| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
what is the stock gear size is for a T-100
__________________
3.0, automatic, used 31x10.50 BFG MT's on 15x10 rebel wheels moog rear springs 14x,xxx miles, still so young Last edited by waskillywabbit; 03-13-2009 at 06:41 PM. Reason: Pointless original title for searching |
#2 (permalink) |
4.10's usually came in manual transmission 4x4 trucks, 4.30's in auto transmission 4x4 trucks.
__________________
96 White T100 4x4 Extracab, Lifted, locked, & 35s Currently out of service due to roll over. Pending body work, SAS and rollcage |
#3 (permalink) |
My t100 is a 93 4wd manual trans with the bigger tire and wheel package. My stock ratio is 4.70:1 (trust me. I counted when I had it all apart. 47 teeth on ring gear, 10 on pinion)
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals 17" Powder coated Sequoia wheels 32" Mickey Thompson Baja ATZ tires stock lift new factory clutch- if you order from Downey, make sure you get the right one:( diff breather mod. cobra cb custom rear bumper w/tire carrier-Kennasaw Mtn. acc. In the works. light bar and hella 500's |
#4 (permalink) |
you could always check the gear code on the door frame.
__________________
92 toyota truck 3.4 5spd 4.56 gears magna flow cat and muffler2 1/4 piping isr mod to intake 1.5 bjsfront add a leafs and 2inch lift shackles rear rancho shocks all around sitting on 265/75/r16 nitto terra grapplers |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Quick question Quick answer re CB | Expat | GPS & Communication | 18 | 03-08-2005 09:52 PM |
| Quick question on quick disconnects... | WSU4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 07-25-2004 07:27 AM |
| I need a quick answer for a quick question | Tacoma Dude | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 08-22-2003 01:37 PM |
| TV help, quick | Corey | Off Topic Talk | 48 | 02-09-2003 10:28 PM |
