| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Torn CV(outer)grease splattering-Not Good-How much to fix$$
__________________
69 FJ40 93 FZJ80 RUBICON TESTED&READY! 98 T100 ext.cab 4WD 2000 4RUNNER LIMITED 4WD |
#2 (permalink) |
Honestly, You say you can do an engine swap...So I would bet you could DIY..
From what I have read, (lots of reading) If the boot goes its probably wise to replace the whole CV joint/axle..Aboot 80 bucks from napa when you turn in your core. If an engine swap means anything to me in mechanical abilities, it'll take you 2 hours. Someone please correct me if im misleading this guy
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#3 (permalink) |
I'v had both my outer cv boots go. a new boot kit from the dealer is about $40. As long as you haven't been driving on it for like thousands of miles with it blown open you should be ok to just slap a new boot kit on it. I did my pass. side about two years ago and it's fine. just did my drivers side last month. drove about 500 miles with it blown open. still good. not bad to change. If you can swap en engine you re-boot a cvshaft. It's not as bad to drive on it as say a frontwheel drive car because unless it is in 4wheel, there is no real force being put on it. just turning with the wheels. however, you really should replace it as soon as possible.
__________________
93 T-100 3.0 5spd 4x4 high flow cat, custom duals 17" Powder coated Sequoia wheels 32" Mickey Thompson Baja ATZ tires stock lift new factory clutch- if you order from Downey, make sure you get the right one:( diff breather mod. cobra cb custom rear bumper w/tire carrier-Kennasaw Mtn. acc. In the works. light bar and hella 500's Last edited by Froggy93; 01-14-2009 at 06:30 PM. |
#4 (permalink) |
Definatly replace the whole shaft, dirt and crap will really screw you up, i replaced both of mine, took me about and hour and ahalf each side, it cost me about $90 from advance auto parts. not too bad though, i suggest pick up a haynes manual. Geno
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| blaster trans valve fix - any good | simpsons721 | 86-95 Trucks & 4Runners | 0 | 10-02-2008 01:11 PM |
| outer tie rod joint grease, name and where to get it | neliconcept | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 06-18-2007 06:20 PM |
| Lithium based grease or Moly based grease dose it really matter? | kmcc78240 | General Vehicle Related Topics (Non Year Related) | 4 | 09-22-2006 04:04 PM |
| Needle adapters for grease guns. Good enough? | Greenman | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 07-13-2006 12:24 PM |
| Think you are good? Fix THIS problem !! (spyware related) | Stegall984R | Computer Talk | 16 | 09-19-2005 07:20 PM |
