Wheel Fitment and Backspace - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-13-2009, 10:16 PM   #1 (permalink)
Hey guys I was wondering what's the best backspace to go with the T... I'm going with a 15/8 Pro Comp Rock Crawlers but I have no clue with the backspace... Im currently riding on stock wheels with bfg all terrains 32/11.5/15's! I want it to be poking out a bit also... Please can someone post some pics of how it would look.Thanks
Kirbyt100 is offline
Old 10-14-2009, 09:00 AM   #2 (permalink)
4Crawler's Avatar
You can easily measure the back spacing on the wheels you have and go from there:
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/24.html
And how does back spacing and wheel width affect track width?
- http://www.4crawler.com/Diesel/Tires...ningTrackWidth
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-14-2009, 10:10 AM   #3 (permalink)
tj884Rdlx's Avatar
11.5s will stick out on either backspace available. the lower the number, the farther they will stick out. i went with 3.5 on my 15x8s and with 10.5" skins they just come outside the fender well. you'll have another inch of rubber.
bear in mind when turning full lock you may rub the outer edge of the tire if you don't have some lift
__________________
88 4Runner DLX, 15x8 soft8s w/ BFG 33x10.5 A/Ts. 1.5" SDORI spacers, OME CS009s, 1" 4crawler b.l., original Canback top
tj884Rdlx is offline
Old 10-14-2009, 02:52 PM   #4 (permalink)
so whats the best backspace for me without me rubbing
Old 10-14-2009, 03:01 PM   #5 (permalink)
4Crawler's Avatar
The closer the backspacing is to stock the less likely the tires are to rub. Why? The closer the wheels/tires are to the body, the smaller the arc they sweep out while steering and it is when that arc of the tire intersects the arch of the wheel well that you have rubbing:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-15-2009, 02:06 PM   #6 (permalink)
tj884Rdlx's Avatar
well, the catch with that width tire is without some lift, you may rub regardless of back space.
if you have a smaller backspace, like 3.5", you move the wheel out, and can rub the outer edge of the tire. with a 4.25" backspace, you risk rubbing the inside edge of the tire. it depends on your lift, if any, and the actual size of the tire, which varies by manufacturer regardless of the size they "name" it.
do you have any lift at all?
__________________
Old 10-15-2009, 06:18 PM   #7 (permalink)
Matt3203's Avatar
this is a t100 here not a pickup
t100s can fit 33s with tbar crank
__________________
1994 Toyota T100 reg. cab, V6, 5spd, 4wd, 32x11.5 maxxis bighorns on cragar soft 8s
Matt3203 is offline
Old 10-15-2009, 06:41 PM   #8 (permalink)
No lift... stock rims... BFG ALL T.
Old 10-15-2009, 06:43 PM   #9 (permalink)
so im thinking of purchasing the cragar soft 8's 15/8 4 inch backspacing...
Old 10-17-2009, 11:09 PM   #10 (permalink)
tj884Rdlx's Avatar
aw jeez, my bad. i did not see T100. if you do go with soft 8's, i can recommend summit racing for price. i got mine there for $40 each i believe. i was able to pick them up at the local store though.
__________________
Old 11-11-2009, 08:02 PM   #11 (permalink)
93yotaSR5's Avatar
I have 31x10.5x15. Should I get 4 or 3.75 in back spacing? I have a 4crawler 1" body lift on the way.
__________________
93 xtra cab, 3vze, 5speed, 31x10.5x15 bfg M/T KM2
hella 500ff. cobra cb, front and rear diff breather mod, many more coming!
93yotaSR5 is offline
Old 11-11-2009, 08:05 PM   #12 (permalink)
4Crawler's Avatar
Either will work, stock is around 4.75" so your tires will be sticking out wider than they do now.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Tags
115, 32, 97, backgspace, backspace, backspacing, houston, out, sticks, stock, t100, tires, toyota, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
