Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Looking for front poly sway bar bushings
Hello,
I'm the proud new owner of a very clean '98 T-100 SR5 Ext. Cab 4x4. It appears that the front sway bar bushings need to be replaced and was wondering if anyone knows of a source for some poly replacement bushings, specifically for the front sway bar? Great forum. Thanks in advance, |
| Sponsored Links |
#2 (permalink) |
Downey Off-Road, try maybe also Jack-It.com
#3 (permalink) |
If you can get the dia. of the front sway bar, I probably have some bushings that will fit. There are various sizes from ~19mm up to ~25mm bar diameters.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs. r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
#5 (permalink) |
I got mine back when i had a sway bar from summit, just measured the stockers and ordered the energy susp. ones for $15 B4 shipping...which was another $9.95...so yeah basically Roger is probably cheaper...but then again my links were pretty shot.
#6 (permalink) |
Thank you for all the sources guys, I will check them out.
#7 (permalink) |
I think you mean Jackit.com...
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Sway bar bushings | Thrillbilly | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 04-04-2006 04:48 PM |
| more sway bar bushings | Localmotion | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 02-02-2005 11:30 AM |
| Front sway bar bushings trashed! | transalper | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 12-23-2003 09:48 AM |
| Front Sway Bar/End Link Bushings Replaced | TDiddy | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 05-30-2003 02:30 PM |
| Rear Poly Sway bar bushings | Luke | 86-95 Trucks & 4Runners | 4 | 06-10-2002 11:07 AM |
