Newbie has some ??? on lifting - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 93-98 T100s
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-17-2009, 11:24 AM   #1 (permalink)
Hi everyone,
I am an experienced mechanic and have done a lot of work on my 95 t100 extended cab 4X4 manual with the 3.4L. The one area where I haven't done anything is the suspension. I just got some new KYB gas shocks on her and I would really like to lift it a bit. I don't want anything too intense just maybe 2-3 inches for a little more clearance while off roading. What is the best way to go about this without spending a ton of cash (I'm a college student so it goes without saying that i'm not looking to spend much). Can I adjust the torsion bars easily? What about body spacers, is that a good way to go? Any ideas would be appreciated.
Nick
funnyguy44444 is offline
Old 06-17-2009, 11:30 AM   #2 (permalink)
scuba's Avatar
Body lift..
Torsion bar lift..
Ball joint spacers..
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 06-17-2009, 11:48 AM   #3 (permalink)
Alright body lift spacers and ball joint spacers are pretty straightforward but the torsion bars I'm inexperienced with. How would I adjust those and how much of a difference could it make?
Old 06-17-2009, 12:00 PM   #4 (permalink)
scuba's Avatar
FYI, Your front suspension is the same as the 86-95 Trucks and 4Runners, So you should deff do some searching in there for lift and things..
But since im board.
Here is your suspension..
The red is the torsion bars, the adjusting bolts are on the frame near the transmission Xmember Here is some more reading
FYI, your probably dont want to adjust them more then 1.5 " as your truck will ride harsher and you will feel every little bump, not to mention if you have ADD you could tear a boot.
Good luck
__________________
scuba is offline
Old 06-17-2009, 12:41 PM   #5 (permalink)
Doddy's Avatar
Get some new tires that is the only true way to gain clearance and it's a good
__________________
2000 Black 4Runner Sport
Deck Plate Mod w/ K&N Filter
WAAG Grill Guard
6.5" JDM Toyota Fog Lights with Black Rock Guards
Thule M.O.A.B. Roof Basket
2"(F), 2.5"(R) Cornfed Spacer Lift
17" Black AR Rims on 265/70/17 Duellers
Doddy is offline
Old 06-17-2009, 01:07 PM   #6 (permalink)
scuba's Avatar
Quote:
Valid Point, But will he be able to fit the tires without the lift...Without hacking and ing on the damn thing..
__________________
scuba is offline
Old 06-18-2009, 07:26 AM   #7 (permalink)
I'm already rolling on 35s and I think thats about as big as this truck will fit without lifting it. They are on their last leg though so thats why I'm thinking about doing this now so that I could possibly upsize when I get new ones. Thanks a lot Scuba, thats a really good pic of the whole thing and definitely a good piece of info to know. t100 parts are harder to find than stuff for the trucks and 4runners.
Old 06-22-2009, 10:26 PM   #8 (permalink)
35s?
Can you post a pic of your T100 with 35s on her? I have already changed the torsion bars out for some heavier ones from Downey offroad. At least 1.5 with out effecting the ride but I'm ride on 31s. i was think 33s would be tight.
jimmck is offline
Old 06-28-2009, 12:38 PM   #9 (permalink)
Bagger's Avatar
If you're going to do a suspension lift, you're going to need longer shocks. The stock length shocks will be stretched to the max when you add a lift and/or larger tires. Breakage will be imminent.
If you add a body lift, the shock mounts don't change and you can run regular shocks.
Good luck finding longer shocks for a lifted T100. I've been in the hunt for over a year and I still haven't found anything available other than the Rancho 5000's, which based on my previous experience with them, are not a good shock for the money. I am discussing with one manufacturer the availability of a shock for the T100 with a 2" lift. Still waiting to hear for certain whether they have anything or not....
__________________
'97 T100 ~ TRD SC ~ ARB ~ FWC
'85 FJ6O ~ 4E9 ~ locked ~ 33's
'87 Turbo 4Runner ~ sold
Bagger is offline
Old 06-28-2009, 01:45 PM   #10 (permalink)
toyota4x4907's Avatar
Send a message via MSN to toyota4x4907
Quote:
You dont need longer shocks when you go only larger tires. Suspension lift, yes, larger tires, no.
__________________
'95 4runner|22re|5spd|130K miles|ISR| 2" BL| 31x10.5 | CompuStar Auto-start| two 170mm LightForce|anti-sway bars removed f/r|Warn manual hubs|ADD bypassed|Diff breather extensions|XLPerformance muffler
'88 4runner|22re|5spd|206K miles|Sold
'93 single cab|22re|5spd|150K miles|Sold|
Pro IFS
toyota4x4907 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
