Help I'm stupid - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Regional Forums > 4ROC > Ozarks
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-02-2009, 01:57 PM   #1 (permalink)
ADH8796's Avatar
Send a message via AIM to ADH8796
Help I'm stupid
I have an 85 4runner with a 22re. I'm an idiot and pulled my distibutor out without marking anything now I need to find out how to put it back in (the right way) so that my engine will actually fire. Can someone help me out here and give my some directions on how to put my distributor back in so that it's in the right timing and will actually fire. Thanks!
Anthony
ADH8796 is offline
Old 02-02-2009, 05:14 PM   #2 (permalink)
eric-the-red's Avatar
You have to get the #1 cylinder to top dead centre, on the compression stroke. The tdc mark on the crank pulley will line up with the timing mark, and both valves will be closed. It's easy to accidently get tdc on the exhaust stroke, which is not good. Then replace the distributor so the rotor is pointing to #1 terminal. Some have a mark for #1, some don't, but you'll see it lined up with where the #1 on the cap is.
On some distributors the shaft turns when installing it so you have to allow for that, and start with the rotor pointing to one side of #1. I've never worked on a 22RE so I don't know how much, if any it will turn. You just have to use trial and error.
After it's installed set the timing correctly.
__________________
2001 4Runner
4.30 ratio 1999 e-locked rear axle and front diff;
OME881/N91S front; OME891/N86 rear;
Tundra brake swap;
1" 4Crawler body lift;
63" 4Crawler SliderZ;
TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line;
265/75R16 Nitto TGs or 255/85R16 Truxs MTs;
Cobra 75 WX ST cb;
Alinco DR635 VHF/UHF ham radio;
ham call sign license plates - VE7 EGC
eric-the-red is offline
Old 02-02-2009, 06:06 PM   #3 (permalink)
ADH8796's Avatar
Got it thanks!
ADH8796 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Stupid, stupid, stupid (I hope I found source of front end noise anyway) navyredneck 86-95 Trucks & 4Runners 1 10-28-2006 08:01 PM
Stupid IS as Stupid Does.......Best prank in history Mason Dixon Off Topic Talk 145 11-16-2005 04:56 PM
stupid stupid me....... Toyrantula Vehicle Audio & Home Entertainment 2 07-21-2005 12:40 AM
Stupid stupid spark plug hole!!! ksurfer Maintenance & Repair Archives 1 07-03-2003 10:18 AM
2009 InternetBrands, Inc.
