All-Pro/Currie Iron Jock 60 Rear End Installed! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > FJ Cruiser
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-13-2008, 05:05 PM   #1 (permalink)
This is the new All-Pro / Currie Iron Jock Dana 60 rear end for the FJ Cruiser installed into Jons SAS equipped rig. This is the ultimate cure for the broken rear ring & pinion sets common to the FJ with the stock rear end. Better clearance under the driveshaft is attained though the high pinion design, and the beefier 9.5" ring gear (compared to the 8" OEM Toyota setup) really adds strength. You also have less to get hung up on as the entire underside of the differential section is a smooth radius that slides over rocks, with NO LOSS OF GROUND CLEARANCE! And for those wondering about the brakes; it uses the factory setup, so the ABS and A-TRAC are fully functional. As a bonus, you also get a 3 position adjustable panhard mount bracket standard to keep your axle in the correct position regardless of the amount of lift you have installed. Pricing for the axle is about $2100 (Anti-Rock sway bar not included) plus your choice of gears and differential, and we will have them in stock in about 2-3 weeks.
Rockrawler is offline
Tags
60, axle, axles, cruiser, currie, end, fj, installed, iron, ironjock, jock, pro, rear, rock, strength
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
swapping out V6 rear end to 4cyl rear end 89yota_mudrunner 86-95 Trucks & 4Runners 11 02-07-2008 08:46 PM
New pro-comp shocks installed and clearance issue SKNKWRX 86-95 Trucks & 4Runners 10 12-16-2007 07:22 AM
installed 390cc injectors this pas w/end jrock 95.5-2004 Tacomas & 96-2002 4Runners 6 03-20-2007 03:45 PM
All Pro Bumper and rock rails installed WillsFJC FJ Cruiser 15 09-26-2006 06:31 PM
Installed Pro Comp ES 9000 shocks Highland Runner 95.5-2004 Tacomas & 96-2002 4Runners 21 02-13-2004 05:26 AM
2009 InternetBrands, Inc.
