YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-29-2007, 10:36 PM   #1 (permalink)
toyota t100 4wd disk removal
Has any on e out there replaced the brake disks on a 95 4wd toyota xtra cab SR5?
I cant figure out how to get the disk off,I have tried removing every bolt around it and looks like it might need a pull tool, can anyone help out there?
joedirt724356 is offline
Sponsored Links
To remove this ad, register today!
Old 09-29-2007, 10:59 PM   #2 (permalink)
Knuckles's Avatar
Send a message via AIM to Knuckles Send a message via Yahoo to Knuckles
you mean rotors? its easy just unbolt the caliber. it only has two bolts.
__________________
97 Limited 4Runner
Knuckles is offline
Old 09-29-2007, 11:02 PM   #3 (permalink)
CJM
CJM's Avatar
You mean the front rotors?
Unbolt caliper and housing, remove hub-it will come right off.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 09-30-2007, 09:55 PM   #4 (permalink)
It looks like it should slip off but thay are frozen on.I have removed the calipers and the grease cap and the bolt under it. I guess I could hit it witha hammer but I dnt want to jack anything up.
Old 09-30-2007, 10:00 PM   #5 (permalink)
also the hub wont come off ether
Old 09-30-2007, 10:19 PM   #6 (permalink)
CJM
CJM's Avatar
You unbolted all the bolts around the hub, then removed the cone washers?
http://www.4x4wire.com/toyota/tech/autohub/
If that doesnt work then I am stumped, you gotta remove the hub assembly to get the rotors off period, there is no other way.
__________________
CJM is offline
Old 09-30-2007, 11:43 PM   #7 (permalink)
OK I will remove the cone washers tomorrow and will post back. I have read a couple of threads on it and I will bet it is it. I missed a good wheelin weekend becouse of this,but I hate paying the shop.
thanks
joe d dirt
Old 10-03-2007, 09:38 PM   #8 (permalink)
remove wheel
remove caliper and hang it out of the way,
remove hub assembly, youll need a 54mm socket to remove the entire spindle assembly, from there the hub and rotor will slide off, careful not to drop those bearings in the dirt, 14mm socket to remove rotor from hub...clean/repack bearings while your in there,
little more involved than a Mustang front end where the caliper unbolts and rotor slides off...but not too difficult..
Jake97T is offline
Old 10-05-2007, 07:18 PM   #9 (permalink)
Froggy93's Avatar
pull the calipers off. remove the grease cap. remove bolt and washer under grease cap. remove six nuts and washers that hold hub end cap on. if it won't come off to easily, there are two threaded holes in the end cap that can be used to pull cap off. find the right bolts for the hole and start treading them in. they will hit against another part of the hub and push the cap off. once the cap is off, remove the big nut and washer that secure and preload the bearings. pull rotor and hub assembly off the spindle. let us know how things go and post picture of your hub and rotor if you are havinbg trouble.
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals
17" Powder coated Sequoia wheels
32" Mickey Thompson Baja ATZ tires stock lift
brand new factory rear axle housing, seals, brakes, everthing but origional axle shafts and third member.
new factory clutch- if you order from Downey, make sure you get the right one:(
diff breather mod.
Froggy93 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
T100 Pro Comp 4WD Lift Kit motodad171 Axles/Suspensions/Tires/Wheels 1 02-02-2007 07:06 PM
Replacement rear shocks for T100 4wd- what would have SOFTEST ride quality? Tennesseestorm 93-98 T100s 6 11-04-2006 09:53 AM
93 T100 4wd Jmunk Vehicles - Trailers (Complete) 4 06-18-2006 12:54 PM
'95 T100 axle housing-'90 4Runner gears (4WD) 90toyrunner 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 2 12-07-2005 07:06 AM
'95 T100 axle housing-'90 4Runner gears (4WD) 90toyrunner 95.5-2004 Tacomas & 96-2002 4Runners 2 11-10-2005 04:10 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
