Total Chaos Spindle Gussets (with use of sway bar)
Total Chaos came out with a gusset that retains the use of the swaybar.
The clearance is tight with 4.5 backspace, but I do clear. They recommend spacers with stock wheels. I believe they could be slightly modified to work with stock wheels.
Here is a How to on the fab work
Total Chaos spindle gusset(with swaybar). How to.
Here are a few of the tools and equipment needed for doing this modification
Gussets
Spindle
Welder
Grinder
Goggles
Gloves
Various other tools as you go
You will want to go through a series of test fit sessions
The gusset kit comes with 2 of the top plate pieces of different thicknesses
You need to use the one that fits best. As you can see the one I have here is the thin one and it has way to big of a gap
This one is much closer
Here is the added gusset that reinforces the tie rod area
I originally used my 4.5 inch grinder to clean the surfaces but found my dremel useful to get all the curves and bumps. All areas that are welded need to be ground clean, for better penetration.
I didn’t have a bolt readily available to secure the top piece so I clamped it. To keep it center in the exsisting hole I used a allen wrench of that diameter . A little unconventional but it worked great
Installing the link, is mandatory, to make sure the hole lines up
After cleaning everything with carb cleaner, I tacked everything into place
I welded it in different areas, to keep the heat down. Eventually after some cleaning up, it looked like this
Then some black paint.
Installed
Gussets
Spindle
Welder
Grinder
Goggles
Gloves
Installed
justdifferentials
14
06-11-2017 08:36 PM
nvwiggins
13
06-16-2016 03:05 PM
FS[FourCorners]: First Gen Tacoma/4Runner Manual Hub Spindles
G-off
12-29-2015 12:44 PM
potatopants
09-15-2015 06:26 AM
