| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Got my new trail Toy!
__________________
Trail/Build Rig: 1981 Toyota Pickup 4x4, flatbed Tow Rig: 2001 Chevy 2500HD Duramax 4x4, X-cab Long Bed. Will be my tow rig, when I get a trailer. RIP: 1995 4Runner. Last edited by Injohneer; 05-23-2009 at 03:58 PM. Reason: I quit looking, now I'm enjoying... |
#2 (permalink) |
nevermind, found one.
__________________
Trail/Build Rig: 1981 Toyota Pickup 4x4, flatbed Tow Rig: 2001 Chevy 2500HD Duramax 4x4, X-cab Long Bed. Will be my tow rig, when I get a trailer. RIP: 1995 4Runner. |
#3 (permalink) |
Staff
__________________
1985 4Runner 22RE 4WD "Ratchet" 2007 Tacoma Double Cab SB 4x4 V6 TRD Sport AR-TTORA "My work number is 9-1-1." |
#4 (permalink) |
![]() Got it for $850 no gauges hooked up after somebody swapped in a different engine Starts most of the time with a little extra pumping, and it won't idle (acts like a fuel problem) so I ran the idle screw up to give it around 1200 RPM or so, just to get it home Lights aren't hooked up either, 3 wires sticking out under the dash will give front, side, and tail lights if you jam them up in the fuse box. It was real fun driving home at night. sway bar connectors are torch'd off, the driver's front shock is in the bed (they unbolted it instead of torching). On the driver's side of the front axle there's a bracket & linking rod that connects to the frame, to keep the axle housing from rotating - what's that called? Anyway they torched it too. Gotta love that redneck flex! I mentioned the engine was replaced, I'm not enough of an early toy expert to know if it's a 22R or 22RE, where do I look for markings? (don't tell me, I will use the search button) It uses some oil, most of it leaks through the timing / water pump cover seal. Oh, and the oil on the dipstick was pretty black. The 5 speed transmission (was that standard for an '81?) seems to shift well and the 4x4 works (tried out 4x4 low, didn't try 4x4 high yet). Steering is real sloppy with a lot of play before you start turning, but amazingly the thing is aligned. I drove it about 90 miles Tuesday night and only had to turn the wheel when the road curved. My plans for this truck are to strip it down and make it minimalistic. I'm thinking an all-metal dash, possibly a custom instrument cluster, a custom switch panel for heater controls, lighting, inverter, CB, etc
__________________
Trail/Build Rig: 1981 Toyota Pickup 4x4, flatbed Tow Rig: 2001 Chevy 2500HD Duramax 4x4, X-cab Long Bed. Will be my tow rig, when I get a trailer. RIP: 1995 4Runner. Last edited by Injohneer; 05-23-2009 at 11:59 AM. |
#5 (permalink) |
flippin sweet.
ok...if its got a carb, its a 22R. if its fuel injected its a 22RE. However what you want to know is if its a later model block and head so you can convert it to fuel injection. Easiest way to tell is bring it 4wheelin June 5-7th at hot springs and let me look at it.
__________________
Cory Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here 04 Dodge 2500 Cummins - DD/Tow Rig 02 Z06 Corvette - Weekender 94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727 72 Buick GS - i.e. the project that will never get done. |
#6 (permalink) | |
Quote:
I knew you would try to get me on the trails ASAP.However, there are many things it needs before I drive it anywhere else: radiator flush, carb cleanup, brakes that feel safe, oil change, lights that work... And most of that stuff is on hold for a month or so because my chevy really needs a brake job and carrier bearing ... besides that, playing with the yota takes 2nd place when my kid's in the hospital (been in for about a month now, has had 3 surgeries this round, still not back to taking food by mouth yet.) But I'll probably grab the camera this weekend and take a bunch of pictures!
__________________
#7 (permalink) |
yeah, right.... no time for the camera when I could actually be working on the truck.
Yesterday I spent a couple hours removing junk out of the cab...bottle rockets, sparklers, old pop cans, one bag of unopened cheetoes, water bottles, floor mats, ... a good pair of pliers, etc. When I drove the truck on anything bumpy my thought was...something's loose. I wonder if the cab is fastened to the frame? Imagine my lack of surprise that two of the three cab mounts on the left side are completely unattached...rusted through on the cab, so I can pick it up off the frame. So I guess I need to work on the cab mounts. Sounds like some fabbing is in order...oh and a good time to do a 2" body lift. Know of any pics of reputable repairs in that area? The other loose thing was the seat, it's a bench seat that is bolted down only (loosely) in the front. Must be a doner seat, after all I was surprised how good the material looked for its age.
__________________
Trail/Build Rig: 1981 Toyota Pickup 4x4, flatbed Tow Rig: 2001 Chevy 2500HD Duramax 4x4, X-cab Long Bed. Will be my tow rig, when I get a trailer. RIP: 1995 4Runner. Last edited by Injohneer; 06-07-2009 at 02:33 PM. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Lookin | fearlessfree | The Classifieds GraveYard | 1 | 03-11-2008 08:10 PM |
| TH350 toy adapter & 4.7 toy case | lizard lips | The Classifieds GraveYard | 9 | 02-06-2008 07:46 AM |
| My cheap 2.5" exhaust on the cheap | tortis | 86-95 Trucks & 4Runners | 2 | 10-06-2007 07:18 PM |
| Cool Cheap Rc Toy | CyMoN | Off Topic Talk | 20 | 02-09-2007 05:02 PM |
| Lookin to make a cheap lift | Carolina_yota | 84-85 Trucks & 4Runners | 7 | 06-08-2006 08:23 AM |
