| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
vacuum solenoid
#2 (permalink) |
Found a VSV for '95 T-100
Well, I found a salvage yard that says it has the vsv for my automatic 4wd. I am just afraid it is probably in the same condition mine is in. They want $50 for it. It's 150 miles from me. Sounds kind of pricey.
It's off a '95. Think I should maybe hold out and try to find a part from a later model T-100 or 4-runner or Taco? |
#3 (permalink) |
Have you tested yours? Coil should have a small resistance (under 100 ohms) and the solenoid should "click" with power application. If that is OK, check for free air flow through when powered up. If blocked, try cleaning the air passages and see if you can open them up. I still have the original VSVs on my '85 4Runner, they last a long time.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
I posted the manual pages with tests on the link below.
http://forum.ih8mud.com/95-gen-toyot...-problems.html
__________________
94 FZJ80 fully locked, OME lift, 285s; 95 T100 beater edition; 1995 LS 400. No problem, I'll tow the pig with a Uhaul Trailer... "A vehicle's capabilities are inseparably linked to the mental instability of the driver" |
| Tags |
| 1st, 20, 4runner, 4wd, 85, add, cheap, gen, ohms, resistance, solenoid, t100, toyota, vacuum, valve |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Anybody parting out 96-01 4wd 4runner?? (need 4wd vacuum solenoid) | AznSky | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 12-30-2007 08:56 AM |
| Starter Solenoid | Guardian_Saint | 86-95 Trucks & 4Runners | 5 | 12-13-2007 04:42 AM |
| Anyone know where the "vacuum switch solenoid" is it? | AznSky | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 07-26-2007 02:13 PM |
| Can you Name This solenoid? | elnido | 93-98 T100s | 4 | 01-11-2006 02:42 PM |
| Transmission Solenoid | Legacy 4Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 08-28-2005 07:38 PM |
