very good make sure everything is connected and not just hanging and nothing seriously broke... A stiff gas pedal is a sign of a bad throttle cable and is not serious you just gotta be a man and get used to the pedal and or replace throttle cable witch is prolly sticky and rusted. Check for leaks in engine area and cracks or hoses and parts.... if it does not sound like a sewing machine then then valves require adjustment and if it sounds like a diesel then you got chain slappin....... running rich could be alot things.... get codes? prolly vac leak or o2 sensor issue... exhaust leak....
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
(Still working on restoring her)
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
(sold)______________
(Was my fastest truck i miss her...)
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
(was my quietest and slowest yota.)
Kiroshu is offline
Old 10-25-2009, 10:04 AM   #5 (permalink)
The check engine light was not on. However, my wife did think it sounded like a diesel. From my experience owning an older 4runner, these trucks seem very reliable. I just hope this one is as well.
Old 10-25-2009, 10:10 AM   #6 (permalink)
Kiroshu's Avatar
yea 22r's tend to sound that way 90% its normal just need a lil adjustment.
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
Kiroshu is offline
Old 10-25-2009, 12:34 PM   #7 (permalink)
Quote:
What do you mean by unforeseen money? Do the 5 speed transmissions hold up past 200k miles? How about the transfer case and differentials?
Thanks
Old 10-25-2009, 12:43 PM   #8 (permalink)
22RUCRAZY's Avatar
I always look for mud in spots that are hard to clean to see if the truck has been beat offroad
22RUCRAZY is offline
Old 10-25-2009, 12:45 PM   #9 (permalink)
Are the CV axles and ball joints hard to replace? I figure if I could figure it out on my wifes Audi A6 Quatro, it should be easy on a Toyota.
Old 10-25-2009, 12:51 PM   #10 (permalink)
Send a message via AIM to fork
i would use all these problems you mentioned to knock the price down, buy it, and spend the difference on fixing it up.
it's a 22re 5spd. hard to go wrong with that, even if it needs a bunch of work
cv axles shouldn't be too hard. balljoints might be moderate though
fork is offline
Old 10-25-2009, 12:52 PM   #11 (permalink)
pwd
pwd's Avatar
I just meant that usually you always find something wrong/broken when you buy a used vehicle, regardless of how well you inspect it. Thats just how it goes. With my experience, it cost me way more than I thought (its still in the body shop) due to the rust problems that wouldn't allow me to get it certified. If it was maintained half right, it should be fine. I can't chime in about the gears/tranny, but I've never heard anything bad about the 5-speed. I've got one in my pickup and its 100% with 146k miles / 235 k kms. The previous owner replaced the clutch and thats it.
__________________
pwd is offline
Old 10-25-2009, 01:12 PM   #12 (permalink)
Yeah, I know what you mean now. Fortunately, most vehicles in Colorado are virtually rust free. One reason for asking all of you Toyota enthusiasts is that you probably know of what areas on the car to look for that most people might overlook. Especially knowing what problem spots to look for.
Old 10-25-2009, 01:20 PM   #13 (permalink)
peow130's Avatar
put it in 4wd to check for signs of bad CV joints or anything like that.
__________________
1987 Toyota Pickup DLX. 30" Cooper Discoverer S/T's. 1" AAL lift and Tbar crank. and two KC HiLites. IFS Club #5
1978 Camaro Z28, 454 Big Block V8 with a 4 Speed.
peow130 is offline
Old 10-25-2009, 02:12 PM   #14 (permalink)
CO 4runner's Avatar
I live in colorado springs and have seen that 4runner driving around.
My 5-speed has 195k on it and still works great. I replaced the master and slave cylinders on the clutch but thats about all i've done.
__________________
1991 toyota 4runner- 4inch Pro Comp Stage II lift kit w/ mx-6 shocks, 35" BFG KM2's on 17" ballistic jesters, hannemann fiberglass flared front fenders, hannemann fiberglass rear 4" fender flares, painted black. 3.4 needed soon.
CO 4runner is offline
Old 10-25-2009, 02:32 PM   #15 (permalink)
What do to get for gas mileage? My wife does not think this truck would be practical. However, practical and fun don't always go together.
Old 10-25-2009, 02:54 PM   #16 (permalink)
Kiroshu's Avatar
That toyota its not practical.... its a Toyota.... nothing more said. Now the fact that its a sec gen runner with a 22re 5-speed already makes it a rare find and a good buy. If its 90% rust free then i'd offer him 2500 cash and go from there. Go for it.
__________________
My current:
1986 Toyota 4runner
SR5 EFI
4cyl 2.4L 22RE
5-Speed
242,000 Miles
95% Stock
__________________
My old:
1988 Toyota 4runner
SR5
EFI
V6 3.0L 3VZ-E
5-Speed
302,000 Miles
All stock
My old:
1989 Toyota 4runner
Non-SR5
EFI
4cyl 2.4L 22RE
Automatic
231,000 Miles
Kiroshu is offline
Old 10-25-2009, 09:48 PM   #17 (permalink)
CO 4runner's Avatar
i have a 3.slow on my '91 but i'm guessing i get somewhere around 18 mpg. i havn't actually calculated it in a while.
__________________
Old 10-26-2009, 07:33 PM   #18 (permalink)
Quick Update: I took the 4Runner to the shop that put the Jasper engine in it. Here is what they found:
Exhaust leak at cat: $100
U-joints loose : $450 for all
Left front CV axle: $600
Front Wheel Bearings:$350
Front Brake pads: $200
Parking break inoperative: ??? didn't know how much$$$$$$$
front crank seal leaks oil: $650 (supposedly covered by Jasper)
Engine runs poor, needs valve adjustments, timing adjustment, plugs, wires, etc.. $89.99
Lower coolant hose soft: $150
Grand Total: $2615
The Bad: The clutch was replaced at 166,000 miles when the engine was done and now it has 188,000 miles on it and the tech made a note that the clutch disk may be getting low, a little hard to get into gear. Also, he stated that it runs poor- rich- thus recommending a complete tune up.
The good news: There is a transferable warranty on the engine that still has 1 year left on it. the front crank seal is covered under the warranty. The prices for the parts/ labor seem steep, a good way to negotiate the price. I can do most of the work for a lot cheaper myself. From what I have listed, what do you guys think my costs would be for the parts? I also did not mention I personally think the starter needs to be replaced, which on my last 4Runner was a PITA!!!!
Old 10-27-2009, 09:30 PM   #19 (permalink)
CO 4runner's Avatar
I broke the parking brake on my 91 a couple months ago. The cable just snapped. It's an easy fix, nothing to be scared of.
__________________
Old 10-27-2009, 09:58 PM   #20 (permalink)
Ardent's Avatar
Quote:
U-joints loose : $450 for all No way.
Left front CV axle: $600 I just replaced both of mine last week for $130 for Napa Remans. That includes the core charge.
Front Wheel Bearings:$350 Should be closer to $150 + grease and seal.
Front Brake pads: $200 New Toyota pads are around $80 and another $30 to turn your rotors at Checker/O'Reily.
Grand Total: $2615
Those prices seem really high. I replaced my CV shafts, did a full front brake job (new pads/ turned rotors), and repacked the wheel bearings last Saturday. Total cost was around $260 (see above). And the lower coolant hose is around a $12 part.
Definitely use those numbers for your negotiation, but do the work yourself. Good luck!
__________________
Nate
1993 3.0 Pickup - 4" lift, 33x10.50s BFG KM1s.
1995 4.5L FZJ80 - OME springs, Locked. Nitto Terra Graplers.
Sold:
1993 3.0 4Runner - Fj80 Coils, 1.5" BJ Spacers
1987 2.4 4Runner / SAS'd / Got it Running!/ Project truck...
Just bought my FZJ80...
Ardent is offline
Tags
1991, 1992, 4runner, 97, black, cable, fender, flares, hard, linkage, replacing, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
