Torsion Bars - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-23-2007, 06:19 PM   #1 (permalink)
offroadie's Avatar
Torsion Bars
Has anyone done any work on their torsion bars? When I got my T, the guy that had it before me tightened those things DOWN to level the front end. It sits nice, but the ride is a little jittery. A local shop said to give 'em some slack to soften the ride, but it'd also lower the stance...
So, I go to try and back the bolts off, and they're so rusted that I'm worried that I'm going to snap 'em! I'm currently working the entire contents of "liquid wrench" can on 'em slowly (daily dosage).
Any tips/pointers/suggestions? Also, if I torque these things in half - where can I get new ones for a reasonable price? Upgrades?
ting...ting...tiiiiing...
__________________
Try to keep the rubber side down...
'88 SR5 Xtra Cab, 3VZ-E/5-spd, Marlin Crawler shifter kit, ASIN hubs, Pro Comp 31x10.50 A/T's, Radio? CD player? Bah!
'02 PreRuner TRD Supercab, 3.4l, locking diff., camper top,
offroadie is offline
Old 12-23-2007, 06:35 PM   #2 (permalink)
seafarinman's Avatar
Send a message via AIM to seafarinman Send a message via Yahoo to seafarinman
Well I would not recommend aftermarket ones. I had the Sway-a-way ones and well after running them cranked a lot, I only found less flex, and a rougher ride than the stock ones. I recommend that you loosen them and get some of the SDORI Balljoint spacers so that you can have the lift and still a nice compliant ride.
__________________
DEPLOYED Again!
1994 SAS 2RZ/R151F=244:1!
1988 Toyota 4Runner SR5
seafarinman is offline
Old 12-23-2007, 06:57 PM   #3 (permalink)
BLKNBLU's Avatar
I was lucky and did not break mine but have heard that it is frequently the case that they do. Somebody on here has to know a part # and if it is dealer only. (I bet yes) Maybe edit your title to "t bar adjusting nuts" or something along those lines. There have been enough "t bar" threads on this board that some folks might not even look past the title any more.
__________________
86 4Runner, custom Sonoran Steel rear bumper, 4Crawler 1" body lift, rock sliders from Richard Stubbs, rear Lockright, SAS w/ARB
My build thread. http://www.yotatech.com/f66/blknblu-s-sac-155872/
BLKNBLU is offline
Old 12-23-2007, 08:20 PM   #4 (permalink)
Steveh29's Avatar
I had Sway A Way bars for a while and they were indeed terrible for wheeling. I could turn real sharp because they were so stiff, but that was the only quality they had. I since switched to Old Man Emu t bars and LOVE them. Wish I'd bought them years ago. They are thicker than stock but have a much nicer / softer ride than stock and keep my ride height with an ARB bumper.
__________________
Steve
1995 4Runner - V6 - 5 Speed
Rear ARB, Manual Hubs, Front TruTrac, Marlin Transmission, ARB Front & Sonoran Steel Rear bumpers that have saved my life!!
Steveh29 is offline
Old 12-23-2007, 08:29 PM   #5 (permalink)
BLKNBLU's Avatar
I don't think he's talking about getting different t bars. Just talking about the adjusting bolts that he is concerned he might break.(which he would still have to deal with if he put in different t bars)
__________________
BLKNBLU is offline
Old 12-23-2007, 08:50 PM   #6 (permalink)
offroadie's Avatar
yeah, both actually - my ride is a little firm with the smaller bumps at high speed (on road), but the adjusting bolts are iffy - any info is helpful, as you can see, I'm a newbie.
You guys rock!
__________________
Old 12-23-2007, 09:15 PM   #7 (permalink)
James Dean's Avatar
When I changed my bars my bolts snapped after about two turns on one and ten turns on the other. I had sprayed stuff on mine for three days before I evan tried. Here's the Toyota part #s for a '93: Bolt 90101-12159, Nut 90179-12074. They are a special designed bolt and nut, you won't be able to replace them with normal ones. They were only like $25 and it doesn't hurt to have new ones.
http://www.jamesdeancreations.com/4r...htm#Suspension
__________________
Custom painter and Toyota Stripe and decal supplier.
http://jamesdeancreations.com
Custom Safari and Crawlin accessories.
http://www.jamesdeancreations.com/4runner_project.htm
James Dean is offline
Old 12-23-2007, 09:18 PM   #8 (permalink)
James Dean's Avatar
By the way I have Old Man Emu torsion bars and 901HD coil springs and I love them. The ride is firm but not stiff. No lumber wagon here.
__________________
Old 12-23-2007, 09:23 PM   #9 (permalink)
BLKNBLU's Avatar
Quote:
Originally Posted by James Dean View Post
When I changed my bars my bolts snapped after about two turns. Here's the Toyota part #s: Bolt 90101-12159, Nut 90179-12074. They are a special designed bolt and nut, you won't be able to replace them with normal ones. They were only like $25 and it doesn't hurt to have new ones.
Nice!
__________________
BLKNBLU is offline
Old 12-23-2007, 09:30 PM   #10 (permalink)
James Dean's Avatar
Here's a pic of a two piece version of the bolt. lol. Notice how the bolt has a shank and the nut has a sleeve that drops down into the adjuster arm. That's why regular blots and nut won't work.
__________________
Old 12-23-2007, 09:35 PM   #11 (permalink)
BLKNBLU's Avatar
Mine were a little different than that. I had 2 nuts up top. One about 1" or 1 1/2" thick, then a second regular sized nut as a lock. Still, as you say, not a typical hardware store item.
__________________
BLKNBLU is offline
Old 12-23-2007, 09:37 PM   #12 (permalink)
James Dean's Avatar
That's true, I didn't show the lock nuts, but those are regular.
__________________
Old 12-23-2007, 11:35 PM   #13 (permalink)
wildcatkit52's Avatar
Here is a question. When people break these bolts, where you using air tools or hand tools? I have found that hand tools and the larger amount of torque applied causes more breakage than air.
I completely removed both sides on my 95 T100 yesterday after only a short period of time soaking. I used air tools and had no problems removing or reinstalling these.
If anybody here rides ATV's and owns a Yamaha or has messed with a banshee or the like, you will know how easy the factory lug nuts are to strip using hand tools compared to air tools. These adjustment bolts on torsion bars seem to have the same issues on almost all vehicles using torsion bars I have messed with...
__________________
SFC Hubbard
95 T100 SR5 ($500 needed transfer case!) Rancho 9000 shocks just added, days away from wheels and tires, ball joint spacers/shackles tbars
[color="Red"]
99 Chevy S10 Blazer5 inch lift, various A/M parts. Stuck 60K engine in. 4Sale if you need it!
89 GMC Heavy HalfTon 4/6in ProComp lift Parting out all but engine tranny Rear axle
89 GMC 'burban new 8 in spring/shackle lift tranny went parting some keeping some for 86 truck build
92 Camaro WIP
66 Buick Skylark GranSport WIP
wildcatkit52 is offline
Old 12-24-2007, 11:25 AM   #14 (permalink)
offroadie's Avatar
hmm, I haven't seen any locknuts on mine. Are they supposed to be there?
also, are the Old Man Emu bars propriatary? I've noticed a lot of "when used with our _____, for best performance" language on their site, is it cool to just use the bars alone?
__________________
Old 12-24-2007, 12:27 PM   #15 (permalink)
AxleIke's Avatar
Oh yes, you can use the bars alone. I have the OME bars, and love them. I have BJ spacers, then relaxed back to stock height (so my tbars are lowered 1.5") I have an aftermarket front bumper, and I can say the ride has never been better. (for a torsion bar truck. It still isn't great, but its as good as I've gotten).
I can actually use my entire flex range. Bump stop to bumpstop, very easily, which makes for better performance offroad.
I would recommend the OME tbars if you have a bumper and winch, and stock tbars if you have a stock bumper.
As for the bolts, good luck. I'd just go buy a new pair at the dealer ship. That way, if you break the old ones, no big deal.
There are different bolt/nut combos for various years. I ordered mine from the dealer, and they gave me the wrong ones, since they had a pair from a 1990 4runner in stock. I had to wait for the specific 87 ones to come in.
__________________
1987 Mutant 4runner|Slightly Modified|Lacking general build direction
-Lifts and Tires look cool at the Mall, Lockers and Gears look cool on the trail.
-Internet Nice Guy
AxleIke is offline
Old 12-24-2007, 01:08 PM   #16 (permalink)
BLKNBLU's Avatar
Quote:
...X2
__________________
BLKNBLU is offline
Old 12-24-2007, 02:05 PM   #17 (permalink)
James Dean's Avatar
Sometimes there are no locknuts. The sleeve on the nut is designed so as not to turn. My ome bars are set to stock height with 1.5" spacers for my lift. I just wanted a stoughter bar for added weight and stability. I have a front hitch for a wench cradle plus other gear.
__________________
Old 12-24-2007, 05:51 PM   #18 (permalink)
the SAW bars arent so bad with a T100, i had them on mine before i did C/Os
Jake97T is offline
Old 12-24-2007, 08:22 PM   #19 (permalink)
CC_yota's Avatar
Send a message via Yahoo to CC_yota
Mine didn't have lock nuts either and when I got my new bolts from the dealership the exploded view for the torsion bars showed no lock nuts, but our 87 has them so it seems to be a year specific deal. I had no choice but to break the driver side bolt. The bolts are fairly inexpensive and the peace of mind is nice. I think it was Deathrunner who said he had heard of the adjuster bolts breaking on guy, puncturing the floor and hitting him in the arse.
__________________
95 4Runner- 3vze- A/T- 4.88's
Currently
LC Coils
BJ Spacers
SAW T-Bars
32x11.50 BFG A/T's
15x8 black Rockcrawlers
Marlin Crawler rear bumper
CC_yota is offline
Old 12-25-2007, 05:38 PM   #20 (permalink)
Try "Areo Kroil" it is the best rust penetrater out there.
You can get it at Grainger or any industrial supply co.
Soak the bolts it that stuff for a few days and see what happens !!
Good Luck
See Rock City is offline
Old 12-26-2007, 04:07 PM   #21 (permalink)
FYI, the bolts and nuts for the T100 torsion bars are identical to the 88-95 4runners and trucks. It is a lot easier to find one of those in a boneyard than a T100..
__________________
94 FZJ80 fully locked, OME lift, 285s; 95 T100 beater edition; 1995 LS 400.
No problem, I'll tow the pig with a Uhaul Trailer...
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
Klierslc is offline
Old 12-27-2007, 02:17 PM   #22 (permalink)
offroadie's Avatar
now that is good to know, seriously! Most 'yards around here are pretty stripped dry...but worth a look.
As far as the OME bars go, for those of you that own a set, how much should I expect to pay for those things?
__________________
Old 01-07-2008, 08:07 AM   #23 (permalink)
Torsion Bars
What is the stock height for the T-100. I have messed with mine in the past trying to get a better ride, but come to find out it was due to the crappy goodyear tires. I would like to put it back to stock specs. If anyone knows, that would be great. Thanks!
96 T100 is offline
Tags
1994, 9010112159, 9017912074, adjustment, axle, bar, bars, bolt, exploded, gmc, replace, safari, t100, torsion, toyota, uhaul, view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
old torsion bars? jay33 86-95 Trucks & 4Runners 12 05-07-2007 05:50 PM
torsion bars t100 93-98 T100s 6 09-24-2006 08:09 PM
Torsion bars Rammedic 95.5-2004 Tacomas & 96-2002 4Runners 1 10-17-2005 05:30 PM
Torsion bars halcyon0 The Fab Shop 7 01-30-2004 10:37 AM
for those of you with SAW torsion bars.. doink 95.5-2004 Tacomas & 96-2002 4Runners 37 06-04-2003 04:39 PM
2009 InternetBrands, Inc.
