| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
need throttle body boot that goes to turbo pipe . for 86 sr5 22rtec.
#2 (permalink) |
http://www.extremepsi.com/store/cust...at=1538&page=1
here is the place to buy after market silicone turbo boots for tb 4 ply and i also have another site for a 5 ply that i just bought works good |
#3 (permalink) |
to get the factory like one, probably just a dealer....
good find on the aftermarket stuff though.
__________________
Cory Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here 04 Dodge 2500 Cummins - DD/Tow Rig 02 Z06 Corvette - Weekender 94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727 72 Buick GS - i.e. the project that will never get done. |
#5 (permalink) |
alright ive got my part put it on didnt fix my problem but a very good product bought
#6 (permalink) |
whats your problem?
__________________
#7 (permalink) |
problem with 86 22rtec
ive rebuilt my engine put new parts on it such as mass air flow fuel pump tps timing is on. But engine wont stay running runs for 5 sec then shuts off it willl restart but will only run for 5 sec.
#8 (permalink) |
oh by the way i did find the connectors i need just a few sec ago a site called automotix very good site for these trucks
#9 (permalink) |
are you sure you're getting adequate fuel? it almost sounds like the fuel pump is being ran for the start sequence, but then it doesnt stay running during the run ignition position...
__________________
#10 (permalink) |
Yup, sounds like it's sucking in air downstream of the MAF. I'm not sure if this works on Toyota's (but I bet it does).... With the truck off unplug the MAF. Then start it up. It should default to open loop control and run without the sensor connected. It won't work if you pull the plug after the key is already on though.
If it does the same thing in open loop control, then I'd check the fuel pump.
__________________
I own 11 vehicles... 10 of which are ongoing projects. I need to sell some stuff so I can turn the 11th into a project. Let me know if you're in need of a Yota transfer case, solid front axle, 22R motor, or rear axleshafts. I promise all proceeds will be directed back into the local 4x4 economy (Ok... Marlin may get some of the money) . |
#11 (permalink) |
The 22RTE is sensitive to vacuum leaks between the MAF and the intake manifold runners. Hook up a vacuum gauge and see what the vacuum is while running. I'll compare it to mine for you. When I first put my engine in I had the same problem because I forgot to tighten up the EGR pipe on back of the manifold. You need to check all of the intake pipe hose clamps between the air cleaner and the turbo and then to the intake manifold. Make sure you have no vacuum leaks.
I heard the turbo pipe connector was no longer available from Toyota, but I have not checked for myself. I would like to replace mine with a silicone one as it is getting hardened. I just bought it used but they will blow out and I already had to stop drill a nice crack.
__________________
Kristopher Erik "KD5EJO" Transplanted Alaskan in Foster OK 88 X-Cab now with 22RTE/CT-20, 87 T4Runner stock 22RTE/CT-20, 93 FZJ80 Landcruiser w/e-lockers FOR TOP NOTCH CARBURATOR OVERHAULS CLICK HERE http://www.yotatech.com/f37/ekhi-cus...turing-162085/ Like Fishing, hunting, Ham radio, flying, canoeing, kayaking, traveling, all the better with friends. Dedicated Christian. Excellent Wife. 3 Very Good Sons. Any other questions? |
#12 (permalink) |
this is the site for the turbo psi intake coupler boot new aftermarket |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1985 4Runner Tail Pipe turbo install | RandyatBBY | 84-85 Trucks & 4Runners | 8 | 07-08-2008 06:34 PM |
| 86 22rtec turbo . rebuliding turbo help!! | rvsmichael | 86-95 Trucks & 4Runners | 1 | 03-17-2008 09:41 AM |
| WTB: 2001-2002 Throttle Body or Throttle Position Sensor (TPS) | Andrey | The Classifieds GraveYard | 7 | 01-11-2008 11:59 AM |
| 22rtec coolant pipe needed | Corrugated | 86-95 Trucks & 4Runners | 0 | 10-23-2006 12:02 PM |
