YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > YotaTech Community > 4ROC (4Runner Owner's Club) > 4ROC > California SoCal
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 02-04-2006, 06:56 PM   #1 (permalink)
Expat's Avatar
Steel fabrication work required
Anyone recommend someone in SoCal (prefereably around the Ventura LA counties line) who can do fab work. I pretty much destroyed a trailing arm mount and need it either bent back and strengthened or cut off and a new one made up.
Thanks
Mark
__________________
Mark
04 4Runner SE,275x70x17 MTR's, Shrockworks Bullbar, Shrockworks Rock Sliders, 1.5" 4Crawler Body Lift, Kurt trailing Arms, OME Suspension, MagnaFlow muffler, 60" High Lift Jack, Yaesu FT-7800 Ham Radio, Diamond Magnetic Mount Antenna, Cobra 75WX ST CB radio, Wilson 5000 Antenna, Sirius Satellite Radio, Garmin iQue GPS, On-board CO2 system.
Expat is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Sonoran Steel Work Truck - 1990 4WD Mini Pickup - Featuring the Mighty 28's sschaefer3 Trucks, 3rd gen-'89 to '95 3 01-14-2007 02:57 PM
DAYSTAR 4th Gen 2.5" Lift - $229.95 Through Sonoran Steel Fabrication. sschaefer3 Vendor Advertising 32 04-28-2006 09:52 AM
Steel fabrication work required - SoCal Expat The Fab Shop 15 02-17-2006 09:58 AM
Steel toe work boots Corey Off Topic Talk 28 01-12-2006 12:23 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
