| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22RE issue
#2 (permalink) |
Watch it idle at night, it's better than the 4th of July. Cory's spark plug wire routing leaves something to be desired
__________________
I own 11 vehicles... 10 of which are ongoing projects. I need to sell some stuff so I can turn the 11th into a project. Let me know if you're in need of a Yota transfer case, solid front axle, 22R motor, or rear axleshafts. I promise all proceeds will be directed back into the local 4x4 economy (Ok... Marlin may get some of the money) . |
#3 (permalink) |
I think what hes trying to say is check for miss-firing due to sparkplug wires or bad plugs.
__________________
Cory Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here 04 Dodge 2500 Cummins - DD/Tow Rig 02 Z06 Corvette - Weekender 94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727 72 Buick GS - i.e. the project that will never get done. |
#4 (permalink) |
new plugs and wires so I know that's not the problem (I checked all of them to make sure)
#5 (permalink) |
you seen any oil leaks around the head gasket?
__________________
94 pickup reg cab 5spd 4x4 22re - blown 00 tacoma ext cab auto 4x4 5vz |
#7 (permalink) |
Clogged injector??
#9 (permalink) |
fouled plug? even new they can be bad ya know I just had this happen with my 3.no and thats what the issue was , brand new Nippion Denso plugs even
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#10 (permalink) |
Nope all the plugs are good. Moved them around a few times and the second cylinder is the only thing not firing.
#11 (permalink) |
what about distributor cap and rotor?
__________________
#12 (permalink) |
Cap and rotor look good but I haven't replaced it or anything. I've pulled the plug wire on the 2nd cylinder while the engine is running and it apears to be working just fine.
#13 (permalink) |
how do you know the second cylinder isnt firing?
__________________
#14 (permalink) |
When I pull the plug on the second cylinder nothing changes at all.
#15 (permalink) |
ok, leave the plug attached to the ignition wire, ground the plug on the valve cover gasket and start the motor. then see if the plug itself is firing, lemme know what you find.
__________________
#16 (permalink) |
Super Moderator-Sponsoring Member
Staff
Toyota or aftermarket plug wires?
Some of that cheap aftermarket Toyota stuf is just that...cheap crap. Had a buddy with the exact same problem and it was his new aftermarket plug wires.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. |
#17 (permalink) |
Yes the plug is firing when grounded to he balve gasket. And it's clear that the cylinder is building plenty of compression (crazy loud). It seems like the only think that might make since is that fuel isn't getting into the cylinder. But I don't know?!?!
#18 (permalink) |
ya, you've got a fuel issue... check the connector on the fuel injector to make sure its securely on there... if it is, I'd say look into getting some injectors (I have a few lying around)
__________________
#19 (permalink) |
The connection is good. I moved the injector from cylinder 1 to cylinder 2 because I knew it was working in cylinder 1. Anyway it's not working in cylinder 2 so I'm thinking something is wrong with the wiring for cylinder 2 injector (it's not the actuall injector). But I'm not really sure where to start as far as finding the problem.
#20 (permalink) |
are you leaking fuel out around the injector or do you have any kind of gas smell, and is the injector properly seated?
I'd almost be tempted to pull the connector off of the injector and check it for voltage signals using a multimeter
__________________
#21 (permalink) |
Not leaking any fuel (no fuel smells) and the injector is seated properly.
Being that you have to take the whole intake manifold off to get to the #2 injector I'm not sure how I'd check to see if it had voltage without putting everything back together and leaving the plug in a place where I could actually get to it. |
#22 (permalink) |
maybe pull the schematic for it and see if you can tap into it at the computer?
__________________
#23 (permalink) |
new symptom I now only have two cylinders the 1st and the 2nd aren't firing
#24 (permalink) |
so no fire with the spark plug grounded on the valve cover?
__________________
#25 (permalink) |
Follow the FI harness from the injectors all the way back to the computer. Sounds like the harness may be chaffed/pinched.
__________________
| Tags |
| 22re, 2nd, cylinder, fire, firing, miss, routing, toyota, wire |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE issue | ADH8796 | 84-85 Trucks & 4Runners | 5 | 11-13-2008 01:28 PM |
| 22re idleing issue | yotakid825 | 86-95 Trucks & 4Runners | 4 | 01-04-2008 01:02 PM |
| 22RE Idle Issue | blb | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 01-02-2006 02:32 PM |
| 22RE idle issue? | dave151 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 10-24-2005 12:48 PM |
| 22RE 93 Temperature Issue | simplify | Maintenance & Repair Archives | 0 | 06-21-2005 06:51 PM |
