whining noise ? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-01-2009, 08:59 AM   #1 (permalink)
whining noise ?
just got my truck on the road. after replacing rear wheel bearings/seals. gas tank, and some body work. and i noticed while driving im hearing a pretty loud whining noise coming from under the truck but it's only when i'm on the gas. if i let off its all quiet. is it the rear diff? or maybe the center bearing? i grabbed the drive shaft and gave it a few yanks and it moves around pretty easily
nikh713 is offline
Old 10-02-2009, 02:29 AM   #2 (permalink)
The drive shaft moves easily side to side? Sounds like you got some bad U-Joints...
BamZipPow is offline
Old 10-02-2009, 05:39 AM   #3 (permalink)
it has a light clunk when i get on and off the gas too, also vibrates at lower speeds
nikh713 is offline
Old 10-02-2009, 10:50 AM   #4 (permalink)
Definitely U-joints!
Old 10-08-2009, 08:56 AM   #5 (permalink)
i checked the u-joints they're fine. if not in gear, the axle moves back and forth like i'm twisting the throttle on a motorcycle, it moves quite a bit until it grabs in the rear i believe. i'm thinking that my rear end is clunking when i take off or get on the gas because of this free movement.
nikh713 is offline
Old 10-08-2009, 05:08 PM   #6 (permalink)
Sounds like the pumpkin/third member will need to git pulled and checked/rebuilt then.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
